Please help me with my virus problem!
Post by Thethetheluis on 2nd December 2009, 6:59 am
Ok well this has happened before and I ended up like renewing my whole computer which of course deletes everything but it's happening again (it happened the first time like 6 months ago).
What happened is I can't open like any programs, it says, "Their infected" but the thing is it's making these like completely fake BOGUS as hell virus scanners pop up I think it was called like, "Virus System Pro" Or something like that I could be way off and like it trys to scan and then wants me to 'pay' for the pro version to get rid of the viruses but I know it's like completely fake. It keeps like popping up saying there's like 38 viruses found and what nawt. But then every like couple minutes it will open Internet Explorer (Which I use FF and Google Chrome I never use IE) when nothing is even allowed to open in the first place and it'll like send me to all these porn and Viagra websites.
I tried Avast which I some how got to finally open (I think it was because I immediately opened it as soon as these things started because last time it happened to me it wouldn't let me, and I did some scans and stuff and it didn't find anything.
Please is there any way to fix this I don't want to have to completely clear my computer and stuff again I have tons of not backed up photos/videos/music.
Thethetheluis
Posts Posts : 22
Joined Joined : 2009-12-02
Points Points : 25912
Re: Please help me with my virus problem!
Post by Thethetheluis on 2nd December 2009, 7:01 am
Also I'm on my "Guest" profile right now because somehow it is working just fine.
Thethetheluis
Posts Posts : 22
Post by Belahzur on 2nd December 2009, 8:38 pm
Points Points : 245111
Post by Thethetheluis on 3rd December 2009, 2:31 am
Scan saved at 6:30:56 PM, on 12/2/2009
MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
C:\Program Files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe
C:\PROGRA~1\hpq\Shared\HPQTOA~1.EXE
C:\Program Files\Windows Live\Contacts\wlcomm.exe
C:\WINDOWS\system32\taskmgr.exe
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O2 - BHO: Ask Toolbar BHO - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files\Ask.com\GenericAskToolbar.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: Ask Toolbar - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files\Ask.com\GenericAskToolbar.dll
O4 - HKLM\..\Run: [hpWirelessAssistant] C:\Program Files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe
O4 - HKLM\..\Run: [aodsrxvh] C:\Documents and Settings\luis castro\Local Settings\Application Data\rrgofl\vvgwsysguard.exe
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [aodsrxvh] C:\Documents and Settings\luis castro\Local Settings\Application Data\rrgofl\vvgwsysguard.exe
O4 - HKUS\S-1-5-21-2996054860-4211420795-2740701291-501\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime (User 'Guest')
O4 - HKUS\S-1-5-21-2996054860-4211420795-2740701291-501\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background (User 'Guest')
O8 - Extra context menu item: &Google Search - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmsearch.html
O8 - Extra context menu item: &Translate English Word - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmwordtrans.html
O8 - Extra context menu item: Backward Links - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmbacklinks.html
O8 - Extra context menu item: Cached Snapshot of Page - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmcache.html
O8 - Extra context menu item: Similar Pages - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmsimilar.html
O8 - Extra context menu item: Translate Page into English - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmtrans.html
O14 - IERESET.INF: START_PAGE_URL=http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=Q106&bd=pavilion&pf=laptop
O23 - Service: GameConsoleService - WildTangent, Inc. - C:\Program Files\WildTangent\Apps\HP Game Console\GameConsoleService.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
End of file - 6564 bytes
Thethetheluis
Posts Posts : 22
Post by Thethetheluis on 3rd December 2009, 2:22 pm
Sorry to bump this thread but I really need help here don't leave me hangin'
Thethetheluis
Posts Posts : 22
Post by Belahzur on 3rd December 2009, 9:04 pm
Post by Thethetheluis on 4th December 2009, 2:23 am
Ok I tried it and the thing that comes up during startup stopped and I can now open stuff but I went to a webpage and (and this has only happened once and didn't like harrase me about it but like it popped up on a webpage as a virus protector iv never heard of and told me i had a crap load of viruses but i just closed it
Thethetheluis
Posts Posts : 22
Post by Thethetheluis on 4th December 2009, 3:45 am
Oh and also how do you suggest I prevent this next time? I have avast but it didn't say anything about it and when it scanned it didn't find anything.
