cpu problem
cpu problem
Post by amir20001 on Sat Dec 12, 2009 9:22 pm
i just got this used hp comp, dual core at 1800Mgh. when i tryed to install xp it too about 3-4 hours so i ran some speed test and it turns out the cpu is going at about 337Mgh Evil or enraged . can any one tell me whats wrong or what i can do to fix it
amir20001
Posts Posts : 83
Joined Joined : 2008-08-08
Points Points : 30821
Re: cpu problem
Post by xald on Sat Dec 12, 2009 10:00 pm
i have 400 MHz CPU (Pentium ii)on my OLD PC (home made) and xp take 1.2 hrs so i cant see why it took 3-4 hrs.
any way back to the problem how much ram and how bug is the Hard Disk what speed is your CD drive and was this a prebuilt PC or or a custom build
your Friendly neighborhood ....... me,
Seth Honored
xald
Posts Posts : 154
Joined Joined : 2009-10-30
OS OS : windows xp home sp3,
Protection Protection : malwarebytes anti-malware, avg free 9.0
Points Points : 27062
Re: cpu problem
Post by amir20001 on Sat Dec 12, 2009 10:41 pm
well mabe it did not take that long i was not rly timing but it took too long, hard drive is new(sata), 1 gb ram , cd player pritty new it has a light scribe, dvd reader and burner i dont know the exact speed. even after installation it was very slow
amir20001
Posts Posts : 83
Re: cpu problem
Post by xald on Sun Dec 13, 2009 3:19 pm
oh that makes sense then
when you started installation windows asks if you need to install RAID or other 3rd party drivers and i believe Serial ATA drives require special drivers (you may want to google that) but thats all i can think of
xald
Posts Posts : 154
Re: cpu problem
Post by amir20001 on Sun Dec 13, 2009 7:01 pm
i'll do some research and test it out
didn't work Sad tearing
amir20001
Posts Posts : 83
Re: cpu problem
Post by xald on Mon Dec 14, 2009 10:51 pm
oh well sorry then
xald
Posts Posts : 154
Re: cpu problem
Post by virushater1 on Tue Dec 22, 2009 12:22 am
I would check the bios and make sure that the speed registers correctly there. All bios's are different but you'll have to search around to find that section, my guess would be in advanced settings. If this is a motherboard not a dell or hp ect. check the motherboard settings sheet and make sure all the jumpers are set correctly. Then try flashing the bios. Good luck.
virushater1
Posts Posts : 8
Joined Joined : 2009-12-21
Points Points : 25443
Re: cpu problem
Post by amir20001 on Tue Dec 22, 2009 4:07 am
it was a bios problem not sur what but updating it worked(well it seems that way so far) thx for every ones help Thank You!
amir20001
Posts Posts : 83
