Internet is connected but doesn't work
Page 1 of 1
- MistarJTNovice
OS : Windows Vista
Rubies : 3150
Okay, so I'm using Vista and the internet is connected (the blue bubble has appeared and everything). However, nothing on my computer works if it needs the internet! Not Messenger, Skype og any of my browsers.
After having checked another thread on Geek Police I tried resetting my TCP/IP stack and the WINSOCK entries, but it didn't work (CMD telling me that the reques requires elevation). I also tried the Winsock XP Fix and rebooted my system, but this didn't work either (quite possibly because I'm using Vista, not XP).
Anything else I can do?
- BelahzurSite Admin
OS : 7 Home Premium x64
Rubies : 218223
Check your proxy settings.
- Tools Menu -> Internet Options -> Connections Tab ->Lan Settings > uncheck "use a proxy server" or reconfigure the Proxy server again in case you have set it previously.
In Internet Explorer
- Tools Menu -> Options... -> Advanced Tab -> Network Tab -> "Settings" under Connection > Choose "No Proxy"
- Click the apply button and restart that computer in normal mode.
In Firefox
Site Admin / Security Administrator
[Prework] - Please PM me if I fail to respond within 24hrs.
- MistarJTNovice
OS : Windows Vista
Rubies : 3150
Thanks, but it still doesn't work :/ and it's not just the browsers that can't connect -- everything that needs the internet has a problem! I uninstalled the anti-virus program I had and the Windows firewall is switched off.
Similar topics
Page 1 of 1
