Antivirus System pro
Re: Antivirus System pro
Post by sajeev_p on 8th January 2010, 11:34 pm
I ran the system look again as per the code provided, Also ran the Combofix with the CFscript. But something peculiar happened before combofix ran, it gave a message saying combofix needs to be updated, then it connected to some server, updated itself and then ran producing a log. is this normal?
Anyways please find the logs below for system look and combofix.
1. System look:
SystemLook v1.0 by jpshortstuff (29.08.09)
Log created at 12:56 on 08/01/2010 by Sajeev (Administrator - Elevation successful)
Searching for "*uridsys*"
No files found.
Searching for "* .exe"
No files found.
-=End Of File=-
2. Combofix(commy) ran with the CFScript provided- Log:
ComboFix 10-01-04.01 - Sajeev 01/08/2010 13:09:09.2.2 - x86
Microsoft® Windows Vista™ Business 6.0.6000.0.1252.1.1033.18.2046.1008 [GMT -8:00]
Running from: c:\users\Sajeev\Desktop\Commy.exe
Command switches used :: c:\users\Sajeev\Desktop\CFScript.txt
SP: McAfee VirusScan *disabled* (Updated) {C78B3C70-4777-4742-BB91-9D615CC575E6}
SP: Windows Defender *disabled* (Updated) {D68DDC3A-831F-4FAE-9E44-DA132C1ACF46}
/wow section - STAGE 1
c:\i386\eventlog.dll --> c:\windows\system32\eventlog.dll
((((((((((((((((((((((((( Files Created from 2009-12-08 to 2010-01-08 )))))))))))))))))))))))))))))))
2010-01-08 21:14 . 2010-01-08 21:14 -------- d-----w- c:\users\Public\AppData\Local\temp
2010-01-08 21:14 . 2010-01-08 21:14 -------- d-----w- c:\users\Default\AppData\Local\temp
2010-01-08 21:14 . 2010-01-08 21:14 -------- d-----w- c:\users\Administrator\AppData\Local\temp
2010-01-08 21:09 . 2004-08-04 11:00 55808 ----a-w- c:\windows\system32\eventlog.dll
2010-01-08 21:06 . 2010-01-08 21:07 -------- d-----w- C:\32788R22FWJFW
2010-01-05 09:57 . 2010-01-05 09:57 144160 ----a-w- c:\users\Sajeev\AppData\Roaming\Move Networks\uninstall.exe
2010-01-05 09:57 . 2010-01-05 09:57 -------- d-----w- c:\users\Sajeev\AppData\Roaming\Move Networks
2009-12-27 21:50 . 2009-12-27 21:54 -------- d-----w- C:\Commy28393C
2009-12-24 22:15 . 2009-12-24 22:31 -------- d-----w- C:\Commy29355C
2009-12-22 08:30 . 2009-12-22 08:39 -------- d-----w- C:\Commy
2009-12-20 02:36 . 2009-12-20 02:36 -------- d-----w- c:\users\Sajeev\AppData\Local\Apple Computer
2009-12-19 10:23 . 2009-12-19 10:23 -------- d-----w- c:\programdata\Kaspersky Lab
2009-12-14 08:43 . 2009-12-14 08:46 -------- d-----w- c:\programdata\RosettaStoneLtdServices
2009-12-14 08:43 . 2009-12-14 08:43 -------- d-----w- c:\program files\RosettaStoneLtdServices
2010-01-05 09:57 . 2009-12-07 01:22 5603776 ----a-w- c:\users\Sajeev\AppData\Roaming\Move Networks\plugins\npqmp071705000014.dll
2010-01-03 04:07 . 2009-12-01 12:15 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-01-03 04:07 . 2009-12-09 00:55 5061520 ----a-w- c:\programdata\Malwarebytes\Malwarebytes' Anti-Malware\mbam-setup.exe
2010-01-01 07:01 . 2008-01-26 20:13 0 ----a-w- c:\windows\system32\drivers\lvuvc.hs
2009-12-30 22:55 . 2009-12-01 12:15 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-12-30 22:54 . 2009-12-01 12:15 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-12-30 21:16 . 2009-12-08 23:50 -------- d-----w- c:\users\Sajeev\AppData\Roaming\Skype
2009-12-28 21:19 . 2007-04-29 22:28 7808 ----a-w- c:\users\Sajeev\AppData\Local\d3d9caps.dat
2009-12-22 05:16 . 2007-01-01 20:49 -------- d-----w- c:\program files\Common Files\Symantec Shared
2009-12-19 04:40 . 2009-12-01 12:57 120 ----a-w- c:\users\Pennu\AppData\Local\Nqehil.dat
2009-12-19 02:03 . 2009-12-01 12:57 0 ----a-w- c:\users\Pennu\AppData\Local\Aqipuz.bin
