wireless connection OK, msn working, web browsing not. Help!
Post by VixyVix on 3rd December 2009, 10:36 pm
Hi there!
I am new to this forum so would be grateful for any help!
I am running Vista
Am using Google Chrome but have also tried IE to see if both have the same problem - they do!
I am connected fine wirelessly to my router and can connect and use windows messenger live with no probs.
However my connection to IE and Google chrome can be sporadic and I find myself rebooting regularly to get a connection, which doesnt stay long.
I have read a couple of other threads which suggest wunning Winsock XP Fix, it comes up with an error though saying
'Registry Import Information not found'
i 'ok' that and it comes up with 'repair complete, please reboot immediately after. However before I do this it comes up with 'Run time error 53. File not found' I have rebooted but still have the problem
I have also tried the CMD prompt suggested in another thread but it says it needs 'elevation' or something like that
If someone could help with this I would be grateful!
Oh, I also run zonealarm and SpyDoctor however this was happening before I loaded spydoctor.
Many thanks
Victoria
VixyVix
Posts Posts : 4
Joined Joined : 2009-12-03
OS OS : Vista
Points Points : 25653
Re: wireless connection OK, msn working, web browsing not. Help!
Post by Doctor Inferno on 4th December 2009, 3:04 am
Install this to reset your TCP/IP:
http://go.microsoft.com/?linkid=9664547
See if it works.
Post by VixyVix on 8th December 2009, 6:46 pm
Hi again,
Thank you for that....
It seemed to work ok for the first few hours (maybe coincidence?) and is back to normal now... msn ok but cannot display pages on chrome or IE...
Anything else you could suggest?
VixyVix
Posts Posts : 4
OS OS : Vista
Post by tishanavin on 8th December 2009, 9:48 pm
I have seen this about the Zone Alarm- an update that it did caused problems, since I do not use it- I cannot speak for myself but have heard that some update or new download affiliated with that program caused internet to go haywire.
tishanavin
Posts Posts : 10
Joined Joined : 2009-12-07
Points Points : 25717
Post by Doctor Inferno on 9th December 2009, 3:02 am
Please download RenewMyDNS by DragonMaster Jay.
  • Right-click on the file and select Extract All...
  • Choose a location to save extracted files and keep pressing Next until Finish.
  • Double-click RenewMyDNS folder, then double-click RenewMyDNS.bat to start the program.
  • Follow the prompts, and when finished it will launch a log.
  • Post that log in your next reply.
  • After posting the log, delete the folder RenewMyDNS.
Download a zip file with the patch,
registry file, and instructions by going here:
http://www.ausconnect.net/files/sp2connectivityfix.zip
1) Download the patch from Microsoft's site
2) Run the update to install it
3)
Run this short Registry fix to complete the update. Type the following
lines in Notepad and save the file as FixReg.reg on your desktop, then
double click on it to install into your registry.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\IPSec]
"AssumeUDPEncapsulationContextOnSendRule"=dword:00000002
4) Reboot your computer
If
you experience the error message again, reboot your computer first. In
most cases this will solve many connectivity issues that are not
associated with this SP2 bug.
Microsoft patch (KB884020):
http://www.microsoft.com/downloads/details.aspx?FamilyID=17d997d2-5034-4bbb-b74d-ad8430a1f7c8&DisplayLang=en
Post by VixyVix on 9th December 2009, 8:06 am
Here is the log... I will now try the second part of your reply. Thank you for your help....
DNS Diagnostics and refresher
Version 0.1.4 - November 2009
Microsoft Windows [Version 6.0.6002]
(((((((((((((((((((( Network and DNS Information ))))))))))))))))))))
Windows IP Configuration
Host Name . . . . . . . . . . . . : Vix-laptop
DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection
Physical Address. . . . . . . . . : 00-1C-BF-8D-F2-0B
DHCP Enabled. . . . . . . . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.64(Preferred)
Lease Obtained. . . . . . . . . . : 08 December 2009 22:42:56
Lease Expires . . . . . . . . . . : 09 December 2009 22:46:36
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Description . . . . . . . . . . . : Realtek RTL8101E Family PCI-E Fast Ethernet NIC (NDIS 6.0)
Physical Address. . . . . . . . . : 00-1B-38-B4-C4-87
(((((((((((((((((((( DNS-Fake Request Testing and Flush ))))))))))))))))))))
... Requests made were successful
The requested operation requires elevation.
(((((((((((((((((((( Speed-test - Ping ))))))))))))))))))))
Pinging yahoo.com [209.131.36.159] with 32 bytes of data:
Reply from 209.131.36.159: bytes=32 time=215ms TTL=54
Reply from 209.131.36.159: bytes=32 time=190ms TTL=54
Reply from 209.131.36.159: bytes=32 time=189ms TTL=54
Reply from 209.131.36.159: bytes=32 time=197ms TTL=54
Ping statistics for 209.131.36.159:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 189ms, Maximum = 215ms, Average = 197ms
Pinging geekpolice.net [74.86.239.78] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 74.86.239.78:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Pinging facebook.com [69.63.181.12] with 32 bytes of data:
Reply from 69.63.181.12: bytes=32 time=214ms TTL=246
Reply from 69.63.181.12: bytes=32 time=194ms TTL=246
Reply from 69.63.181.12: bytes=32 time=196ms TTL=246
Ping statistics for 69.63.181.12:
Minimum = 194ms, Maximum = 214ms, Average = 199ms
Pinging microsoft.com [207.46.197.32] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 207.46.197.32:
EOF
VixyVix
Posts Posts : 4
OS OS : Vista
Post by VixyVix on 9th December 2009, 8:34 am
Hi again, I tried to install the patch but it says it doesnt work with the version of windows I have installed (it seems that one is for XP when I have Vista)
If Zonealarm is a possible problem, can you suggest an alternative firewall that is free that I could install instead?
VixyVix
Posts Posts : 4
OS OS : Vista
Post by Doctor Inferno on 9th December 2009, 9:24 am
You can use Outpost as an alternative:
http://free.agnitum.com/
