Need help with an extremely anoying problem!!!
Post by Elmo253 on Fri Dec 04, 2009 6:04 am
I installed Explorer 8 on my computer. Ever since then, I have been recieving security alerts saying that I have malware, worms, trojans, etc. When i clicked the enable protection button, an install wizard for Antimalware popped up. I let it install (even though I already have McAffee installed) and when it was finished it said that I had to buy the upgrade to get rid of the malware. when I rejected this, porn icons apeared on my desktop. I have tried everyhing I can think of to fix this problem. Can you help me because this is starting to really bug me.
Elmo253
Posts Posts : 6
Joined Joined : 2009-12-04
Points Points : 25632
Re: Need help with an extremely anoying problem!!!
Post by Dr Jay on Fri Dec 04, 2009 11:07 am
Posts Posts : 13717
Points Points : 302127
