Bankerfox.a, wuauclt.exe and Antivirus Pro Help
Post by gadekm on 7th December 2009, 3:15 am
I have got a computer infected with the bankerfox.a virus and need help getting it cleaned up. It will not let me open anything on the infected machine. How do I go about downloading the Hijack This program? Can I follow steps you have posted for others with this infection? Thanks for any help you can give me.
gadekm
Posts Posts : 48
Joined Joined : 2009-12-06
OS OS : Vista
Points Points : 26286
Re: Bankerfox.a, wuauclt.exe and Antivirus Pro Help
Post by Dr Jay on 7th December 2009, 5:41 am
Posts Posts : 14309
Points Points : 302960
Post by gadekm on 8th December 2009, 4:33 am
I can not get to the web page to do any downloading. When I try to change the web page it goes to this address [You must be registered and logged in to see this link.] There are 20 plus red shields with white x's in them across the bottom taskbar and a yellow one that jumps through the red ones one by one. I downloaded the commy.exe to a disk from a different computer and put it on the desktop of the infected one the "run" feature comes up with an error that it can't find the commy.exe. When I double click or select run on the commy icon a small box flashes and says Combofix but that is all it does.
gadekm
Posts Posts : 48
OS OS : Vista
Post by gadekm on 8th December 2009, 4:35 am
I can not even get to geekpolice web site and if I let the computer set long enough porno pages come up.
gadekm
Posts Posts : 48
OS OS : Vista
Post by Dr Jay on 8th December 2009, 4:45 am
Please download: [You must be registered and logged in to see this link.] to your Desktop.
  • Double Click the HijackThis icon, located on your Desktop.
  • By Default, it will install to: C:\Program Files\Trend Micro\HijackThis
    It will also create a shortcut on your Desktop.
  • Accept the license agreement.
  • Click Do a System Scan and Save a Logfile.
  • Please post the log in your next reply.
Posts Posts : 14309
Post by gadekm on 8th December 2009, 5:06 am
yippe...I got the hijackthis to work, but it's on the other computer and I can't access any email nor can I get to this web page to post the results :-( any help?
gadekm
Posts Posts : 48
OS OS : Vista
Post by Dr Jay on 8th December 2009, 6:03 am
Please start Internet Explorer, and when the program is open, click on the Tools menu and then select Internet Options.
  • Now click on the Connections tab and then the Lan Settings button
  • Under the Proxy Server section, please uncheck the checkbox labeled Use a proxy server for your LAN. Then press the OK button to close this screen. Then press the Apply button and then the OK button to close the Internet Options screen. Now that you have disabled the proxy server you will be able to browse the web again with Internet Explorer.
Post the HijackThis log when ready.
Posts Posts : 14309
Post by gadekm on 8th December 2009, 4:54 pm
last night nothing would work. I couldn't get the LAN setting to where you advised it kept resetting. I shut down and this morning I restarted avg picked up the antivirus program and I got rid of it through there. Why it didn't do it before?? I ran commy.exe and am including the log here. Let me know what you think...am I healed?
ComboFix 09-12-07.09 - Owner 12/08/2009 10:35.1.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.503.203 [GMT -6:00]
Running from: c:\documents and settings\Owner\Desktop\commy.exe.exe
AV: AVG Anti-Virus Free *On-access scanning enabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
c:\program files\Shared
c:\program files\Shared\lib.sig
c:\recycler\S-1-5-21-763046184-1108015167-220856613-1003
D:\Autorun.inf
Infected copy of c:\windows\system32\DRIVERS\atapi.sys was found and disinfected
Restored copy from - Kitty ate it :p
((((((((((((((((((((((((( Files Created from 2009-11-08 to 2009-12-08 )))))))))))))))))))))))))))))))
2009-12-08 04:56 . 2009-12-08 04:56 -------- d-----w- c:\program files\Trend Micro
2009-12-08 02:55 . 2009-12-08 08:43 3585369 ----a-w- c:\documents and settings\commy.exe.exe
2009-12-08 02:39 . 2008-04-14 01:11 21504 -c--a-w- c:\windows\system32\dllcache\hidserv.dll
2009-12-08 02:39 . 2008-04-14 01:11 21504 ----a-w- c:\windows\system32\hidserv.dll
2009-12-08 02:38 . 2008-04-13 19:45 32128 -c--a-w- c:\windows\system32\dllcache\usbccgp.sys
2009-12-08 02:38 . 2008-04-13 19:45 32128 ----a-w- c:\windows\system32\drivers\usbccgp.sys
2009-12-04 22:47 . 2009-12-08 15:48 -------- d-----w- c:\documents and settings\Owner\Local Settings\Application Data\fxgupx
2009-12-04 19:55 . 2009-12-04 19:55 79488 ----a-w- c:\documents and settings\Owner\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
2009-12-08 16:09 . 2009-09-25 00:08 -------- d-----w- c:\documents and settings\All Users\Application Data\avg8
2009-12-04 22:13 . 2009-04-26 22:23 -------- d-----w- c:\documents and settings\Owner\Application Data\MSN6
2009-12-02 22:41 . 2009-05-31 01:10 6588 ----a-w- c:\documents and settings\Owner\Application Data\wklnhst.dat
2009-12-01 03:13 . 2009-04-27 21:29 -------- d-----w- c:\documents and settings\Owner\Application Data\AdobeUM
2009-09-25 00:08 . 2009-09-25 00:08 11952 ----a-w- c:\windows\system32\avgrsstx.dll
2009-09-25 00:08 . 2009-09-25 00:08 108552 ----a-w- c:\windows\system32\drivers\avgtdix.sys
2009-09-25 00:08 . 2009-09-25 00:08 335240 ----a-w- c:\windows\system32\drivers\avgldx86.sys
