Antivirus System Pro Removal with Hijack This info
Post by ghoticov on 3rd December 2009, 6:17 pm
I am looking for help to remove this stubborn virus from my laptop. I have installed and ran Malwarebytes' in safe mode with networking and it found many files and deleted them. After I reboot, the stubborn virus is still there (with pop ups, etc). I finally read a post where I could right click on the task bar and open my task manager before the virus loads and delete the file from starting... that seemed to work but I know as soon as I reboot, it will probably be back.
So as of now, I was able to open Malwarebytes' in normal mode and when I tried to run an update, I get an Error Code: 732 (0,0) and says I should report it to the Malwarebytes' support team (so here I am to report it) Smile
I finally got HiJackThis to work and here is the log, thank you for your help!
Scan saved at 10:11:42 AM, on 12/3/2009
Platform: Windows Vista SP2 (WinNT 6.00.1906)
MSIE: Internet Explorer v8.00 (8.00.6001.18828)
C:\Program Files (x86)\HP\HP Software Update\hpwuSchd2.exe
C:\Program Files (x86)\HP\Digital Imaging\bin\HpqSRmon.exe
C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Distillr\acrotray.exe
C:\Program Files (x86)\Mozilla Firefox\firefox.exe
C:\Users\Marc\Desktop\winlogon.scr
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
O1 - Hosts: ::1 localhost
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Symantec NCO BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\coIEPlg.dll
O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\IPSBHO.DLL
O2 - BHO: Tunebite_WebRipPlugin Class - {AA102584-3B97-47e7-B9BC-75D54C110A7D} - C:\Program Files (x86)\RapidSolution\Tunebite\plugins\IE\TB_WebRipIePlugin.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O2 - BHO: Microsoft Live Search Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - c:\Program Files (x86)\MSN\Toolbar\3.0.0541.0\msneshellx.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
O2 - BHO: HP Smart BHO Class - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O3 - Toolbar: Microsoft Live Search Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - c:\Program Files (x86)\MSN\Toolbar\3.0.0541.0\msneshellx.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: Norton Toolbar - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\coIEPlg.dll
O4 - HKLM\..\Run: [UCam_Menu] "C:\Program Files (x86)\Hewlett-Packard\Media\Webcam\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\Hewlett-Packard\Media\Webcam" update "Software\Hewlett-Packard\Media\Webcam"
O4 - HKLM\..\Run: [UpdateLBPShortCut] "C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\LabelPrint" UpdateWithCreateOnce "Software\CyberLink\LabelPrint\2.5"
O4 - HKLM\..\Run: [UpdatePSTShortCut] "C:\Program Files (x86)\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\DVD Suite" UpdateWithCreateOnce "Software\CyberLink\PowerStarter"
O4 - HKLM\..\Run: [UpdateP2GoShortCut] "C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\Power2Go" UpdateWithCreateOnce "SOFTWARE\CyberLink\Power2Go\6.0"
O4 - HKLM\..\Run: [UpdatePDIRShortCut] "C:\Program Files (x86)\CyberLink\PowerDirector\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\PowerDirector" UpdateWithCreateOnce "SOFTWARE\CyberLink\PowerDirector\7.0"
O4 - HKLM\..\Run: [Adobe Version Cue CS2] C:\Adobe Creative Suite2\Adobe Version Cue CS2\ControlPanel\VersionCueCS2Tray.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [hpqSRMon] C:\Program Files (x86)\HP\Digital Imaging\bin\hpqSRMon.exe
O4 - HKLM\..\Run: [Acrobat Assistant 7.0] "C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Distillr\Acrotray.exe"
O4 - HKLM\..\Run: [HP Health Check Scheduler] c:\Program Files (x86)\Hewlett-Packard\HP Health Check\HPHC_Scheduler.exe
O4 - HKLM\..\Run: [CarboniteSetupLite] "C:\Program Files (x86)\Carbonite\CarbonitePreinstaller.exe" /preinstalled /showonfirst /reshowat=1800
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] "C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamgui.exe" /install /silent
O4 - HKCU\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~2\MYWEBS~1\bar\1.bin\mwsoemon.exe
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files (x86)\Windows Media Player\WMPNSCFG.exe
O4 - HKCU\..\Run: [wioewcgr] C:\Users\Marc\AppData\Local\poibar\udnisysguard.exe
O4 - HKCU\..\Run: [wiprxrrj] C:\Users\Marc\AppData\Local\oxpund\udensysguard.exe
O4 - HKCU\..\Run: [vipfxgdb] C:\Users\Marc\AppData\Local\mhwnbo\ucussysguard.exe
O8 - Extra context menu item: Convert link target to Adobe PDF - [You must be registered and logged in to see this link.] Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - [You must be registered and logged in to see this link.] Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - [You must be registered and logged in to see this link.] Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - [You must be registered and logged in to see this link.] Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - [You must be registered and logged in to see this link.] Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - [You must be registered and logged in to see this link.] Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - [You must be registered and logged in to see this link.] Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert to existing PDF - [You must be registered and logged in to see this link.] Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~2\Office12\REFIEBAR.DLL
O9 - Extra button: HP Smart Select - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O13 - Gopher Prefix:
O18 - Protocol: symres - {AA1061FE-6C41-421F-9344-69640C9732AB} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\coIEPlg.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files (x86)\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Adobe Version Cue CS2 - Adobe Systems Incorporated - C:\Adobe Creative Suite2\Adobe Version Cue CS2\bin\VersionCueCS2.exe
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Unknown owner - C:\Windows\system32\agr64svc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
O23 - Service: Com4QLBEx - Hewlett-Packard Development Company, L.P. - C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch Buttons\Com4QLBEx.exe
O23 - Service: @dfsrres.dll,-101 (DFSR) - Unknown owner - C:\Windows\system32\DFSR.exe (file missing)
O23 - Service: GameConsoleService - WildTangent, Inc. - C:\Program Files (x86)\HP Games\My HP Game Console\GameConsoleService.exe
O23 - Service: HP Health Check Service - Hewlett-Packard - c:\Program Files (x86)\Hewlett-Packard\HP Health Check\hphc_service.exe
O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files (x86)\Hewlett-Packard\Shared\hpqwmiex.exe
O23 - Service: HP Service (hpsrv) - Unknown owner - C:\Windows\system32\Hpservice.exe (file missing)
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files (x86)\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files (x86)\iPod\bin\iPodService.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: My Web Search Service (MyWebSearchService) - Unknown owner - C:\PROGRA~2\MYWEBS~1\bar\1.bin\mwssvc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Norton Internet Security - Symantec Corporation - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\ccSvcHst.exe
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Recovery Service for Windows - Unknown owner - C:\Program Files (x86)\SMINST\BLService.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\SLsvc.exe,-101 (slsvc) - Unknown owner - C:\Windows\system32\SLsvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: TV Background Capture Service (TVBCS) (TVCapSvc) - Unknown owner - C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVCapSvc.exe
O23 - Service: TV Task Scheduler (TVTS) (TVSched) - Unknown owner - C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVSched.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
End of file - 12823 bytes
ghoticov
Posts Posts : 13
Joined Joined : 2009-12-02
OS OS : Vista
Points Points : 25819
Re: Antivirus System Pro Removal with Hijack This info
Post by DjDan999 on 3rd December 2009, 6:31 pm
Hmmm, I didn't use Hijack this to get rid of it. When I booted up I hit Ctrl+Alt+Dlt as soon as it booted up. And then I found the name of the exe in the processes tab. Then you should be able to open IE and the internet will work again. This allows MB to download the update and remove it with a quick scan Smile
Hope that helps. I had it last weekend.
DjDan999
Posts Posts : 6
Joined Joined : 2009-12-03
Points Points : 25718
Post by ghoticov on 3rd December 2009, 6:33 pm
I was able to quit the process so I am not getting any pop ups at the moment but I still cannot update Malwarebytes, it keeps give me the Error Code. I am running a full system scan now and it did find one item when I did the quick scan but I have a feeling the virus will be back if I reboot.
ghoticov
Posts Posts : 13
OS OS : Vista
Post by DjDan999 on 3rd December 2009, 6:35 pm
Hmm, well for me I couldn't open any exe files. But I could access the internet to update Malwarebytes...I think I did have to reboot though for it to update. Try rebooting and as soon as it boots end the process then try it. as fast as possible. Best advice I can give really :/ I'm not amazing with computers so sorry if this doesn't help! Sad tearing
DjDan999
Posts Posts : 6
Post by ghoticov on 3rd December 2009, 6:36 pm
No problem, thanks for the help! I will try anything at this point. HA!
ghoticov
Posts Posts : 13
OS OS : Vista
Post by Belahzur on 3rd December 2009, 9:01 pm
    In Internet Explorer
    In Firefox
    O4 - HKCU\..\Run: [vipfxgdb] C:\Users\Marc\AppData\Local\mhwnbo\ucussysguard.exeO23 - Service: My Web Search Service (MyWebSearchService) - Unknown owner - C:\PROGRA~2\MYWEBS~1\bar\1.bin\mwssvc.exe (file missing)
Points Points : 245111
Post by ghoticov on 3rd December 2009, 10:30 pm
I did not see the following files to check in the HiJackThis part:
ghoticov
Posts Posts : 13
OS OS : Vista
Post by ghoticov on 3rd December 2009, 10:55 pm
Here is the Malwarebytes' Log:
Malwarebytes' Anti-Malware 1.42
Database version: 3289
Windows 6.0.6002 Service Pack 2
Internet Explorer 8.0.6001.18828
12/3/2009 2:55:27 PM
mbam-log-2009-12-03 (14-55-27).txt
Objects scanned: 98584
Time elapsed: 6 minute(s), 35 second(s)
Registry Keys Infected: 3
Files Infected: 1
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Users\Marc\downloads\winlogon.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
ghoticov
Posts Posts : 13
OS OS : Vista
Post by ghoticov on 3rd December 2009, 11:41 pm
My system is running good now so I think its all gone but I really have no idea how to know for sure. lol
ghoticov
Posts Posts : 13
OS OS : Vista
Post by Belahzur on 4th December 2009, 1:21 am
Post by ghoticov on 4th December 2009, 1:26 am
[You must be registered and logged in to see this link.] wrote:Download [You must be registered and logged in to see this link.] by OldTimer to your Desktop.
