Wireless not working
Solved Wireless not working
Post by justinob on Wed Dec 09, 2009 2:55 am
My wireless seems to not be working and it can't even find the network...I was using it yesterday and now it just suddenly stopped working.
justinob
OS : XP
Solved Re: Wireless not working
Post by Doctor Inferno on Wed Dec 09, 2009 3:08 am
Open CMD, Reset WINSOCK entries to installation defaults by typing: netsh winsock reset catalog
Restart your PC.
If it doesn't work, download Winsock XP Fix from here, save it to your Desktop.
See if you can connect now.
Post by justinob on Wed Dec 30, 2009 2:16 pm
I did both of them. but they still didn't work it says this
EDIT:Even though it says that when I click the balloon it didn't find anything and I am right next to my wireless router
justinob
OS : XP
Post by Doctor Inferno on Wed Dec 30, 2009 3:03 pm
Have you got the correct router configuration settings? Please try resetting your router and connecting again.
Post by justinob on Wed Dec 30, 2009 11:43 pm
Everything is fine for my brother's laptop, but for me it just doesn't work
justinob
OS : XP
Post by justinob on Fri Jan 01, 2010 11:44 pm
The wireless works now...after I was doing combofix I think...but whatever the reason was it's back ^_^
justinob
OS : XP
