wscsvc32.exe removal help
Post by newtronbomb on Tue Dec 15, 2009 4:34 pm
I have ran all the tests and everything appears to be cleaned up, I even ran the complete test. Now my internet explorer will not connect, just wondering what's going on? Please and thanks again
newtronbomb
Posts Posts : 4
Joined Joined : 2009-12-14
Points Points : 25546
Re: wscsvc32.exe removal help
Post by Belahzur on Tue Dec 15, 2009 6:50 pm
Make sure there is no proxy set.
    In Internet Explorer
    In Firefox
Points Points : 245091