Is this to me or the other poster?
ghoticov
Posts Posts : 13
OS OS : Vista
Post by ghoticov on 4th December 2009, 1:37 am
Here is the OTL.Txt
OTL logfile created on: 12/3/2009 5:27:55 PM - Run 1
OTL by OldTimer - Version 3.1.11.4 Folder = C:\Users\Marc\Desktop
64bit-Windows Vista Home Premium Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
Internet Explorer (Version = 8.0.6001.18828)
3.90 Gb Total Physical Memory | 2.53 Gb Available Physical Memory | 64.88% Memory free
4.00 Gb Paging File | 4.00 Gb Available in Paging File | 100.00% Paging File free
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
Drive C: | 285.62 Gb Total Space | 171.62 Gb Free Space | 60.09% Space Free | Partition Type: NTFS
Drive D: | 12.47 Gb Total Space | 1.98 Gb Free Space | 15.84% Space Free | Partition Type: NTFS
Drive F: | 465.65 Gb Total Space | 431.31 Gb Free Space | 92.63% Space Free | Partition Type: FAT32
Computer Name: MARC-PC
Current User Name: Marc
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Include 64bit Scans
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2009/12/03 17:27:04 | 00,535,552 | ---- | M] (OldTimer Tools) -- C:\Users\Marc\Desktop\OTL.exe
PRC - [2009/11/06 14:29:03 | 00,908,248 | ---- | M] (Mozilla Corporation) -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe
PRC - [2009/10/11 04:17:36 | 00,149,280 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files (x86)\Java\jre6\bin\jusched.exe
PRC - [2009/08/21 23:28:17 | 00,117,640 | R--- | M] (Symantec Corporation) -- C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\ccSvcHst.exe
PRC - [2008/11/07 11:28:16 | 00,132,424 | ---- | M] (Apple Inc.) -- C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
PRC - [2008/09/24 18:08:26 | 00,296,320 | ---- | M] () -- C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVCapSvc.exe
PRC - [2008/09/24 18:08:26 | 00,116,096 | ---- | M] () -- C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVSched.exe
PRC - [2008/09/23 11:18:52 | 00,365,904 | ---- | M] () -- C:\Program Files (x86)\SMINST\BLService.exe
PRC - [2008/08/29 07:18:44 | 00,238,888 | ---- | M] (Apple Inc.) -- C:\Program Files (x86)\Bonjour\mDNSResponder.exe
PRC - [2008/06/29 15:10:18 | 00,241,734 | ---- | M] () -- C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe
PRC - [2008/06/09 10:21:58 | 00,073,728 | ---- | M] (Hewlett-Packard Company) -- C:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe
PRC - [2008/04/23 01:08:13 | 00,483,328 | ---- | M] (Adobe Systems Inc.) -- C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Distillr\acrotray.exe
PRC - [2007/10/14 20:17:32 | 00,049,152 | ---- | M] (Hewlett-Packard) -- C:\Program Files (x86)\HP\HP Software Update\hpwuSchd2.exe
PRC - [2007/08/22 15:31:16 | 00,080,896 | ---- | M] (Hewlett-Packard) -- C:\Program Files (x86)\HP\Digital Imaging\bin\HpqSRmon.exe
PRC - [2005/04/04 15:58:30 | 03,502,080 | ---- | M] () -- C:\Adobe Creative Suite2\Adobe Version Cue CS2\data\database\bin\mysqld-nt.exe
PRC - [2005/04/04 15:58:28 | 00,163,840 | ---- | M] (Adobe Systems Incorporated) -- C:\Adobe Creative Suite2\Adobe Version Cue CS2\bin\VersionCueCS2.exe
MOD - [2009/12/03 17:27:04 | 00,535,552 | ---- | M] (OldTimer Tools) -- C:\Users\Marc\Desktop\OTL.exe
SRV:64bit: - [2009/09/24 17:26:26 | 01,142,272 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysNative\FntCache.dll -- (FontCache)
SRV:64bit: - [2008/03/18 16:25:40 | 00,023,040 | ---- | M] (Hewlett-Packard Corporation) -- C:\Windows\SysNative\Hpservice.exe -- (hpsrv)
SRV:64bit: - [2008/01/20 18:47:32 | 00,383,544 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Defender\MpSvc.dll -- (WinDefend)
SRV:64bit: - [2007/12/11 12:11:30 | 00,015,872 | ---- | M] (Agere Systems) -- C:\Windows\SysNative\agr64svc.exe -- (AgereModemAudio)
SRV - [2009/08/21 23:28:17 | 00,117,640 | R--- | M] (Symantec Corporation) -- C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\ccSvcHst.exe -- (Norton Internet Security)
SRV - [2009/03/29 20:39:54 | 00,089,920 | ---- | M] (Microsoft Corporation) -- C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorsvw.exe -- (clr_optimization_v2.0.50727_64)
SRV - [2009/01/26 17:55:21 | 00,072,704 | ---- | M] (Adobe Systems) -- C:\Program Files (x86)\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe -- (Adobe LM Service)
SRV - [2009/01/06 10:06:24 | 00,536,872 | ---- | M] (Apple Inc.) -- C:\Program Files (x86)\iPod\bin\iPodService.exe -- (iPod Service)
SRV - [2008/11/07 11:28:16 | 00,132,424 | ---- | M] (Apple Inc.) -- C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe -- (Apple Mobile Device)
SRV - [2008/10/09 06:56:48 | 00,094,208 | ---- | M] (Hewlett-Packard) -- c:\Program Files (x86)\Hewlett-Packard\HP Health Check\hphc_service.exe -- (HP Health Check Service)
SRV - [2008/09/24 18:08:26 | 00,296,320 | ---- | M] () -- C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVCapSvc.exe -- (TVCapSvc) TV Background Capture Service (TVBCS)
SRV - [2008/09/24 18:08:26 | 00,116,096 | ---- | M] () -- C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVSched.exe -- (TVSched) TV Task Scheduler (TVTS)
SRV - [2008/09/23 11:18:52 | 00,365,904 | ---- | M] () -- C:\Program Files (x86)\SMINST\BLService.exe -- (Recovery Service for Windows)
SRV - [2008/08/29 07:18:44 | 00,238,888 | ---- | M] (Apple Inc.) -- C:\Program Files (x86)\Bonjour\mDNSResponder.exe -- (Bonjour Service)
SRV - [2008/06/29 15:10:18 | 00,241,734 | ---- | M] () -- C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe -- (RichVideo) Cyberlink RichVideo Service(CRVS)
SRV - [2008/06/09 10:21:58 | 00,073,728 | ---- | M] (Hewlett-Packard Company) -- C:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe -- (LightScribeService)
SRV - [2008/05/05 14:25:46 | 00,165,416 | ---- | M] (WildTangent, Inc.) -- C:\Program Files (x86)\HP Games\My HP Game Console\GameConsoleService.exe -- (GameConsoleService)
SRV - [2008/05/01 15:25:56 | 00,165,192 | ---- | M] (Hewlett-Packard Development Company, L.P.) -- C:\Program Files (x86)\Hewlett-Packard\Shared\hpqwmiex.exe -- (hpqwmiex)
SRV - [2008/04/03 10:33:26 | 00,193,840 | ---- | M] (Hewlett-Packard Development Company, L.P.) -- C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch Buttons\Com4QLBEx.exe -- (Com4QLBEx)
SRV - [2008/03/07 15:04:10 | 00,217,088 | ---- | M] (Hewlett-Packard Co.) -- C:\Program Files (x86)\HP\Digital Imaging\bin\hpqcxs08.dll -- (hpqcxs08)
SRV - [2007/11/06 20:16:54 | 00,139,264 | ---- | M] (Hewlett-Packard Co.) -- C:\Program Files (x86)\HP\Digital Imaging\bin\hpqddsvc.dll -- (hpqddsvc)
SRV - [2007/10/14 20:15:16 | 00,963,072 | ---- | M] (Hewlett-Packard Co.) -- C:\Program Files (x86)\HP\Digital Imaging\bin\HPSLPSVC64.DLL -- (HPSLPSVC)
SRV - [2006/11/02 05:34:14 | 00,000,000 | ---D | M] -- C:\Windows\SysWOW64\Msdtc -- (MSDTC)
SRV - [2006/11/01 22:35:15 | 00,060,994 | ---- | M] () -- C:\Windows\SysWOW64\wbem\vds.mof -- (vds)
SRV - [2006/11/01 22:35:15 | 00,055,846 | ---- | M] () -- C:\Windows\SysWOW64\wbem\vss.mof -- (VSS)
SRV - [2005/04/04 15:58:28 | 00,163,840 | ---- | M] (Adobe Systems Incorporated) -- C:\Adobe Creative Suite2\Adobe Version Cue CS2\bin\VersionCueCS2.exe -- (Adobe Version Cue CS2)
SRV - [2004/10/22 02:24:18 | 00,073,728 | ---- | M] (Macrovision Corporation) -- C:\Program Files (x86)\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe -- (IDriverT)
DRV:64bit: - [2009/09/08 14:04:23 | 00,583,296 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\Drivers\NISx64\1007020.00B\ccHPx64.sys -- (ccHP)
DRV:64bit: - [2009/08/21 23:28:17 | 00,476,720 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\Drivers\NISx64\1007020.00B\SRTSP64.SYS -- (SRTSP)
DRV:64bit: - [2009/08/21 23:28:17 | 00,402,992 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\drivers\NISx64\1007020.00B\SYMEFA64.SYS -- (SymEFA)
DRV:64bit: - [2009/08/21 23:28:17 | 00,334,384 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\Drivers\NISx64\1007020.00B\BHDrvx64.sys -- (BHDrvx64)
DRV:64bit: - [2009/08/21 23:28:17 | 00,278,576 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\Drivers\NISx64\1007020.00B\SYMTDI.SYS -- (SYMTDI)
