Virus Problem
Virus Problem
Post by kconley1014 on Sat Dec 12, 2009 11:57 pm
Hi, I am using Windows Vista and currently am experiencing a virus problem with something blocking most internet access and it claims there are multiple trojans affecting my system and I need to purchase additional protection, which I found out from a real life friend is a scam and apparently there is only 1 virus, being that. It has the same problem as another post by loveblakelewis i believe with something coming up and saying ____win32. etc. If there's any help you could give me, it would be extremely appreciated, thank you.
kconley1014
Joined Joined : 2009-12-12
OS OS : Vista
Points Points : 25508
Re: Virus Problem
Post by Dr Jay on Sun Dec 13, 2009 12:17 am
Posts Posts : 13713
Points Points : 302059
Re: Virus Problem
Post by kconley1014 on Sun Dec 13, 2009 2:40 pm
First off, I have Windows VISTA, not XP, so the "Run" function you mentioned is something I cannot do. And also, when I tried to download Combo Fix (I attempted each link you gave) it would download all the way and finally McAfee would come up and say "Successfully Removed Trojan" or something like that. Also, I dont know how to rename the Combo Fix to commy because I'm on windows vista.. Im sorry but I just don't know what to do. Any further help would be greatly appreciated, thank you.
Scan saved at 10:31:38 AM, on 12/13/2009
Platform: Windows Vista SP1 (WinNT 6.00.1905)
MSIE: Internet Explorer v7.00 (7.00.6001.18349)
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Program Files\Dell\DellDock\DellDock.exe
C:\Windows\system32\taskeng.exe
C:\Program Files\Windows Defender\MSASCui.exe
C:\Program Files\DellTPad\Apoint.exe
C:\Windows\OEM02Mon.exe
C:\Windows\System32\rundll32.exe
C:\Program Files\Intel\Intel Matrix Storage Manager\IAAnotif.exe
C:\Windows\System32\WLTRAY.EXE
C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
C:\Program Files\Dell\MediaDirect\PCMService.exe
C:\Program Files\Dell DataSafe Online\DataSafeOnline.exe
C:\Program Files\Dell Support Center\bin\sprtcmd.exe
C:\Program Files\Dell V305\dldtmon.exe
C:\Program Files\Fingerprint Reader Suite\psqltray.exe
C:\Program Files\Dell V305\dldtMsdMon.exe
C:\Program Files\MyWebSearch\bar\1.bin\M3SRCHMN.EXE
C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE
C:\Program Files\DellTPad\HidFind.exe
C:\Program Files\HP\HP Software Update\hpwuSchd2.exe
C:\Program Files\DellTPad\Apntex.exe
C:\Program Files\Dell\QuickSet\quickset.exe
C:\Program Files\HP\Digital Imaging\bin\hpqbam08.exe
C:\Program Files\HP\Digital Imaging\bin\hpqgpc01.exe
C:\Program Files\AIM\aim.exe
C:\Users\Bugger\Downloads\winlogon.scr
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Internet Explorer provided by Dell
O1 - Hosts: ::1 localhost
O2 - BHO: MyWebSearch Search Assistant BHO - {00A6FAF1-072E-44cf-8957-5838F569A31D} - C:\Program Files\MyWebSearch\bar\1.bin\MWSSRCAS.DLL
O2 - BHO: mwsBar BHO - {07B18EA1-A523-4961-B6BB-170DE4475CCA} - C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - c:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: McAfee Phishing Filter - {27B4851A-3207-45A2-B947-BE8AFE6163AB} - c:\PROGRA~1\mcafee\msk\mskapbho.dll
O2 - BHO: Windows Live Family Safety Browser Helper - {4f3ed5cd-0726-42a9-87f5-d13f3d2976ac} - C:\Program Files\Windows Live\Family Safety\fssbho.dll
O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
O2 - BHO: livetvbar Toolbar - {ad55c869-668e-457c-b270-0cfb2f61116f} - C:\Program Files\livetvbar\tbliv0.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll
O2 - BHO: AIM Toolbar Loader - {b0cda128-b425-4eef-a174-61a11ac5dbf8} - C:\Program Files\AIM Toolbar\aimtb.dll
O2 - BHO: Browser Address Error Redirector - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\Dell\BAE\BAE.dll
O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
O2 - BHO: HP Smart BHO Class - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O3 - Toolbar: livetvbar Toolbar - {ad55c869-668e-457c-b270-0cfb2f61116f} - C:\Program Files\livetvbar\tbliv0.dll
O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
O3 - Toolbar: My Web Search - {07B18EA9-A523-4961-B6BB-170DE4475CCA} - C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL
O3 - Toolbar: AIM Toolbar - {61539ecd-cc67-4437-a03c-9aaccbd14326} - C:\Program Files\AIM Toolbar\aimtb.dll
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [Apoint] C:\Program Files\DellTPad\Apoint.exe
