Need help removing antivirus live
Post by ChicagoTed on 13th December 2009, 8:20 pm
No idea how it got there, but basically i've been searching a lot on how to remove it. nothing i do works. Every time i try to extract anything using ALZip, or download free online anti-virus scanners like AVG that stupid Security Warning that says "Application cannot be executed. The file acrord32info.exe is infected, Do you want to activate your anti-virus now?" pops up and its very annoying. I have no clue what to do anymore. Any ideas?
Basically here is a list of things that i already tried and didn't work
1. run "msconfg
2. extract anything using AlZip
3. free online anti-virus scanners such as AVG
4. every time i would un-click the "use a proxy server for your LAN" on explorer, it would just be re-clicked when i open up the LAN settings on the connections options on explorer tools
5. i cant do anything that it says here: [You must be registered and logged in to see this link.]
ChicagoTed
Posts Posts : 4
Joined Joined : 2009-12-13
Points Points : 25544
Re: Need help removing antivirus live
Post by Belahzur on 13th December 2009, 9:03 pm
Points Points : 245079
Post by ChicagoTed on 13th December 2009, 9:31 pm
Every time i open up HiJack This, it closes and doesn't let me do the system scan.
ChicagoTed
Posts Posts : 4
Post by Belahzur on 14th December 2009, 12:01 am
Run this first, then see if it lets you run Hijack This without it closing.
Post by ChicagoTed on 14th December 2009, 2:27 pm
Unfortunately, this cant open either. Every time i try open something up, even if its just AIM, i get that security warning telling me "file is aim.exe infected" or "file exehelper is infected".
This is just a thought, but i do have Norton Antivirus. Is there anything i can do with it that can help me?
ChicagoTed
Posts Posts : 4
Post by Belahzur on 14th December 2009, 7:29 pm
Post by dj hamer on 14th January 2010, 9:16 am
Moderated Message: Hello, your comment has been removed. Please do not post in another member's topic. If you need help, please read [You must be registered and logged in to see this link.] over and [You must be registered and logged in to see this link.] to open a new topic.
dj hamer
Joined Joined : 2010-01-14
OS OS : windowsxp
Points Points : 25205