DRV:64bit: - [2009/08/21 23:28:17 | 00,120,880 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\Drivers\NISx64\1007020.00B\SYMFW.SYS -- (SYMFW)
DRV:64bit: - [2009/08/21 23:28:17 | 00,056,880 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\Drivers\NISx64\1007020.00B\SYMNDISV.SYS -- (SYMNDISV)
DRV:64bit: - [2009/08/21 23:28:17 | 00,032,304 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\drivers\NISx64\1007020.00B\SRTSPX64.SYS -- (SRTSPX) Symantec Real Time Storage Protection (PEL)
DRV:64bit: - [2009/08/20 08:19:49 | 00,172,592 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\Drivers\SYMEVENT64x86.SYS -- (SymEvent)
DRV:64bit: - [2009/08/18 11:11:43 | 00,031,280 | R--- | M] (Symantec Corporation) -- C:\Windows\SysNative\DRIVERS\SymIMv.sys -- (SymIM)
DRV:64bit: - [2009/06/09 17:15:54 | 00,046,112 | ---- | M] (RapidSolution Software AG) -- C:\Windows\SysNative\drivers\tbhsd.sys -- (tbhsd)
DRV:64bit: - [2009/05/21 14:24:28 | 00,030,736 | ---- | M] (Windows (R) Codename Longhorn DDK provider) -- C:\Windows\SysNative\drivers\lmvac.sys -- (LTXMD_VAC) Litex Media Virtual Audio Cable (WDM)
DRV:64bit: - [2009/04/10 21:39:51 | 00,275,456 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysNative\drivers\HdAudio.sys -- (HdAudAddService)
DRV:64bit: - [2008/12/10 00:16:43 | 01,522,168 | ---- | M] (Broadcom Corporation) -- C:\Windows\SysNative\DRIVERS\bcmwl664.sys -- (BCM43XX)
DRV:64bit: - [2008/09/19 17:43:58 | 00,068,096 | ---- | M] (Realtek Semiconductor Corp.) -- C:\Windows\SysNative\drivers\RTSTOR64.SYS -- (RTSTOR)
DRV:64bit: - [2008/09/04 09:48:00 | 00,064,000 | ---- | M] (ENE TECHNOLOGY INC.) -- C:\Windows\SysNative\DRIVERS\enecir.sys -- (enecir)
DRV:64bit: - [2008/08/14 02:18:54 | 08,029,792 | ---- | M] (Intel Corporation) -- C:\Windows\SysNative\DRIVERS\igdkmd64.sys -- (igfx)
DRV:64bit: - [2008/08/06 08:26:08 | 00,174,592 | ---- | M] (Realtek Corporation ) -- C:\Windows\SysNative\DRIVERS\Rtlh64.sys -- (RTL8169)
DRV:64bit: - [2008/07/15 00:20:42 | 00,126,464 | ---- | M] (Intel(R) Corporation) -- C:\Windows\SysNative\drivers\IntcHdmi.sys -- (IntcHdmiAddService) Intel(R)
DRV:64bit: - [2008/06/19 17:37:42 | 00,325,680 | ---- | M] (Synaptics, Inc.) -- C:\Windows\SysNative\DRIVERS\SynTP.sys -- (SynTP)
DRV:64bit: - [2008/04/17 10:12:54 | 00,019,304 | ---- | M] (GEAR Software Inc.) -- C:\Windows\SysNative\DRIVERS\GEARAspiWDM.sys -- (GEARAspiWDM)
DRV:64bit: - [2008/03/27 12:10:56 | 00,026,984 | ---- | M] (Hewlett-Packard Corporation) -- C:\Windows\SysNative\DRIVERS\hpdskflt.sys -- (hpdskflt)
DRV:64bit: - [2008/03/27 12:10:14 | 00,040,296 | ---- | M] (Hewlett-Packard Corporation) -- C:\Windows\SysNative\DRIVERS\Accelerometer.sys -- (Accelerometer)
DRV:64bit: - [2008/01/20 18:47:27 | 00,168,704 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysNative\Drivers\usbvideo.sys -- (usbvideo) USB Video Device (WDM)
DRV:64bit: - [2008/01/20 18:47:25 | 00,012,288 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysNative\DRIVERS\serscan.sys -- (StillCam)
DRV:64bit: - [2008/01/20 18:46:57 | 03,154,432 | ---- | M] (Intel Corporation) -- C:\Windows\SysNative\DRIVERS\NETw3v64.sys -- (NETw3v64) Intel(R)
DRV:64bit: - [2008/01/20 18:46:55 | 00,111,104 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysNative\DRIVERS\sdbus.sys -- (sdbus)
DRV:64bit: - [2008/01/20 18:46:51 | 00,017,792 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysNative\DRIVERS\CmBatt.sys -- (CmBatt)
DRV:64bit: - [2007/06/18 16:13:12 | 00,018,432 | ---- | M] (Hewlett-Packard Development Company, L.P.) -- C:\Windows\SysNative\DRIVERS\HpqKbFiltr.sys -- (HpqKbFiltr)
DRV:64bit: - [2006/10/03 17:45:36 | 00,273,408 | ---- | M] (Marvell) -- C:\Windows\SysNative\DRIVERS\yk60x64.sys -- (yukonx64)
DRV:64bit: - [2006/09/18 13:38:10 | 01,074,688 | ---- | M] (Agere Systems) -- C:\Windows\SysNative\DRIVERS\agrsm64.sys -- (AgereSoftModem)
DRV - [2009/10/28 14:37:21 | 00,466,992 | ---- | M] (Symantec Corporation) -- C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20091111.001\IDSviA64.sys -- (IDSVia64)
DRV - [2009/08/26 00:00:00 | 00,475,696 | ---- | M] (Symantec Corporation) -- C:\Program Files (x86)\Common Files\Symantec Shared\EENGINE\eeCtrl64.sys -- (eeCtrl)
DRV - [2009/08/26 00:00:00 | 00,132,656 | ---- | M] (Symantec Corporation) -- C:\Program Files (x86)\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys -- (EraserUtilRebootDrv)
DRV - [2009/08/25 00:00:00 | 01,742,896 | ---- | M] (Symantec Corporation) -- C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20091203.004\EX64.SYS -- (NAVEX15)
DRV - [2009/08/25 00:00:00 | 00,116,272 | ---- | M] (Symantec Corporation) -- C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20091203.004\ENG64.SYS -- (NAVENG)
DRV - [2008/09/26 02:36:34 | 00,027,632 | ---- | M] (Cyberlink Corp.) -- C:\Program Files (x86)\Hewlett-Packard\Media\DVD\000.fcl -- ({55662437-DA8C-40c0-AADA-2C816A897A49})
DRV - [2006/09/18 13:36:40 | 00,003,066 | ---- | M] () -- C:\Windows\SysWOW64\wbem\tcpip.mof -- (Tcpip)
DRV - [2006/09/18 13:35:23 | 00,001,088 | ---- | M] () -- C:\Windows\SysWOW64\wbem\mpsdrv.mof -- (mpsdrv)
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = [You must be registered and logged in to see this link.]
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,StartPageCache = 1
========== FireFox ==========
FF - prefs.js..browser.startup.homepage: "[You must be registered and logged in to see this link.]
FF - HKLM\software\mozilla\Firefox\Extensions\\smartwebprinting@hp.com: C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\MozillaAddOn2 [2008/10/18 15:46:21 | 00,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\tunebite-firefox-surf-and-catch-extension@audials.com: C:\Program Files (x86)\RapidSolution\Tunebite\plugins\GeckoBased\tunebite-firefox-surf-and-catch-extension@audials.com\ [2009/06/20 20:10:43 | 00,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.5\extensions\\Components: C:\Program Files (x86)\Mozilla Firefox\components [2009/11/06 14:29:05 | 00,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.5\extensions\\Plugins: C:\Program Files (x86)\Mozilla Firefox\plugins [2009/11/06 14:29:05 | 00,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Thunderbird 2.0.0.23\extensions\\Components: C:\Program Files (x86)\Mozilla Thunderbird\components [2009/08/24 16:50:29 | 00,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Thunderbird 2.0.0.23\extensions\\Plugins: C:\Program Files (x86)\Mozilla Thunderbird\plugins
[2009/01/24 12:11:22 | 00,000,000 | ---D | M] -- C:\Users\Marc\AppData\Roaming\Mozilla\Extensions
[2009/12/03 09:14:38 | 00,000,000 | ---D | M] -- C:\Users\Marc\AppData\Roaming\Mozilla\Firefox\Profiles\fuyna9v6.default\extensions
[2009/03/28 17:20:15 | 00,000,000 | ---D | M] -- C:\Users\Marc\AppData\Roaming\Mozilla\Firefox\Profiles\fuyna9v6.default\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
[2009/12/03 14:58:35 | 00,000,000 | ---D | M] -- C:\Program Files (x86)\Mozilla Firefox\extensions
O1 HOSTS File: (761 bytes) - C:\Windows\SysNative\drivers\etc\Hosts
O2 - BHO: (AcroIEHlprObj Class) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\ActiveX\AcroIEHelper.dll (Adobe Systems Incorporated)
O2 - BHO: (Adobe PDF Link Helper) - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll (Adobe Systems Incorporated)
O2 - BHO: (Symantec NCO BHO) - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\CoIEPlg.dll (Symantec Corporation)
O2 - BHO: (Symantec Intrusion Prevention) - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\IPSBHO.dll (Symantec Corporation)
O2 - BHO: (Tunebite_WebRipPlugin Class) - {AA102584-3B97-47e7-B9BC-75D54C110A7D} - C:\Program Files (x86)\RapidSolution\Tunebite\plugins\IE\TB_WebRipIePlugin.dll (RapidSolution Software)
O2 - BHO: (Adobe PDF Conversion Toolbar Helper) - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O2 - BHO: (Microsoft Live Search Toolbar Helper) - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - c:\Program Files (x86)\MSN\Toolbar\3.0.0541.0\msneshellx.dll (Microsoft Corp.)