2009-12-07 01:22 . 2009-12-07 01:22 97216 ----a-w- c:\users\Sajeev\AppData\Roaming\Move Networks\ie_bin\MovePlayerUpgrade.exe
2009-12-04 01:09 . 2009-12-04 01:08 -------- d-----w- c:\users\Pennu\AppData\Roaming\Winamp
2009-12-01 20:50 . 2008-01-10 17:03 7808 ----a-w- c:\users\Pennu\AppData\Local\d3d9caps.dat
2009-12-01 12:54 . 2009-12-01 12:54 -------- d-----w- c:\users\Pennu\AppData\Roaming\Malwarebytes
2009-12-01 12:15 . 2009-12-01 12:15 -------- d-----w- c:\users\Sajeev\AppData\Roaming\Malwarebytes
2009-12-01 12:15 . 2009-12-01 12:15 -------- d-----w- c:\programdata\Malwarebytes
2009-12-01 10:52 . 2009-12-01 10:52 2962 ----a-w- c:\users\Pennu\AppData\Local\arafecufica.dll
2009-12-01 09:03 . 2009-12-01 09:03 2962 ----a-w- c:\users\Pennu\AppData\Local\ikivehadaj.dll
2009-11-25 11:21 . 2009-01-10 01:11 -------- d-----w- c:\program files\McAfee
2009-11-21 06:40 . 2009-12-22 01:49 916480 ----a-w- c:\windows\system32\wininet.dll
2009-11-21 06:34 . 2009-12-22 01:49 71680 ----a-w- c:\windows\system32\iesetup.dll
2009-11-21 06:34 . 2009-12-22 01:49 109056 ----a-w- c:\windows\system32\iesysprep.dll
2009-11-21 04:59 . 2009-12-22 01:49 133632 ----a-w- c:\windows\system32\ieUnatt.exe
2009-11-09 13:34 . 2009-12-09 10:16 24064 ----a-w- c:\windows\system32\nshhttp.dll
2009-11-09 13:30 . 2009-12-09 10:16 31232 ----a-w- c:\windows\system32\httpapi.dll
2009-11-09 11:17 . 2009-12-09 10:16 396800 ----a-w- c:\windows\system32\drivers\http.sys
2009-10-29 07:59 . 2009-11-25 11:02 2048 ----a-w- c:\windows\system32\tzres.dll
2009-10-27 15:01 . 2009-12-09 02:57 52736 ----a-w- c:\windows\AppPatch\iebrshim.dll
2007-03-11 09:39 . 2007-03-11 09:39 88 --sha-r- c:\windows\System32\20B142885A.sys
2007-03-11 09:40 . 2007-03-11 09:39 2828 --sha-w- c:\windows\System32\KGyGaAvL.sys
2007-01-05 20:18 . 2007-01-05 20:18 8192 --sha-w- c:\windows\Users\Default\NTUSER.DAT
"Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2008-01-10 1232896]
"WindowsWelcomeCenter"="oobefldr.dll" [2006-11-02 2159104]
"Yahoo! Pager"="c:\program files\Yahoo!\Messenger\YahooMessenger.exe" [2007-01-19 4670968]
"StartCCC"="c:\program files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2006-11-10 90112]
"DellSupport"="c:\program files\DellSupport\DSAgnt.exe" [2006-11-12 446976]
"ISUSPM Startup"="c:\progra~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe" [2006-10-03 221184]
"DellTransferAgent"="c:\programdata\Dell\TransferAgent\TransferAgent.exe" [2007-11-13 135168]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2006-11-02 201728]
"Skype"="c:\program files\Skype\Phone\Skype.exe" [2009-07-16 25604904]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2006-11-02 1004136]
"DellHelp"="c:\dell\DellHelp\DellHelp.exe" [2004-04-01 1589248]
"PCMService"="c:\program files\Dell\MediaDirect\PCMService.exe" [2006-08-22 184320]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2008-11-04 413696]
"RealTray"="c:\program files\Real\RealPlayer\RealPlay.exe" [2007-01-01 26112]
"SunJavaUpdateSched"="c:\program files\Java\jre1.5.0_06\bin\jusched.exe" [2005-11-10 36975]
"SigmatelSysTrayApp"="sttray.exe" [2007-01-12 303104]
"RoxWatchTray"="c:\program files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe" [2006-11-05 221184]
"WinampAgent"="c:\program files\Winamp\winampa.exe" [2007-05-14 35328]
"LogitechCommunicationsManager"="c:\program files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe" [2006-12-22 497176]
"LogitechQuickCamRibbon"="c:\program files\Logitech\QuickCam10\QuickCam10.exe" [2006-12-22 756248]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-11-20 290088]
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2009-10-29 1218008]
