Antivirus System PRO Removal Problems
Post by Jeff Sheets on Sun 06 Dec 2009, 12:11 pm
Hello, I printed out the instructions for removing the Winsecure2010 Antivirus System PRO. I was able to download the Malwarebytes Anit-Malware and updates but cannot open then from the download folder on the desktop icon or start menu icon. I get a message: Application cannot be executed. File mbam.exe is infected. Do you want to activate your antivirus software now? I click on no. I get this same message with the only difference being the file name. I don't know what to do now. Can someone please help
Jeff Sheets
Operating System : xp
Re: Antivirus System PRO Removal Problems
Post by Belahzur on Sun 06 Dec 2009, 12:43 pm
Link 1
Link 2
  • Double-click on or exeHelper.scr to run the fix.
  • Post the contents of log.txt (Will be created in the directory where you ran
Please download the current version of HijackThis from HERE
Manager | Tech Officer