O2 - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
O2 - BHO: (HP Smart BHO Class) - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll (Hewlett-Packard Co.)
O3 - HKLM\..\Toolbar: (Microsoft Live Search Toolbar) - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - c:\Program Files (x86)\MSN\Toolbar\3.0.0541.0\msneshellx.dll (Microsoft Corp.)
O3 - HKLM\..\Toolbar: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKLM\..\Toolbar: (Norton Toolbar) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\CoIEPlg.dll (Symantec Corporation)
O3 - HKCU\..\Toolbar\WebBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKCU\..\Toolbar\WebBrowser: (Norton Toolbar) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\CoIEPlg.dll (Symantec Corporation)
O4:64bit: - HKLM..\Run: [HotKeysCmds] C:\Windows\SysNative\hkcmd.exe (Intel Corporation)
O4:64bit: - HKLM..\Run: [IgfxTray] C:\Windows\SysNative\igfxtray.exe (Intel Corporation)
O4:64bit: - HKLM..\Run: [Persistence] C:\Windows\SysNative\igfxpers.exe (Intel Corporation)
O4:64bit: - HKLM..\Run: [Windows Defender] C:\Program Files\Windows Defender\MSASCui.exe (Microsoft Corporation)
O4 - HKLM..\Run: [] File not found
O4 - HKLM..\Run: [Acrobat Assistant 7.0] C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Distillr\Acrotray.exe (Adobe Systems Inc.)
O4 - HKLM..\Run: [Adobe Version Cue CS2] C:\Adobe Creative Suite2\Adobe Version Cue CS2\ControlPanel\VersionCueCS2Tray.exe (Adobe Sytems Incorporated)
O4 - HKLM..\Run: [CarboniteSetupLite] C:\Program Files (x86)\Carbonite\CarbonitePreinstaller.exe (Carbonite, Inc.)
O4 - HKLM..\Run: [HP Health Check Scheduler] c:\Program Files (x86)\Hewlett-Packard\HP Health Check\HPHC_Scheduler.exe (Hewlett-Packard)
O4 - HKLM..\Run: [HP Software Update] C:\Program Files (x86)\HP\HP Software Update\hpwuSchd2.exe (Hewlett-Packard)
O4 - HKLM..\Run: [hpqSRMon] C:\Program Files (x86)\HP\Digital Imaging\bin\HpqSRmon.exe (Hewlett-Packard)
O4 - HKLM..\Run: [Malwarebytes Anti-Malware (reboot)] C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbam.exe (Malwarebytes Corporation)
O4 - HKLM..\Run: [SunJavaUpdateSched] C:\Program Files (x86)\Java\jre6\bin\jusched.exe (Sun Microsystems, Inc.)
O4 - HKLM..\Run: [UCam_Menu] C:\Program Files (x86)\Hewlett-Packard\Media\Webcam\MUITransfer\MUIStartMenu.exe (CyberLink Corp.)
O4 - HKLM..\Run: [UpdateLBPShortCut] C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe (CyberLink Corp.)
O4 - HKLM..\Run: [UpdateP2GoShortCut] C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe (CyberLink Corp.)
O4 - HKLM..\Run: [UpdatePDIRShortCut] C:\Program Files (x86)\CyberLink\PowerDirector\MUITransfer\MUIStartMenu.exe (CyberLink Corp.)
O4 - HKLM..\Run: [UpdatePSTShortCut] C:\Program Files (x86)\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe (CyberLink Corp.)
O4 - HKCU..\Run: [WMPNSCFG] C:\Program Files (x86)\Windows Media Player\WMPNSCFG.exe File not found
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O8:64bit: - Extra context menu item: Convert link target to Adobe PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:64bit: - Extra context menu item: Convert link target to existing PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:64bit: - Extra context menu item: Convert selected links to Adobe PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:64bit: - Extra context menu item: Convert selected links to existing PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:64bit: - Extra context menu item: Convert selection to Adobe PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:64bit: - Extra context menu item: Convert selection to existing PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:64bit: - Extra context menu item: Convert to Adobe PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:64bit: - Extra context menu item: Convert to existing PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert link target to Adobe PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert link target to existing PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert selected links to Adobe PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert selected links to existing PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert selection to Adobe PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert selection to existing PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert to Adobe PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert to existing PDF - C:\Adobe Creative Suite2\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O9 - Extra Button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra Button: HP Smart Select - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll (Hewlett-Packard Co.)
O13 - gopher Prefix: missing
O15 - HKCU\..Trusted Ranges: Range1 ([http] in Local intranet)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_07)
O16 - DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 68.87.76.182 68.87.78.134
O18:64bit: - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\ms-itss {0A9007C0-4076-11D3-8789-0000F8105754} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\symres {AA1061FE-6C41-421f-9344-69640C9732AB} - Reg Error: Key error. File not found
O18 - Protocol\Handler\symres {AA1061FE-6C41-421f-9344-69640C9732AB} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.2.11\CoIEPlg.dll (Symantec Corporation)
O20:64bit: - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20 - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\SysWow64\explorer.exe (Microsoft Corporation)
O20:64bit: - Winlogon\Notify\igfxcui: DllName - Reg Error: Key error. - C:\Windows\SysNative\igfxdev.dll (Intel Corporation)
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2007/10/13 04:00:32 | 00,000,000 | ---D | M] - F:\autorun -- [ FAT32 ]
O32 - AutoRun File - [2007/05/18 10:37:12 | 00,000,069 | RH-- | M] () - F:\autorun.inf -- [ FAT32 ]
O33 - MountPoints2\{9bd50c8d-fb68-11dd-9ddd-00238b4f410b}\Shell\AutoRun\command - "" = F:\wd_windows_tools\WDSetup.exe -- [2007/07/13 14:07:56 | 01,671,650 | ---- | M] (Western Digital )
O33 - MountPoints2\{9bd50ca6-fb68-11dd-9ddd-00238b4f410b}\Shell\AutoRun\command - "" = F:\WDSetup.exe -- File not found
O33 - MountPoints2\{de7187b6-ea56-11dd-a10d-00238b4f410b}\Shell\AutoRun\command - "" = F:\wd_windows_tools\Setup.exe -- [2007/06/26 12:02:12 | 00,212,992 | ---- | M] (Western Digital Technologies, Inc.)
O33 - MountPoints2\F\Shell\AutoRun\command - "" = F:\wd_windows_tools\Setup.exe -- [2007/06/26 12:02:12 | 00,212,992 | ---- | M] (Western Digital Technologies, Inc.)
