New guy; problem removing antivirus sytem pro
Post by mikadocooper on 3rd December 2009, 3:23 pm
Hello everyone,
This is my first time on this forum.
My internet explorer got hijacked and I tried to install AVG and windows defender by installed from a jump drive, but this program keeps disabling every command. It even turned off my automatic updates on windows and acts like it is my antivirus and won't let me do anything.
How can I download the Malwarebytes anti-malware tool when it will not let me even use my task manager?
I am using windows xp.
Help!!!
These companies should be run out of business for causing these kinds of problems!!
mikadocooper
Joined Joined : 2009-12-03
Points Points : 25623
Re: New guy; problem removing antivirus sytem pro
Post by Mr Porko on 3rd December 2009, 5:34 pm
Hello. I have just registered and this is my first post.
Like you I have the Antivirus System Pro virus. I have checked with the advice previously given for getting rid of this but all this advice seems to assume that you are able to access the web to be able to download the Malware. I am sending this from a lap top which is mercifully unaffected. My question is is there anyway I can access the web to download the fixing software or do you have alternitive methods.
Many thanks for your help
Mr Porko
Mr Porko
Points Points : 25627
Post by Doctor Inferno on 4th December 2009, 2:07 am
Anybody with malware/virus problems open a new topic here:
http://www.geekpolice.net/virus-spyware-malware-removal-f11/
Thank you.