"Malwarebytes Anti-Malware (reboot)"="c:\program files\Malwarebytes' Anti-Malware\mbam.exe" [2009-12-30 1389904]
c:\users\Sajeev\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
CCC.lnk - c:\program files\ATI Technologies\ATI.ACE\Core-Static\CCC.exe [2006-9-29 49152]
America Online 9.0 Tray Icon.lnk - c:\program files\America Online 9.0\aoltray.exe [2007-1-1 156784]
Digital Line Detect.lnk - c:\program files\Digital Line Detect\DLG.exe [2007-4-6 50688]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office10\OSA.EXE [2001-2-13 83360]
QuickSet.lnk - c:\windows\Installer\{53A01CC6-14B0-4512-A2E7-10D39BF83DC4}\NewShortcut2_53A01CC614B04512A2E710D39BF83DC4.exe [2007-4-6 45056]
"aux"=wdmaud.drv
R2 RosettaStoneDaemon;RosettaStoneDaemon;c:\program files\RosettaStoneLtdServices\RosettaStoneDaemon.exe [9/3/2009 3:44 PM 444224]
LocalServiceNoNetwork REG_MULTI_SZ PLA DPS BFE mpssvc
2009-11-15 c:\windows\Tasks\McDefragTask.job
- c:\progra~1\mcafee\mqc\QcConsol.exe [2009-10-24 19:22]
2010-01-01 c:\windows\Tasks\McQcTask.job
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
Rootkit scan 2010-01-08 13:14
Windows 6.0.6000 NTFS
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DRM\clsid\{3da165b6-cc41-11d2-bdc6-00c04f79ec6b}\ProgID]
@Denied: (A) (Everyone)
@="{130DD502-9E74-4187-839C-C35B3164EAB6}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DRM\clsid\{3da165b6-cc41-11d2-bdc6-00c04f79ec6b}\Version]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
@Denied: (A) (Users)
"BlindDial"=dword:00000000
Completion time: 2010-01-08 13:17:48
ComboFix-quarantined-files.txt 2010-01-08 21:17
ComboFix2.txt 2009-12-27 22:14
Pre-Run: 32,517,271,552 bytes free
Post-Run: 32,497,868,800 bytes free
- - End Of File - - E684F7D64804D944BF820AE2873872B9
sajeev_p
Posts Posts : 17
Joined Joined : 2009-12-01
OS OS : vista
Points Points : 25891
Post by Dr Jay on 9th January 2010, 12:27 am
Yeah, that was fine for ComboFix. I was expecting it to update soon.
How is your computer running now?
Posts Posts : 14314
Points Points : 302989
Post by sajeev_p on 13th January 2010, 4:16 am
The computer seem to be running fine now, but there are multiple folders created on the C: drive, which are related to combofix runs I guess. how do I get rid of them? also is there any other scans I need to run to ensure the computer is clean.
sajeev_p
Posts Posts : 17
OS OS : vista
Post by Dr Jay on 13th January 2010, 4:56 am
To uninstall ComboFix
Posts Posts : 14314
Post by sajeev_p on 16th January 2010, 5:32 am
Hi ,
Please find below the log from security check:
Windows Vista (UAC is enabled)
Out of date service pack!!
Antivirus/Firewall Check:
Windows Firewall Disabled!
McAfee SecurityCenter
Antivirus up to date!
Adobe Flash Player 10
Process Check:
objlist.exe by Laurent
DNS Vulnerability Check:
Also I ran the un install command for combofix. It ran successfuly but the folders created on the root of C: have not been deleted.
following are the folders that are now appearing on the C: root
1. $INPLACE.~TR
2. $WINDOWS.~Q
3. Boot
4. 32788R22FWJFW
5. Commy
6. Commy882c
7. Commy28393c
8. Commy29355c
9. Config.Msi
10. e8535ee0d396b26b8f
Not sure if these folders were created by repeated running of the Combo fix and Gmer or folders created due to the infection.
Dont recollect these folders being present before the antivirus system pro infection.
Also the two folders starting with '$' is not allowing me access(even though I am logged on a s Admin). its directing me to windows access control message.
Please advise if(how) I should get rid of these folders.
thanks...
sajeev_p
Posts Posts : 17
OS OS : vista