O34 - HKLM BootExecute: (autocheck) - File not found
O34 - HKLM BootExecute: (autochk) - C:\Windows\SysWow64\autochk.exe (Microsoft Corporation)
O34 - HKLM BootExecute: (*) - File not found
64bit: O35 - comfile [open] -- "%1" %* File not found
64bit: O35 - exefile [open] -- "%1" %* File not found
[2009/12/03 17:27:02 | 00,535,552 | ---- | C] (OldTimer Tools) -- C:\Users\Marc\Desktop\OTL.exe
[2009/12/03 10:06:59 | 00,401,720 | ---- | C] (Trend Micro Inc.) -- C:\Users\Marc\Desktop\winlogon.scr
[2009/12/03 10:05:27 | 00,000,000 | ---D | C] -- C:\JavaRa
[2009/12/03 09:54:09 | 00,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\Windows\SysWow64\drivers\mbamswissarmy.sys
[2009/12/02 15:29:55 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Roaming\Malwarebytes
[2009/12/02 14:32:28 | 00,022,104 | ---- | C] (Malwarebytes Corporation) -- C:\Windows\SysNative\drivers\mbam.sys
[2009/12/02 14:32:28 | 00,000,000 | ---D | C] -- C:\ProgramData\Malwarebytes
[2009/12/02 14:32:27 | 00,000,000 | ---D | C] -- C:\Program Files (x86)\Malwarebytes' Anti-Malware
[2009/12/02 08:37:35 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\mhwnbo
[2009/12/02 08:37:31 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\oxpund
[2009/12/02 08:37:28 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\poibar
[2009/11/30 14:42:31 | 00,000,000 | ---D | C] -- C:\Program Files (x86)\Windows Portable Devices
[2009/11/30 14:42:29 | 00,000,000 | ---D | C] -- C:\Program Files\Windows Portable Devices
[2009/11/30 14:20:25 | 00,449,024 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\WMPhoto.dll
[2009/11/30 14:20:25 | 00,369,664 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\WMPhoto.dll
[2009/11/30 14:20:25 | 00,342,016 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\winspool.drv
[2009/11/30 14:20:19 | 00,047,616 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\cdd.dll
[2009/11/30 14:20:16 | 01,548,800 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d3d10warp.dll
[2009/11/30 14:20:16 | 00,829,440 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d3d10warp.dll
[2009/11/30 14:20:16 | 00,035,840 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\printfilterpipelineprxy.dll
[2009/11/30 14:20:15 | 01,209,856 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\WindowsCodecs.dll
[2009/11/30 14:20:15 | 00,981,504 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d2d1.dll
[2009/11/30 14:20:15 | 00,974,848 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\WindowsCodecs.dll
[2009/11/30 14:20:15 | 00,828,928 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d2d1.dll
[2009/11/30 14:20:15 | 00,470,016 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\XpsGdiConverter.dll
[2009/11/30 14:20:15 | 00,245,248 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\WindowsCodecsExt.dll
[2009/11/30 14:20:15 | 00,231,936 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\XpsRasterService.dll
[2009/11/30 14:20:15 | 00,189,440 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\WindowsCodecsExt.dll
[2009/11/30 14:20:15 | 00,135,680 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\XpsRasterService.dll
[2009/11/30 14:20:14 | 00,566,272 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d3d10level9.dll
[2009/11/30 14:20:14 | 00,411,648 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\PhotoMetadataHandler.dll
[2009/11/30 14:20:14 | 00,328,192 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\dxdiag.exe
[2009/11/30 14:20:14 | 00,321,024 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\PhotoMetadataHandler.dll
[2009/11/30 14:20:14 | 00,280,064 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\XpsGdiConverter.dll
[2009/11/30 14:20:14 | 00,262,656 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\dxdiagn.dll
[2009/11/30 14:20:14 | 00,252,928 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\dxdiag.exe
[2009/11/30 14:20:14 | 00,195,584 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\dxdiagn.dll
[2009/11/30 14:20:13 | 01,554,432 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\xpsservices.dll
[2009/11/30 14:20:13 | 00,847,360 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\OpcServices.dll
[2009/11/30 14:20:13 | 00,792,576 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d3d11.dll
[2009/11/30 14:20:13 | 00,625,664 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\dxgi.dll
[2009/11/30 14:20:13 | 00,519,680 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d3d11.dll
[2009/11/30 14:20:13 | 00,486,912 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d3d10level9.dll
[2009/11/30 14:20:13 | 00,481,792 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\dxgi.dll
[2009/11/30 14:20:13 | 00,351,232 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\XpsPrint.dll
[2009/11/30 14:20:13 | 00,326,656 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d3d10_1core.dll
[2009/11/30 14:20:13 | 00,287,744 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d3d10core.dll
[2009/11/30 14:20:13 | 00,218,112 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d3d10_1core.dll
[2009/11/30 14:20:13 | 00,190,464 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d3d10core.dll
[2009/11/30 14:20:12 | 03,068,416 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\xpsservices.dll
[2009/11/30 14:20:12 | 01,461,760 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\OpcServices.dll
[2009/11/30 14:20:12 | 01,142,272 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\FntCache.dll
[2009/11/30 14:20:12 | 01,064,448 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\DWrite.dll
[2009/11/30 14:20:12 | 01,032,192 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\printfilterpipelinesvc.exe
[2009/11/30 14:20:12 | 00,643,072 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\XpsPrint.dll
[2009/11/30 14:20:11 | 01,548,800 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\DWrite.dll
[2009/11/30 14:20:11 | 01,269,248 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d3d10.dll
[2009/11/30 14:20:11 | 01,030,144 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d3d10.dll
[2009/11/30 14:20:11 | 00,196,608 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d3d10_1.dll
[2009/11/30 14:20:11 | 00,161,280 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d3d10_1.dll
[2009/11/30 14:18:23 | 00,034,816 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\WPDShextAutoplay.exe
[2009/11/30 14:18:23 | 00,030,208 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\WPDShextAutoplay.exe
[2009/11/30 14:18:21 | 00,037,888 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\BthMtpContextHandler.dll
[2009/11/30 14:18:09 | 00,077,824 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\PortableDeviceConnectApi.dll
[2009/11/30 14:18:06 | 02,727,936 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\wpdshext.dll
[2009/11/30 14:18:06 | 02,537,472 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\wpdshext.dll
[2009/11/30 14:18:06 | 00,573,440 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\wpd_ci.dll
[2009/11/30 14:18:06 | 00,453,120 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\PortableDeviceApi.dll
[2009/11/30 14:18:06 | 00,433,152 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\WPDSp.dll
[2009/11/30 14:18:06 | 00,350,208 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\WPDSp.dll
[2009/11/30 14:18:06 | 00,334,848 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\PortableDeviceApi.dll
[2009/11/30 14:18:06 | 00,218,624 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\PortableDeviceWMDRM.dll
[2009/11/30 14:18:06 | 00,214,528 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\PortableDeviceTypes.dll
[2009/11/30 14:18:06 | 00,196,608 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\PortableDeviceWMDRM.dll
[2009/11/30 14:18:06 | 00,160,256 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\PortableDeviceTypes.dll
[2009/11/30 14:18:06 | 00,113,152 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\PortableDeviceClassExtension.dll
[2009/11/30 14:18:06 | 00,110,080 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\WPDShServiceObj.dll
[2009/11/30 14:18:06 | 00,100,864 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\PortableDeviceClassExtension.dll
[2009/11/30 14:18:06 | 00,060,928 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\PortableDeviceConnectApi.dll
