proper way to adjust speakers on PC
Solved proper way to adjust speakers on PC
Post by suzonka on Sun Dec 13, 2009 2:04 pm
I have external speakers on my PC ,I have 2 choices to adjust them ,1 turn speaker volume up on the speakers, and turn the PC volume down,or 2 turn the PC volume up and the speaker volume on the speakers down, which is the safest way to adjust the volume?
suzonka
Posts Posts : 199
Joined Joined : 2008-08-30
OS OS : windows 10
Points Points : 31663
Solved Re: proper way to adjust speakers on PC
Post by Nazzgull on Tue Dec 15, 2009 9:32 am
Hi, it's only your choice Smile I will probably turn on both
Points Points : 40455
Post by suzonka on Tue Dec 15, 2009 4:04 pm
@Nazzgull wrote:Hi, it's only your choice Smile I will probably turn on both
Thank You! DO YOU MEAN TURN THE SPEAKERS ON ABOUT 75% AND THE PC VOLUME CONTROL ABOUT 25% and then just use the PC volume to turn them down or up?
suzonka
Posts Posts : 199
OS OS : windows 10
Post by Nazzgull on Tue Dec 15, 2009 7:28 pm
You should let PC to configure them Smile Also, you can do it manually.
Solved configure
Post by suzonka on Wed Dec 16, 2009 12:14 am
@Nazzgull wrote:You should let PC to configure them Smile Also, you can do it manually.
how do you configure the speakes? Hooray!
suzonka
Posts Posts : 199
OS OS : windows 10
Post by Doctor Inferno on Wed Dec 16, 2009 3:16 am
It doesn't matter how to adjust the volume it makes no difference.
Points Points : 104600
Post by suzonka on Mon Jan 04, 2010 1:16 am
thanks DOCTOR INFERNO
suzonka
Posts Posts : 199
OS OS : windows 10