2009-09-25 00:08 . 2009-09-25 00:08 27784 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
2009-09-24 22:52 . 2009-04-26 21:04 38112 ----a-w- c:\documents and settings\Owner\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-09-24 22:32 . 2004-08-26 18:03 76487 ----a-w- c:\windows\pchealth\helpctr\OfflineCache\index.dat
2009-09-24 22:30 . 2009-09-24 22:30 73728 ----a-w- c:\windows\ALCFDRTM.EXE
2009-09-11 14:18 . 2004-08-26 16:12 136192 ----a-w- c:\windows\system32\msv1_0.dll
"MsnMsgr"="c:\program files\Windows Live\Messenger\MsnMsgr.Exe" [2009-07-26 3883856]
"SoundMan"="SOUNDMAN.EXE" [2004-08-24 77824]
"AlcWzrd"="ALCWZRD.EXE" [2004-08-24 2552320]
"Recguard"="c:\windows\SMINST\RECGUARD.EXE" [2002-09-13 212992]
"SunKistEM"="c:\program files\eMachines Bay Reader\shwiconem.exe" [2004-03-11 135168]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2004-07-01 155648]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2004-07-01 118784]
"RemoteControl"="c:\program files\CyberLink\PowerDVD\PDVDServ.exe" [2003-11-01 32768]
"QuickCare2.2"="c:\program files\Qwest\QuickCare\bin\sprtcmd.exe" [2007-05-04 198184]
"Microsoft Default Manager"="c:\program files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" [2009-02-03 233304]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2009-02-08 77824]
"AVG8_TRAY"="c:\progra~1\AVG\AVG8\avgtray.exe" [2009-11-26 2029336]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
"c:\\Program Files\\AVG\\AVG8\\avgemc.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgupd.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgnsx.exe"=
R1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [9/24/2009 6:08 PM 335240]
R1 AvgTdiX;AVG Free8 Network Redirector;c:\windows\system32\drivers\avgtdix.sys [9/24/2009 6:08 PM 108552]
R2 avg8emc;AVG Free8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [9/24/2009 6:08 PM 908056]
R2 avg8wd;AVG Free8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [9/24/2009 6:08 PM 297752]
R2 sprtlisten;SupportSoft Listener Service;c:\program files\Common Files\supportsoft\bin\sprtlisten.exe [1/8/2008 11:02 AM 1213728]
uLocal Page = \blank.htm
gadekm
Posts Posts : 48
OS OS : Vista
Post by Dr Jay on 8th December 2009, 11:18 pm
Please run a Full Scan with AVG - and post a log, if available.
Posts Posts : 14309
Post by gadekm on 9th December 2009, 4:18 am
there is no log to post. No infections and some tracking cookies are all it found. So this must mean my machine is clean? AVG must have caught the antivirus virus this morning and cleaned it off. Thank you for being here and I have bookmarked the address. This is great!!! I definately will donate towards a great cause. Thanks for all the time you spend here. Hooray!
gadekm
Posts Posts : 48
OS OS : Vista
Post by Dr Jay on 9th December 2009, 6:11 am
Let us do a final check then I will help you prevent malware in the future.
Posts Posts : 14309
Post by gadekm on 9th December 2009, 4:25 pm
Windows XP Service Pack 3
Antivirus/Firewall Check:
Windows Firewall Enabled!
AVG Free 9.0
HijackThis 2.0.2
Java(TM) 6 Update 13
Out of date Java installed!
Adobe Flash Player 10
Adobe Reader 6.0
Process Check:
objlist.exe by Laurent
AVG avgwdsvc.exe
AVG avgtray.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
AVG avgemc.exe
DNS Vulnerability Check:
gadekm
Posts Posts : 48
OS OS : Vista
Post by gadekm on 9th December 2009, 4:53 pm
I updated Java and Adobe Reader then reran the SecurityCheck and here are the results:
AVG Free 9.0
HijackThis 2.0.2
Java(TM) 6 Update 17
Adobe Reader 9.2
Process Check:
AVG avgwdsvc.exe
AVG avgtray.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
AVG avgemc.exe
Request Timed Out (Wireless Internet connection/Disconnected Internet/Proxy?)
gadekm
Posts Posts : 48
OS OS : Vista
Post by hackrkillr1 on 9th December 2009, 5:21 pm
Moderated Message: Hello, your comment has been removed. Please do not post in another member's topic. If you need help, please read [You must be registered and logged in to see this link.] over and [You must be registered and logged in to see this link.] to open a new topic. ~DragonMaster Jay
Last edited by DragonMaster Jay on 9th December 2009, 9:25 pm; edited 2 times in total
hackrkillr1
Joined Joined : 2009-12-09
Points Points : 25585
Post by Dr Jay on 9th December 2009, 9:26 pm
Software recommendations
Firewall
AntiSpyware
Resident Protection help
Rogue programs help
There are a lot of rogue programs out there that want to scare you into giving them your money and some malware actually claims to be security programs. If you get a popup for a security program that you did not install yourself, do NOT click on it and ask for help immediately. It is very important to run an antivirus and firewall, but you can't always rely on reviews and ads for information. Ask in a security forum that you trust if you are not sure. If you are unsure and looking for anti-spyware programs, you can find out if it is a rogue here: [You must be registered and logged in to see this link.]
Securing your computer
If you are interested:
Posts Posts : 14309
Post by gadekm on 10th December 2009, 12:40 am
no more questions. I will be checking out all the information above. Thank you for your attention and help on this...couldn't have done it without your help. Can't praise you enough. Bow or Thanks
gadekm
Posts Posts : 48
OS OS : Vista