Thethetheluis
Posts Posts : 22
Post by Belahzur on 5th December 2009, 1:20 am
Can you post a new Hijack This log please? Smile
Post by Thethetheluis on 5th December 2009, 5:21 am
Scan saved at 9:20:51 PM, on 12/4/2009
C:\Documents and Settings\luis castro\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
C:\Program Files\iTunes\iTunes.exe
End of file - 6177 bytes
Thethetheluis
Posts Posts : 22
Post by Belahzur on 5th December 2009, 4:18 pm
Doesn't look too bad.
Post by Thethetheluis on 5th December 2009, 9:25 pm
Wait I have to download ANOTHER program? What is so important I thought you said nothing was wrong.
Thethetheluis
Posts Posts : 22
Post by Belahzur on 6th December 2009, 1:15 am
This infection can pack more than what is showing, it will go as far as infected your system files so we need to check they are ok.
Post by Thethetheluis on 6th December 2009, 4:39 am
DDS (Ver_09-12-01.01) - NTFSx86
Run by luis castro at 20:37:45.03 on Sat 12/05/2009
Internet Explorer: 6.0.2900.5512
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.382.92 [GMT -8:00]
AV: avast! antivirus 4.8.1351 [VPS 091104-1] *On-access scanning disabled* (Outdated) {7591DB91-41F0-48A3-B128-1A293FD8233D}
svchost.exe
svchost.exe
svchost.exe
svchost.exe
C:\Documents and Settings\luis castro\My Documents\Downloads\dds.scr
mDefault_Page_URL = [You must be registered and logged in to see this link.]
BHO: AcroIEHlprObj Class: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\adobe\acrobat 6.0\reader\activex\AcroIEHelper.dll
BHO: RealPlayer Download and Record Plugin for Internet Explorer: {3049c3e9-b461-4bc5-8870-4c09146192ca} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\googletoolbar1.dll
TB: &Google: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\googletoolbar1.dll
TB: {C4069E3A-68F1-403E-B40E-20066696354B} - No File
TB: {D4027C7F-154A-4066-A1AD-4243D8127440} - No File
uRun: [msnmsgr] "c:\program files\windows live\messenger\msnmsgr.exe" /background
mRun: [hpWirelessAssistant] c:\program files\hpq\hp wireless assistant\HP Wireless Assistant.exe
IE: &Google Search - c:\program files\google\GoogleToolbar1.dll/cmsearch.html
IE: &Translate English Word - c:\program files\google\GoogleToolbar1.dll/cmwordtrans.html
IE: Backward Links - c:\program files\google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\google\GoogleToolbar1.dll/cmcache.html
IE: Similar Pages - c:\program files\google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate Page into English - c:\program files\google\GoogleToolbar1.dll/cmtrans.html
DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\progra~1\common~1\skype\SKYPE4~1.DLL
Notify: AtiExtEvent - Ati2evxx.dll
FF - ProfilePath - c:\docume~1\luisca~1\applic~1\mozilla\firefox\profiles\i271sulc.default\
FF - component: c:\program files\real\realplayer\browserrecord\firefox\ext\components\nprpffbrowserrecordext.dll
FF - plugin: c:\documents and settings\luis castro\local settings\application data\google\update\1.2.183.13\npGoogleOneClick8.dll
FF - plugin: c:\program files\google\update\1.2.183.13\npGoogleOneClick8.dll
---- FIREFOX POLICIES ----
c:\program files\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl3.rsa_seed_sha", true);
R1 aswSP;avast! Self Protection;c:\windows\system32\drivers\aswSP.sys [2009-9-18 114768]
R2 aswFsBlk;aswFsBlk;c:\windows\system32\drivers\aswFsBlk.sys [2009-9-18 20560]
