Firewall Questions... please help
Post by okstsk8ter on Sat Dec 12, 2009 3:49 am
My Firewall keeps interupting my internet browsing with 2 .exe's and it tells me if i want to block them or allow them. The 1st one is Cdas3c4.exe and the 2nd is RegAsm.exe ... how can i get rid of this?
okstsk8ter
Posts Posts : 12
Joined Joined : 2009-11-20
Points Points : 25822
Re: Firewall Questions... please help
Post by Dr Jay on Sat Dec 12, 2009 8:29 am
Posts Posts : 13719
Points Points : 302143
Question for Dragon Master Jay
Post by okstsk8ter on Sat Dec 12, 2009 8:31 pm
I downloaded the combofix like you told me, it scanned... and since i had a Cyberdefander Anti Virus, Cyberdefender PC Support, Cyberdefender Fix PC Errors to speed up your computer, Webroot internet security and Walwarebytes Anti-Malware, it scanned And it Removed My Cyberdefender anti virus, pc support and error fixer but left Webroot and malwarebytes.. what should i do? should i re-install it? should i leave it like that? or why did it remove it? please reply asap... it also gave me a Log.. please reply
okstsk8ter
Posts Posts : 12
Post by okstsk8ter on Sat Dec 12, 2009 10:27 pm
also i got this blue screen that has slowed down my computer Big time
okstsk8ter
Posts Posts : 12
Post by Dr Jay on Sun Dec 13, 2009 12:16 am
I merged some info in to this topic. Please do not start a new topic.
Please download the Kaspersky AVP Tool from [You must be registered and logged in to see this link.].
  • Save it to your desktop.
  • Please reboot to Safe Mode (tap the F8 key just before Windows starts to load and select the Safe Mode option from the menu).
  • Click Next to continue.
  • It will by default install it to your desktop folder.Click Next.
  • Hit ok at the prompt for scanning in Safe Mode.
  • Under Automatic scan make sure these are checked:
    • System Memory
    • Startup Objects
    • Disk Boot Sectors.
    • My Computer.
After that click on Security level then choose Customize then click on the tab that says Heuristic Analyzer then choose Enable Deep rootkit search then choose ok.
Then choose OK again then you are back to the main screen.
  • Then click on Scan at the to right hand Corner.
  • It will automatically Neutralize any objects found.
  • If some objects are left un-neutralized then click the button that says Neutralize all
  • If it says it cannot be Neutralized then chooose The delete option when prompted.
  • After that is done click on the reports button at the bottom and save it to file name it Kas.
  • Save it somewhere convenient like your desktop and just post only the detected Virus\malware in the report it will be at the very top under Detected post those results in your next reply.
Posts Posts : 13719
Post by okstsk8ter on Mon Dec 14, 2009 6:27 am
I ran the kaspersky AVP and it held on 97% and never advanced... it stayed there for 19 hours until finally i closed it in safe mode like you told me... i did write down the virus... or the items it detected..
#1 Exploit.Java.Gimsh.a
#2 Trojan.Win32.Genome.alet
#3 Trojan.Win32.Krepper.y
#4 Trojan.Downloader.WMA.Wimad.n
Also like i mentioned before, the Combofix Deleted my Cyberdefender Anti-virus, PC Support and Error Cleaner.. should i re-install them or were they removed for a reason? and i have a Blue Screen that has slowed my computer and possibly taken a lot of my memory and Space... also, Windows installer keeps trying to Install Sonic Mydvd plus every 5 mins.. i looked in my control panel and i have 4 programs.. how do you advice? the Kaspersky uninstalled itself in safemode and i had no way of Saving the Report that i was viewing... please let me know please
okstsk8ter
Posts Posts : 12
Post by Dr Jay on Mon Dec 14, 2009 6:30 am
Actually, all three of those you said are rogue software, and are not recommended.
Posts Posts : 13719
Post by okstsk8ter on Tue Dec 15, 2009 5:00 pm
ok.. i did the malware scan.. it took me a while to post this because since the scan took too long.. by the time i came to check on it.. my computer was reset.. this malware didnt find anything.. but my webroot did, it found a trojan worm-bagle.. also, i keep asking about the Combofix Deleted my Cyberdefender Anti-virus, PC Support and Error Cleaner.. should i re-install them or were they removed for a reason?
Database version: 2797
12/15/2009 8:52:15 AM
mbam-log-2009-12-15 (08-52-15).txt
Objects scanned: 231249
Time elapsed: 52 minute(s), 38 second(s)
okstsk8ter
Posts Posts : 12
Post by Dr Jay on Tue Dec 15, 2009 10:20 pm
  • Click Start
  • Click Start
Posts Posts : 13719