[2009/11/30 14:16:26 | 00,004,096 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\oleaccrc.dll
[2009/11/30 14:16:26 | 00,004,096 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\oleaccrc.dll
[2009/11/30 14:16:25 | 00,736,256 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\UIAutomationCore.dll
[2009/11/30 14:16:25 | 00,555,520 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\UIAutomationCore.dll
[2009/11/30 14:16:25 | 00,315,904 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\oleacc.dll
[2009/11/30 14:14:43 | 00,103,424 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\UIAnimation.dll
[2009/11/30 14:14:43 | 00,092,672 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\UIAnimation.dll
[2009/11/30 14:14:37 | 01,164,800 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\UIRibbonRes.dll
[2009/11/30 14:14:36 | 03,815,424 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\UIRibbon.dll
[2009/11/30 14:14:36 | 03,023,360 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\UIRibbon.dll
[2009/11/30 14:14:36 | 01,164,800 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\UIRibbonRes.dll
[2009/11/30 11:49:53 | 10,626,560 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\wmp.dll
[2009/11/30 11:49:51 | 00,372,736 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\unregmp2.exe
[2009/11/30 11:49:51 | 00,310,784 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\unregmp2.exe
[2009/11/30 11:49:47 | 13,428,224 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\wmp.dll
[2009/11/30 11:49:43 | 08,147,456 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\wmploc.DLL
[2009/11/30 11:49:41 | 08,147,968 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\wmploc.DLL
[2009/11/30 11:47:24 | 00,032,256 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\Apphlpdm.dll
[2009/11/30 11:47:24 | 00,028,672 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\Apphlpdm.dll
[2009/11/30 11:47:21 | 04,240,384 | ---- | C] (Microsoft) -- C:\Windows\SysWow64\GameUXLegacyGDFs.dll
[2009/11/30 11:47:21 | 04,240,384 | ---- | C] (Microsoft) -- C:\Windows\SysNative\GameUXLegacyGDFs.dll
[2009/11/30 11:46:54 | 00,880,640 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\timedate.cpl
[2009/11/30 11:46:53 | 00,714,240 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\timedate.cpl
[2009/11/30 11:22:53 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\urudvu
[2009/11/30 11:22:51 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\flpiue
[2009/11/30 11:22:49 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\oflmuo
[2009/11/30 11:22:48 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Roaming\xygrux
[2009/11/30 11:22:47 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\xygrux
[2009/11/30 11:22:46 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\hsbvuh
[2009/11/30 11:22:44 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\rmvbur
[2009/11/30 11:22:42 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\bgrftb
[2009/11/30 11:22:41 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\sdohhg
[2009/11/30 11:22:40 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\kamktk
[2009/11/30 11:22:31 | 00,000,000 | ---D | C] -- C:\Users\Marc\AppData\Local\wbsctx
[2009/11/22 21:56:34 | 00,149,280 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaws.exe
[2009/11/22 21:56:34 | 00,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaw.exe
[2009/11/22 21:56:34 | 00,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\java.exe
[2009/12/03 17:27:50 | 01,835,008 | -HS- | M] () -- C:\Users\Marc\ntuser.dat
[2009/12/03 16:58:18 | 00,003,216 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
[2009/12/03 16:58:18 | 00,003,216 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
[2009/12/03 16:14:06 | 00,038,224 | ---- | M] (Malwarebytes Corporation) -- C:\Windows\SysWow64\drivers\mbamswissarmy.sys
[2009/12/03 16:13:58 | 00,022,104 | ---- | M] (Malwarebytes Corporation) -- C:\Windows\SysNative\drivers\mbam.sys
[2009/12/03 15:17:00 | 00,690,960 | ---- | M] () -- C:\Windows\SysNative\PerfStringBackup.INI
[2009/12/03 15:17:00 | 00,595,684 | ---- | M] () -- C:\Windows\SysNative\perfh009.dat
[2009/12/03 15:17:00 | 00,101,350 | ---- | M] () -- C:\Windows\SysNative\perfc009.dat
[2009/12/03 14:58:23 | 00,000,006 | -H-- | M] () -- C:\Windows\tasks\SA.DAT
[2009/12/03 14:58:11 | 00,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2009/12/03 14:57:44 | 41,934,72512 | -HS- | M] () -- C:\hiberfil.sys
[2009/12/03 14:56:21 | 00,524,288 | -HS- | M] () -- C:\Users\Marc\ntuser.dat{6a8e844f-850c-11de-ab22-00238bc58902}.TMContainer00000000000000000001.regtrans-ms
[2009/12/03 14:56:21 | 00,065,536 | -HS- | M] () -- C:\Users\Marc\ntuser.dat{6a8e844f-850c-11de-ab22-00238bc58902}.TM.blf
[2009/12/03 14:56:19 | 02,973,709 | -H-- | M] () -- C:\Users\Marc\AppData\Local\IconCache.db
[2009/12/03 14:33:07 | 00,000,848 | ---- | M] () -- C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk
[2009/12/03 10:07:00 | 00,401,720 | ---- | M] (Trend Micro Inc.) -- C:\Users\Marc\Desktop\winlogon.scr
[2009/11/30 14:41:50 | 00,000,000 | -H-- | M] () -- C:\Windows\SysNative\drivers\Msft_User_WpdFs_01_07_00.Wdf
[2009/11/27 22:05:30 | 00,000,038 | ---- | M] () -- C:\Users\Marc\jagex_runescape_preferences.dat
[2009/11/27 21:35:31 | 00,000,063 | ---- | M] () -- C:\Users\Marc\jagex_runescape_preferences2.dat
[2009/11/27 16:34:08 | 00,041,752 | ---- | M] () -- C:\Users\Marc\Desktop\IMG00037-20091127-1532.jpg
[2009/11/27 16:34:02 | 00,029,258 | ---- | M] () -- C:\Users\Marc\Desktop\IMG00030-20091126-1622.jpg
[2009/11/23 16:11:07 | 00,013,799 | ---- | M] () -- C:\Users\Marc\Desktop\untitled.docx
[2009/11/11 14:07:57 | 00,394,648 | ---- | M] () -- C:\Windows\SysNative\FNTCACHE.DAT
[2009/12/03 09:54:12 | 00,000,848 | ---- | C] () -- C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk
[2009/12/03 08:07:42 | 41,934,72512 | -HS- | C] () -- C:\hiberfil.sys
[2009/11/30 14:41:50 | 00,000,000 | -H-- | C] () -- C:\Windows\SysNative\drivers\Msft_User_WpdFs_01_07_00.Wdf
[2009/11/27 20:12:09 | 00,000,063 | ---- | C] () -- C:\Users\Marc\jagex_runescape_preferences2.dat
[2009/11/27 20:10:05 | 00,000,038 | ---- | C] () -- C:\Users\Marc\jagex_runescape_preferences.dat
[2009/11/27 16:34:08 | 00,041,752 | ---- | C] () -- C:\Users\Marc\Desktop\IMG00037-20091127-1532.jpg
[2009/11/27 16:34:02 | 00,029,258 | ---- | C] () -- C:\Users\Marc\Desktop\IMG00030-20091126-1622.jpg
[2009/11/01 20:22:54 | 00,000,000 | ---- | C] () -- C:\Users\Marc\AppData\Roaming\wklnhst.dat
[2009/06/20 19:15:06 | 00,117,248 | ---- | C] () -- C:\Windows\SysWow64\EhStorAuthn.dll
[2009/06/20 19:13:43 | 00,368,640 | ---- | C] () -- C:\Windows\SysWow64\msjetoledb40.dll
[2009/05/24 23:21:23 | 00,425,046 | ---- | C] () -- C:\Users\Marc\AppData\Local\dd_vcredistMSI7186.txt
[2009/05/24 23:21:22 | 00,011,442 | ---- | C] () -- C:\Users\Marc\AppData\Local\dd_vcredistUI7186.txt
[2009/03/08 14:42:42 | 00,002,041 | ---- | C] () -- C:\ProgramData\hpzinstall.log
[2009/02/05 12:58:05 | 00,004,608 | ---- | C] () -- C:\Users\Marc\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2009/01/24 18:09:29 | 00,000,171 | ---- | C] () -- C:\Windows\QUICKEN.INI
[2009/01/24 11:49:40 | 00,000,000 | ---- | C] () -- C:\Users\Marc\AppData\Local\QSwitch.txt
[2009/01/24 11:49:40 | 00,000,000 | ---- | C] () -- C:\Users\Marc\AppData\Local\DSwitch.txt
[2009/01/24 11:49:40 | 00,000,000 | ---- | C] () -- C:\Users\Marc\AppData\Local\AtStart.txt
[2008/12/10 00:56:28 | 00,000,105 | ---- | C] () -- C:\ProgramData\{d36dd326-7280-11d8-97c8-000129760cbe}.log
[2008/12/10 00:56:20 | 00,000,032 | ---- | C] () -- C:\ProgramData\{051B9612-4D82-42AC-8C63-CD2DCEDC1CB3}.log
[2008/12/10 00:55:57 | 00,000,032 | ---- | C] () -- C:\ProgramData\{9867824A-C86D-4A83-8F3C-E7A86BE0AFD3}.log
[2008/12/10 00:55:28 | 00,000,032 | ---- | C] () -- C:\ProgramData\{23F3DA62-2D9E-4A69-B8D5-BE8E9E148092}.log
[2008/12/10 00:54:15 | 00,000,032 | ---- | C] () -- C:\ProgramData\{4FC670EB-5F02-4B07-90DB-022B86BFEFD0}.log
[2008/10/18 15:45:24 | 00,000,109 | ---- | C] () -- C:\ProgramData\{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79}.log
[2008/10/18 15:39:59 | 00,000,110 | ---- | C] () -- C:\ProgramData\{CB099890-1D5F-11D5-9EA9-0050BAE317E1}.log
[2008/10/18 15:38:17 | 00,000,105 | ---- | C] () -- C:\ProgramData\{40BF1E83-20EB-11D8-97C5-0009C5020658}.log