R3 HSFHWATI;HSFHWATI;c:\windows\system32\drivers\HSFHWATI.sys [2005-8-22 231424]
S2 gupdate;Google Update Service (gupdate);c:\program files\google\update\GoogleUpdate.exe [2009-10-6 133104]
S4 avast! Antivirus;avast! Antivirus;c:\program files\alwil software\avast4\ashServ.exe [2009-9-18 138680]
S4 avast! Mail Scanner;avast! Mail Scanner;c:\program files\alwil software\avast4\ashMaiSv.exe [2009-9-18 254040]
S4 avast! Web Scanner;avast! Web Scanner;c:\program files\alwil software\avast4\ashWebSv.exe [2009-9-18 352920]
2009-12-04 02:03:23 0 d-----w- c:\docume~1\luisca~1\applic~1\Malwarebytes
2009-12-04 02:03:19 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-12-04 02:03:17 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-12-04 02:03:17 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-12-04 02:03:17 0 d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-12-03 02:30:14 0 d-----w- c:\program files\Trend Micro
2009-11-22 18:47:43 512000 ------w- c:\windows\system32\dllcache\jscript.dll
2009-11-21 18:45:19 0 d-----w- c:\windows\system32\scripting
2009-11-21 18:45:18 0 d-----w- c:\windows\system32\en
2009-11-21 18:45:18 0 d-----w- c:\windows\l2schemas
2009-11-21 18:45:17 0 d-----w- c:\windows\system32\bits
2009-11-21 18:39:57 0 d-----w- c:\windows\network diagnostic
2009-11-21 18:34:32 0 d-----w- c:\windows\EHome
2009-11-18 03:25:26 644400 ----a-w- c:\windows\system32\mscomct2.ocx
2009-11-15 07:07:31 0 d-----w- c:\program files\Windows Media Connect 2
2009-11-15 07:02:59 0 d-----w- c:\windows\system32\LogFiles
2009-11-11 02:41:54 0 d-----w- c:\windows\pss
2009-11-07 21:18:20 552 ----a-w- c:\windows\system32\d3d8caps.dat
2009-11-06 15:13:02 0 d-----w- c:\windows\system32\wbem\Repository
2009-11-06 05:42:02 1324 ----a-w- c:\windows\system32\d3d9caps.dat
2009-12-05 00:21:28 96512 ----a-w- c:\windows\system32\drivers\atapi.sys
2009-12-05 00:21:28 96512 ----a-w- c:\windows\system32\dllcache\atapi.sys
2009-10-29 02:54:25 63 ----a-w- c:\documents and settings\luis castro\jagex_runescape_preferences2.dat
2009-10-29 02:50:02 38 ----a-w- c:\documents and settings\luis castro\jagex_runescape_preferences.dat
2009-10-19 23:53:44 3070976 ------w- c:\windows\system32\dllcache\mshtml.dll
2009-10-14 14:05:02 49168 ---ha-w- c:\windows\system32\mlfcache.dat
2009-09-25 05:37:11 667136 ----a-w- c:\windows\system32\wininet.dll
2009-09-25 05:37:11 667136 ------w- c:\windows\system32\dllcache\wininet.dll
2009-09-25 05:37:11 627712 ------w- c:\windows\system32\dllcache\urlmon.dll
2009-09-25 05:37:10 1509888 ------w- c:\windows\system32\dllcache\shdocvw.dll
2009-09-25 05:37:09 81920 ----a-w- c:\windows\system32\ieencode.dll
2009-09-25 05:37:09 81920 ------w- c:\windows\system32\dllcache\ieencode.dll
2009-09-18 13:21:37 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-09-11 14:18:39 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-11 14:18:39 136192 ------w- c:\windows\system32\dllcache\msv1_0.dll
2006-08-01 06:59:36 22 --sha-w- c:\windows\sminst\HPCD.SYS
============= FINISH: 20:38:37.23 ===============
Thethetheluis
Posts Posts : 22
Install Date: 9/17/2009 11:45:32 PM
System Uptime: 12/5/2009 11:47:09 AM (9 hours ago)
Motherboard: Hewlett-Packard | | 30AE
Processor: Mobile AMD Sempron(tm) Processor 3300+ | U23 | 1989/mhz
C: is FIXED (NTFS) - 47 GiB total, 18.368 GiB free.
D: is FIXED (FAT32) - 8 GiB total, 0.426 GiB free.