O4 - HKLM\..\Run: [OEM02Mon.exe] C:\Windows\OEM02Mon.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [NVHotkey] rundll32.exe C:\Windows\system32\nvHotkey.dll,Start
O4 - HKLM\..\Run: [UpdReg] C:\Windows\UpdReg.EXE
O4 - HKLM\..\Run: [PSQLLauncher] "C:\Program Files\Fingerprint Reader Suite\launcher.exe" /startup
O4 - HKLM\..\Run: [IAAnotif] "C:\Program Files\Intel\Intel Matrix Storage Manager\Iaanotif.exe"
O4 - HKLM\..\Run: [Broadcom Wireless Manager UI] C:\Windows\system32\WLTRAY.exe
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [dscactivate] "C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe"
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Dell\MediaDirect\PCMService.exe"
O4 - HKLM\..\Run: [Dell DataSafe Online] "C:\Program Files\Dell DataSafe Online\DataSafeOnline.exe" /m
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "c:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O4 - HKLM\..\Run: [fssui] "C:\Program Files\Windows Live\Family Safety\fsui.exe" -autorun
O4 - HKLM\..\Run: [dldtmon.exe] "C:\Program Files\Dell V305\dldtmon.exe"
O4 - HKLM\..\Run: [dldtamon] "C:\Program Files\Dell V305\dldtamon.exe"
O4 - HKLM\..\Run: [MyWebSearch Plugin] rundll32 C:\PROGRA~1\MYWEBS~1\bar\1.bin\M3PLUGIN.DLL,UPF
O4 - HKLM\..\Run: [My Web Search Bar Search Scope Monitor] "C:\PROGRA~1\MYWEBS~1\bar\1.bin\m3SrchMn.exe" /m=2 /w /h
O4 - HKLM\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
O4 - Startup: Dell Dock.lnk = C:\Program Files\Dell\DellDock\DellDock.exe
O4 - Global Startup: QuickSet.lnk = C:\Program Files\Dell\QuickSet\quickset.exe
O8 - Extra context menu item: &Search - [You must be registered and logged in to see this link.]
O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: HP Smart Select - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O13 - Gopher Prefix:
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} (DivXBrowserPlugin Object) - [You must be registered and logged in to see this link.]
O20 - AppInit_DLLs: C:\PROGRA~1\Google\GOOGLE~3\GOEC62~1.DLL
O20 - Winlogon Notify: GoToAssist - C:\Program Files\Citrix\GoToAssist\514\G2AWinLogon.dll
O23 - Service: Andrea ST Filters Service (AESTFilters) - Andrea Electronics Corporation - C:\Windows\system32\aestsrv.exe
O23 - Service: Creative Labs Licensing Service - Creative Labs - C:\Program Files\Common Files\Creative Labs Shared\Service\CreativeLicensing.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\Windows\system32\CTsvcCDA.exe
O23 - Service: dldtCATSCustConnectService - Unknown owner - C:\Windows\system32\spool\DRIVERS\W32X86\3\\dldtserv.exe
O23 - Service: dldt_device - - C:\Windows\system32\dldtcoms.exe
O23 - Service: Dock Login Service (DockLoginService) - Stardock Corporation - C:\Program Files\Dell\DellDock\DockLogin.exe
O23 - Service: Google Desktop Manager 5.9.911.3589 (GoogleDesktopManager-110309-193829) - Google - C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
O23 - Service: GoToAssist - Citrix Online, a division of Citrix Systems, Inc. - C:\Program Files\Citrix\GoToAssist\514\g2aservice.exe
O23 - Service: Intel(R) Matrix Storage Event Monitor (IAANTMON) - Intel Corporation - C:\Program Files\Intel\Intel Matrix Storage Manager\Iaantmon.exe
O23 - Service: McAfee Anti-Spam Service (MSK80Service) - McAfee, Inc. - C:\Program Files\McAfee\MSK\MskSrver.exe
O23 - Service: My Web Search Service (MyWebSearchService) - MyWebSearch.com - C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwssvc.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\Windows\system32\nvvsvc.exe
O23 - Service: SupportSoft Sprocket Service (dellsupportcenter) (sprtsvc_dellsupportcenter) - SupportSoft, Inc. - C:\Program Files\Dell Support Center\bin\sprtsvc.exe
O23 - Service: SigmaTel Audio Service (STacSV) - IDT, Inc. - C:\Windows\system32\STacSV.exe
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
O23 - Service: Dell Wireless WLAN Tray Service (wltrysvc) - Unknown owner - C:\Windows\System32\WLTRYSVC.EXE
End of file - 11626 bytes
Last edited by kconley1014 on Sun Dec 13, 2009 3:36 pm; edited 1 time in total (Reason for editing : Didn't Include the HJT Report)
kconley1014
OS OS : Vista
Re: Virus Problem
Post by Dr Jay on Sun Dec 13, 2009 6:44 pm
Please download ComboFix and double-click on it to run. When it launches the log, please post it in your next reply.
Posts Posts : 13713