[2008/10/18 15:36:58 | 00,000,107 | ---- | C] () -- C:\ProgramData\{C59C179C-668D-49A9-B6EA-0121CCFC1243}.log
[2008/06/18 13:59:56 | 00,007,680 | ---- | C] () -- C:\Windows\SysWow64\ff_vfw.dll
[2008/01/20 18:50:05 | 00,060,124 | ---- | C] () -- C:\Windows\SysWow64\tcpmon.ini
@Alternate Data Stream - 103 bytes -> C:\ProgramData\Temp:C39E55C5
ghoticov
Posts Posts : 13
OS OS : Vista
Post by ghoticov on 4th December 2009, 1:38 am
And here is the Extras.Txt list:
OTL Extras logfile created on: 12/3/2009 5:27:55 PM - Run 1
Include 64bit Scans
File Age = 30 Days
Output = Standard
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\]
.chm [@ = chm.file] -- "%SystemRoot%\hh.exe" %1
.cpl [@ = cplfile] -- C:\Windows\SysWow64\control.exe (Microsoft Corporation)
.html [@ = FirefoxHTML] -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe (Mozilla Corporation)
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\\shell\[command]\command]
batfile [open] -- "%1" %* File not found
chm.file [open] -- "%SystemRoot%\hh.exe" %1 File not found
cmdfile [open] -- "%1" %* File not found
htmlfile [edit] -- "C:\Adobe Creative Suite2\Adobe GoLive CS2\GoLive.exe" "%1" (Adobe Systems Incorporated)
htmlfile [print] -- "C:\Program Files (x86)\Microsoft Office\Office12\msohtmed.exe" /p %1 (Microsoft Corporation)
InternetShortcut [print] -- "C:\Windows\System32\rundll32.exe" "C:\Windows\System32\mshtml.dll",PrintHTML "%1" (Microsoft Corporation)
piffile [open] -- "%1" %* File not found
scrfile [config] -- "%1" File not found
scrfile [open] -- "%1" /S File not found
Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1 File not found
Directory [OneNote.Open] -- C:\PROGRA~2\MICROS~2\Office12\ONENOTE.EXE "%L" (Microsoft Corporation)
Directory [OtsMedia.Surf] -- "C:\OtsLabs\OtsPlay.exe" "%1" /play /surf ()
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
"cval" = 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
"VistaSp1" = 9F 9E 16 8C DC 5B C8 01 [binary data]
"VistaSp2" = 27 99 FF 8B 24 F2 C9 01 [binary data]
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
"oobe_av" = 1
"EnableFirewall" = 0
"DisableNotifications" = 0
========== Vista Active Open Ports Exception List ==========
"{0F6D8328-BE46-43ED-A426-2C8A99370E79}" = lport=6004 | protocol=17 | dir=in | app=c:\program files (x86)\microsoft office\office12\outlook.exe |
========== Vista Active Application Exception List ==========
"{0597A580-AC01-43FC-95D0-4A773088607E}" = dir=in | app=c:\program files (x86)\hewlett-packard\media\tv\qpservice.exe |
"{155B95D0-550C-4CA4-B3A0-330DADAB5CDC}" = protocol=17 | dir=in | app=c:\program files (x86)\itunes\itunes.exe |
"{1B3396CC-4B13-4328-863B-D4950B3ECE4D}" = protocol=6 | dir=in | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
"{1BAF0EE4-5289-46E7-AAC5-F9F2B8D56A0F}" = dir=in | app=c:\program files (x86)\cyberlink\powerdirector\pdr.exe |
"{24F72FF9-5558-4157-BC17-AB3E20AAF376}" = dir=in | app=c:\program files (x86)\hewlett-packard\media\dvd\tsmagent.exe |
"{43107FB5-59CD-44FB-86CD-4BA554355E87}" = dir=in | app=c:\program files (x86)\hewlett-packard\touchsmart\media\hptouchsmartvideo.exe |
"{448C8DA4-E1FB-4318-9D6C-F7392F3A62FE}" = dir=in | app=c:\program files (x86)\hewlett-packard\media\dvd\kernel\clml\clmlsvc.exe |
"{44E9D574-49DF-4186-ACEB-14105753B3F2}" = dir=in | app=c:\program files (x86)\hewlett-packard\touchsmart\media\hptouchsmartmusic.exe |
"{4EA375FB-F6D7-420F-BB73-5798D2EA53E7}" = protocol=6 | dir=in | app=c:\program files (x86)\itunes\itunes.exe |
"{583805D9-F23C-4552-9AEF-3EB259AD0C5C}" = dir=in | app=c:\program files (x86)\hewlett-packard\media\dvd\hptouchsmartmusic.exe |
"{7286AE5E-C63B-41AC-9B78-74CFCA0EC4C0}" = protocol=17 | dir=in | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
"{7F53BB49-F4F6-4C6C-966C-2F807238692C}" = dir=in | app=c:\program files (x86)\hewlett-packard\media\dvd\hptouchsmartvideo.exe |
"{90B9FAFF-3BCE-452A-9A51-06099F6ED5DE}" = dir=in | app=c:\program files (x86)\hewlett-packard\media\dvd\hpdvdsmart.exe |
"{9215733D-5533-4A43-8141-D482891FEA82}" = dir=in | app=c:\program files (x86)\hewlett-packard\touchsmart\media\kernel\clml\clmlsvc.exe |
"{998EA985-3DE8-4936-96D4-2CB8FD180A03}" = dir=in | app=c:\program files (x86)\hewlett-packard\touchsmart\media\hptouchsmartphoto.exe |
"{A37DBC2D-BEF8-475C-9E53-C39E76EC3419}" = protocol=17 | dir=in | app=c:\program files (x86)\bonjour\mdnsresponder.exe |
"{B62C29B7-8C88-4707-A8BA-DBB70EC02CA0}" = protocol=6 | dir=in | app=c:\program files (x86)\bonjour\mdnsresponder.exe |
"{C71ECA09-AF15-4B56-BF5F-BA464596ACE9}" = protocol=17 | dir=in | app=c:\adobe creative suite2\adobe version cue cs2\bin\versioncuecs2.exe |
"{CC59B9C5-79AF-4C3B-B983-0AA6A633C6F5}" = protocol=6 | dir=in | app=c:\program files (x86)\yahoo!\messenger\yahoomessenger.exe |
"{D25C2E44-773E-4746-BF90-E5A190646BFF}" = protocol=17 | dir=in | app=c:\program files (x86)\yahoo!\messenger\yahoomessenger.exe |
"{DC5DFBAF-1277-47D5-84E7-CE58CAD07C4F}" = dir=in | app=c:\program files (x86)\hewlett-packard\media\tv\qp.exe |
"{ECD17C0C-F8B4-4E53-8456-EA43961E5AC7}" = dir=in | app=c:\program files (x86)\hewlett-packard\touchsmart\media\tsmagent.exe |
"{F76EC7FB-BF0D-4D79-BF1B-FDAFC89B0CBE}" = dir=in | app=c:\program files (x86)\hewlett-packard\media\dvd\hptouchsmartphoto.exe |
"{FF3AD083-E2ED-4E02-8810-B43E6C94BB7C}" = protocol=6 | dir=in | app=c:\adobe creative suite2\adobe version cue cs2\bin\versioncuecs2.exe |
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
"{071c9b48-7c32-4621-a0ac-3f809523288f}" = Microsoft Visual C++ 2005 Redistributable (x64)
"{15262012-213A-4f65-9019-C8A409EC0156}" = HP Officejet J6400 Series
"{240FCE0B-F553-4ab3-9C7B-3CD082FCA117}" = NetDeviceManager64
"{2EF5C74A-1137-46B1-A7BA-5A39ED27A22A}" = Bonjour
"{2F97CE84-9C33-4631-821B-85EA371EA254}" = ProtectSmart Hard Drive Protection
"{4575935D-9457-4517-8750-2341F4286F5F}" = iTunes
"{4FFA2088-8317-3B14-93CD-4C699DB37843}" = Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729
"{52784483-7088-4A4C-81E2-808303AD98F5}" = Apple Mobile Device Support
"{90120000-002A-0000-1000-0000000FF1CE}" = Microsoft Office Office 64-bit Components 2007
"{90120000-002A-0409-1000-0000000FF1CE}" = Microsoft Office Shared 64-bit MUI (English) 2007
"{90120000-0116-0409-1000-0000000FF1CE}" = Microsoft Office Shared 64-bit Setup Metadata MUI (English) 2007
"{9F560BEB-021F-43AC-825F-AA60442D8DE4}" = 64 Bit HP CIO Components Installer
"{D2F7994F-661E-46D1-A1DF-67F2887AAA7E}" = HP MediaSmart SmartMenu
"07B260955637F1FF7587ED2AA87459040DD09BF7" = Windows Driver Package - ENE (enecir) HIDClass (09/04/2008 2.6.0.0)
"Agere Systems Soft Modem" = Agere Systems HDA Modem
"Broadcom 802.11b Network Adapter" = Broadcom 802.11 Wireless LAN Adapter
"HDMI" = Intel(R) Graphics Media Accelerator Driver
"HP Document Manager" = HP Document Manager 1.0
"HP Imaging Device Functions" = HP Imaging Device Functions 10.0
"HP Photosmart Essential" = HP Photosmart Essential 2.5
"HP Smart Web Printing" = HP Smart Web Printing
"HP Solution Center & Imaging Support Tools" = HP Solution Center 10.0
"HPExtendedCapabilities" = HP Customer Participation Program 10.0
"HPOCR" = OCR Software by I.R.I.S. 10.0
"Shop for HP Supplies" = Shop for HP Supplies
"SynTPDeinstKey" = Synaptics Pointing Device Driver
"{0054A0F6-00C9-4498-B821-B5C9578F433E}" = HP Help and Support
"{0134A1A1-C283-4A47-91A1-92F19F960372}" = Adobe Creative Suite 2
"{01FB4998-33C4-4431-85ED-079E3EEFE75D}" = HP MediaSmart Webcam
"{07A5026D-5F9F-43D1-9073-C2F882D417E7}" = HP User Guides 0128
"{082702D5-5DD8-4600-BCE5-48B15174687F}" = HP Doc Viewer
"{0E7DBD52-B097-4F2B-A7C7-F105B0D20FDB}" = LightScribe System Software 1.14.17.1
"{0F7C2E47-089E-4d23-B9F7-39BE00100776}" = Toolbox
"{154A4184-1A3D-4BF9-A5AE-4FA1660445F3}" = HP Total Care Advisor
"{15BC8CD0-A65B-47D0-A2DD-90A824590FA8}" = Microsoft Works
"{18669FF9-C8FE-407a-9F70-E674896B1DB4}" = GPBaseService
"{188C0E25-3D65-4DAC-9C00-7483FBA4C7EB}" = Status
"{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79}" = CyberLink DVD Suite
"{216AB108-2AE1-4130-B3D5-20B2C4C80F8F}" = QuickTime
"{236BB7C4-4419-42FD-0409-1E257A25E34D}" = Adobe Photoshop CS2
"{254C37AA-6B72-4300-84F6-98A82419187E}" = ActiveCheck component for HP Active Support Library
"{26A24AE4-039D-4CA4-87B4-2F83216012FF}" = Java(TM) 6 Update 17
"{279D3818-7287-4ab4-A927-542EBEA9E365}" = ProductContext
"{30D3B7BC-5798-45D9-822D-05CA18F39E99}" = HPTCSSetup
