Antivirus System Removal Pro Shut down IE
Post by Coolblue on Sun Dec 06, 2009 11:44 pm
I was infected by the BS spyware program recently, and I got rid of it by using Malwarebytes, Spyware Doctor, and manual deletion of registry. One thing I noticed while infected was that it shut down my internet explorer so I could not get online help. I was lucky that it did not shut down Firefox however, so I used that to download the tools I need. I got rid of the virus, but internet explorer is still disabled, as everytime I run it, it takes me to the page where it says the webpage cannot be displayed. I ran diagnostic test, and HTTP and other things were being blocked. How do I free it up?
thx.
Coolblue
OS : XP
# Likes : 0
Re: Antivirus System Removal Pro Shut down IE
Post by Dr Jay on Mon Dec 07, 2009 12:42 am
OS : Windows 10 Home & Pro
# Likes : 10
Post by Coolblue on Tue Dec 08, 2009 8:29 pm
Ty but some complications occured while trying to install. In the end, I just reset all internet explorer preferences and data and it started working again. The only thing I'm worried about is that the block is still there but in waiting.
Coolblue
OS : XP
# Likes : 0
Post by Dr Jay on Wed Dec 09, 2009 1:07 am
Please start Internet Explorer, and when the program is open, click on the Tools menu and then select Internet Options.
  • Now click on the Connections tab and then the Lan Settings button
  • Under the Proxy Server section, please uncheck the checkbox labeled Use a proxy server for your LAN. Then press the OK button to close this screen. Then press the Apply button and then the OK button to close the Internet Options screen. Now that you have disabled the proxy server you will be able to browse the web again with Internet Explorer.
Then, post a log when ready.
# Likes : 10