"{3248F0A8-6813-11D6-A77B-00B0D0160070}" = Java(TM) 6 Update 7
"{34BFB099-07B2-4E95-A673-7362D60866A2}" = PSSWCORE
"{34D2AB40-150D-475D-AE32-BD23FB5EE355}" = HP Quick Launch Buttons 6.40 H2
"{36FDBE6E-6684-462b-AE98-9A39A1B200CC}" = HPProductAssistant
"{380CC749-8C28-4C74-BE01-45921D062302}" = BPDSoftware_Ini
"{3877C901-7B90-4727-A639-B6ED2DD59D43}" = ESU for Microsoft Vista
"{3A215E3C-CBAD-4062-984D-1F4A3F4926D1}" = Tunebite
"{3B0F52AC-EF5C-4831-B221-06C782E41280}" = Quicken 2008
"{40BF1E83-20EB-11D8-97C5-0009C5020658}" = Power2Go
"{41853D20-40CC-4266-978D-F128BB97CA96}" = 6400_Help
"{45A136EC-88BF-4B95-99F5-C45D3930E1CC}" = HP MULTIPLE MODEM INSTALLER for VISTA
"{46548E80-0409-0000-7E8A-45000F855001}" = Adobe GoLive CS2
"{4D4AAB01-FB62-48EB-AC03-C777B26DD457}" = Mspc2
"{4EB7E778-1E95-433F-8919-C323D5483363}" = HP Smart Web Printing
"{52A69E11-7CEB-4a7d-9607-68BA4F39A89B}" = DeviceDiscovery
"{57A5AEC1-97FC-474D-92C4-908FCC2253D4}" = HP Customer Experience Enhancements
"{5ACE69F0-A3E8-44eb-88C1-0A841E700180}" = TrayApp
"{5BB4D7C1-52F2-4BFD-9E40-0D419E2E3021}" = bpd_scan
"{5D934326-165A-413b-B056-26BE1EC082AF}" = J6400
"{6423EF83-6E1D-4D22-A36F-689CD19FD4D2}" = Juno Preloader
"{65DA2EC9-0642-47E9-AAE2-B5267AA14D75}" = Activation Assistant for the 2007 Microsoft Office suites
"{669D4A35-146B-4314-89F1-1AC3D7B88367}" = HPAsset component for HP Active Support Library
"{66E6CE0C-5A1E-430C-B40A-0C90FF1804A8}" = eSupportQFolder
"{67626E09-5366-4480-8F1E-93FADF50CA15}" = HP MediaSmart TV
"{676981B7-A2D9-49D0-9F4C-03018F131DA9}" = DocProc
"{687FEF8A-8597-40b4-832C-297EA3F35817}" = BufferChm
"{6A370610-3778-44AF-9AAC-69B2FD1A3356}" = Microsoft Live Search Toolbar
"{77DCDCE3-2DED-62F3-8154-05E745472D07}" = Acrobat.com
"{786C5747-1033-0000-B58E-000000000001}" = Adobe Stock Photos 1.0
"{7F4C8163-F259-49A0-A018-2857A90578BC}" = Adobe InDesign CS2
"{80533B67-C407-485D-8B5D-63BB8ED9D878}" = Scan
"{85C8D391-0EAE-4492-8A0A-2EE8B0B6DA03}" = BPDSoftware
"{87E2B986-07E8-477a-93DC-AF0B6758B192}" = DocProcQFolder
"{8833FFB6-5B0C-4764-81AA-06DFEED9A476}" = Realtek 8169 8168 8101E 8102E Ethernet Driver
"{8A85DEAD-7C1F-4368-881C-72AC74CB2E91}" = UnloadSupport
"{8EDBA74D-0686-4C99-BFDD-F894678E5B39}" = Adobe Common File Installer
"{91120000-0014-0000-0000-0000000FF1CE}" = Microsoft Office Professional 2007
"{9ADABDDE-9644-461B-9E73-83FA3EFCAB50}" = HP Wireless Assistant
"{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
"{A5AB9D5E-52E2-440e-A3ED-9512E253C81A}" = SolutionCenter
"{AB5D51AE-EBC3-438D-872C-705C7C2084B0}" = DeviceManagementQFolder
"{ABA00898-9467-4689-9F40-DE7F58C8429C}" = Fax
"{AC76BA86-1033-0000-7760-000000000002}" = Adobe Acrobat 7.0 Professional
"{AC76BA86-7AD7-1033-7B44-A90000000001}" = Adobe Reader 9
"{ADBE46EE-54E0-4610-B436-D7E93D829100}" = Adobe Version Cue CS2
"{B2C3BB6B-E005-4246-B8E5-DF0A4D073CDC}" = PixiePack Codec Pack
"{B2EE25B9-5B00-4ACF-94F0-92433C28C39E}" = HP MediaSmart Music/Photo/Video
"{B2F5D08C-7E79-4FCD-AAF4-57AD35FF0601}" = Adobe Illustrator CS2
"{B74D4E10-6884-0000-0000-000000000103}" = Adobe Bridge 1.0
"{B8DBED1E-8BC3-4d08-B94A-F9D7D88E9BBF}" = HPSSupply
"{BAD0FA60-09CF-4411-AE6A-C2844C8812FA}" = HP Photosmart Essential 2.5
"{C49DAA9C-5BA8-459A-8244-E57B69DF0F04}" = Suite Specific
"{C59C179C-668D-49A9-B6EA-0121CCFC1243}" = LabelPrint
"{C8FD5BC1-92EF-4C15-92A9-F9AC7F61985F}" = HP Update
"{CB099890-1D5F-11D5-9EA9-0050BAE317E1}" = PowerDirector
"{CCB9B81A-167F-4832-B305-D2A0430840B3}" = WebReg
"{CE7E3BE0-2DD3-4416-A690-F9E4A99A8CFF}" = HP Active Support Library
"{D142FE39-3386-4d82-9AD3-36D4A92AC3C2}" = DocMgr
"{D2E0F0CC-6BE0-490b-B08B-9267083E34C9}" = MarketResearch
"{D99A8E3A-AE5A-4692-8B19-6F16D454E240}" = Destination Component
"{DBCC73BA-C69A-4BF5-B4BF-F07501EE7039}" = AnswerWorks 5.0 English Runtime
"{DC24971E-1946-445D-8A82-CE685433FA7D}" = Realtek USB 2.0 Card Reader
"{DCCAD079-F92C-44DA-B258-624FC6517A5A}" = HP MediaSmart DVD
"{DD35C328-F115-BEDA-6EEE-E00C5AACCCBC}" = muvee Reveal
"{E08DC77E-D09A-4e36-8067-D6DBBCC5F8DC}" = VideoToolkit01
"{E9787678-1033-0000-8E67-000000000001}" = Adobe Help Center 1.0
"{ECEE0279-785F-4CB3-9F28-E69813234BF8}" = SPORE Creature Creator Trial Edition
"{FEA0CE81-7FC7-AAAE-FC8C-241A5F8684F0}" = Supercast
"Activation Assistant for the 2007 Microsoft Office suites" = Activation Assistant for the 2007 Microsoft Office suites
"Adobe AIR" = Adobe AIR
"Adobe SVG Viewer" = Adobe SVG Viewer 3.0
"Carbonite Setup Lite" = Carbonite Online Backup Setup
"com.directv.supercast.AA1ECC8BBAFE4E1BBF2D418DC006AF207FACE6CA.1" = Supercast
"InstallShield_{01FB4998-33C4-4431-85ED-079E3EEFE75D}" = HP MediaSmart Webcam
"InstallShield_{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79}" = CyberLink DVD Suite
"InstallShield_{40BF1E83-20EB-11D8-97C5-0009C5020658}" = Power2Go
"InstallShield_{67626E09-5366-4480-8F1E-93FADF50CA15}" = HP MediaSmart TV
"InstallShield_{B2EE25B9-5B00-4ACF-94F0-92433C28C39E}" = HP MediaSmart Music/Photo/Video
"InstallShield_{C59C179C-668D-49A9-B6EA-0121CCFC1243}" = LabelPrint
"InstallShield_{CB099890-1D5F-11D5-9EA9-0050BAE317E1}" = PowerDirector
"InstallShield_{DCCAD079-F92C-44DA-B258-624FC6517A5A}" = HP MediaSmart DVD
"Mozilla Firefox (3.5.5)" = Mozilla Firefox (3.5.5)
"Mozilla Thunderbird (2.0.0.23)" = Mozilla Thunderbird (2.0.0.23)
"NIS" = Norton Internet Security
"OtsAV DJ" = OtsAV DJ 1.85.064
"OtsAV DJ Trial" = OtsAV DJ Trial 1.85.064
"PROR" = Microsoft Office Professional 2007
"Protected Music Converter_is1" = Protected Music Converter 1.1
"WildTangent hp Master Uninstall" = My HP Games
"Yahoo! Messenger" = Yahoo! Messenger
Error reading Event Logs: The Event Service is not operating properly or the Event Logs are corrupt!
ghoticov
Posts Posts : 13
Joined Joined : 2009-12-02
OS OS : Vista
Points Points : 25819
Re: Antivirus System Pro Removal with Hijack This info
Post by Belahzur on 4th December 2009, 1:45 am
You.
DjDan999 isn't an official helper here so instructions from users that don't have colored names (like Blue for me and green for Dragon Master Jay, or red forum admins) could b e fatal should something go wrong and they have no idea what happened.
  • Click Start >> Control Panel.
  • Under the Programs click Uninstall a Program
  • Highlight Java(TM) 6 Update 7
  • Click on the Uninstall/Change button at the top.
Please run OTL.exe.
    :files
  • Close OTL.exe
Points Points : 245111
Post by ghoticov on 4th December 2009, 1:53 am
Ok, done. Here ya go...
========== FILES ==========
C:\Users\Marc\AppData\Local\mhwnbo folder moved successfully.
C:\Users\Marc\AppData\Local\oxpund folder moved successfully.
C:\Users\Marc\AppData\Local\poibar folder moved successfully.
C:\Users\Marc\AppData\Local\urudvu folder moved successfully.
C:\Users\Marc\AppData\Local\flpiue folder moved successfully.
C:\Users\Marc\AppData\Local\oflmuo folder moved successfully.
C:\Users\Marc\AppData\Roaming\xygrux folder moved successfully.
C:\Users\Marc\AppData\Local\xygrux folder moved successfully.
C:\Users\Marc\AppData\Local\hsbvuh folder moved successfully.
C:\Users\Marc\AppData\Local\rmvbur folder moved successfully.
C:\Users\Marc\AppData\Local\bgrftb folder moved successfully.
C:\Users\Marc\AppData\Local\sdohhg folder moved successfully.
C:\Users\Marc\AppData\Local\kamktk folder moved successfully.
C:\Users\Marc\AppData\Local\wbsctx folder moved successfully.
OTL by OldTimer - Version 3.1.11.4 log created on 12032009_175305
ghoticov
Posts Posts : 13
OS OS : Vista
Post by Belahzur on 4th December 2009, 2:03 am
To remove all of the tools we used and the files and folders they created do the following:
Double click OTL.exe.
  • Click the CleanUp! button.
  • Select Yes when the "Begin cleanup Process?" prompt appears.
How is the machine now?
Post by ghoticov on 4th December 2009, 2:14 am
Ok, I did that. My machine seems to be running fine now. For some reason though, I am getting a "A Program needs your permission to run" pop up when I restart and it is the Malwarebytes' program that is being asked to be run. I am not even clicking on it to try and run it, it just pops up on its own.
ghoticov
Posts Posts : 13
OS OS : Vista
Post by Belahzur on 4th December 2009, 10:07 pm
Don't worry, it's just the Vista UAC protection warning, and MBAM uses delete on reboot command on some tougher-to-remove files.
Post by ghoticov on 5th December 2009, 12:21 am
ok, thank you!
ghoticov
Posts Posts : 13
OS OS : Vista