E: is CDROM ()
F: is CDROM ()
Class GUID: {4D36E972-E325-11CE-BFC1-08002BE10318}
Description: Realtek RTL8139/810x Family Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_30A4103C&REV_10\4&13826118&0&30A4
Manufacturer: Realtek Semiconductor Corp.
Name: Realtek RTL8139/810x Family Fast Ethernet NIC
PNP Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_30A4103C&REV_10\4&13826118&0&30A4
Service: RTL8023xp
RP1: 11/10/2009 7:23:52 PM - System Checkpoint
RP2: 11/11/2009 1:29:53 AM - Software Distribution Service 3.0
RP3: 11/12/2009 8:00:02 AM - System Checkpoint
RP4: 11/14/2009 10:50:30 PM - Installed Windows Media Player 10
RP5: 11/14/2009 11:01:11 PM - Software Distribution Service 3.0
RP6: 11/15/2009 1:22:44 AM - Software Distribution Service 3.0
RP7: 11/15/2009 11:33:12 PM - Software Distribution Service 3.0
RP8: 11/16/2009 6:04:20 AM - Software Distribution Service 3.0
RP9: 11/17/2009 8:18:46 PM - System Checkpoint
RP10: 11/18/2009 9:13:42 PM - System Checkpoint
RP11: 11/19/2009 9:29:59 PM - System Checkpoint
RP12: 11/21/2009 10:26:50 AM - Software Distribution Service 3.0
RP13: 11/22/2009 10:59:58 AM - System Checkpoint
RP14: 11/23/2009 12:53:28 AM - Software Distribution Service 3.0
RP15: 11/24/2009 11:29:35 AM - System Checkpoint
RP16: 11/25/2009 1:01:27 AM - Software Distribution Service 3.0
RP17: 11/26/2009 12:04:38 PM - System Checkpoint
RP18: 11/27/2009 9:48:27 PM - System Checkpoint
RP19: 11/29/2009 10:43:38 AM - System Checkpoint
RP20: 11/29/2009 6:55:09 PM - Installed Google SketchUp 7
RP21: 11/30/2009 7:28:58 PM - System Checkpoint
RP22: 12/2/2009 4:32:07 PM - System Checkpoint
RP23: 12/3/2009 5:04:18 PM - System Checkpoint
RP24: 12/4/2009 5:08:26 PM - System Checkpoint
RP25: 12/5/2009 6:05:15 PM - System Checkpoint
µTorrent
5 Card Slingo from Hewlett-Packard Laptops (remove only)
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Reader 6.0.1
Apple Application Support
Apple Mobile Device Support
Apple Software Update
Ask Toolbar
Athlon 64 Processor Driver
ATI Control Panel
ATI Display Driver
avast! Antivirus
Bejeweled 2 Deluxe from Hewlett-Packard Laptops (remove only)
Big Kahuna Reef from Hewlett-Packard Laptops (remove only)
Blackhawk Striker 2 from Hewlett-Packard Laptops (remove only)
Blasterball 2 from Hewlett-Packard Laptops (remove only)
Boggle Supreme from Hewlett-Packard Laptops (remove only)
Bonjour
Bookworm Deluxe from Hewlett-Packard Laptops (remove only)
Bounce Symphony from Hewlett-Packard Laptops (remove only)
BufferChm
Carbonite Online Backup Setup
Chuzzle Deluxe from Hewlett-Packard Laptops (remove only)
Conexant AC-Link Audio
CP_AtenaShokunin1Config
CP_CalendarTemplates1
cp_LightScribeConfig
cp_OnlineProjectsConfig
CP_Package_Basic1
CP_Package_Variety1
CP_Package_Variety2
CP_Package_Variety3
CP_Panorama1Config
cp_PosterPrintConfig
cp_UpdateProjectsConfig
Crystal Maze from Hewlett-Packard Laptops (remove only)
CueTour
Customer Experience Enhancement
Destinations
DeviceManagementQFolder
Easy Internet Sign-up
FATE from Hewlett-Packard Laptops (remove only)
Final Drive Nitro from Hewlett-Packard Laptops (remove only)
Flip Words from Hewlett-Packard Laptops (remove only)
FullDPAppQFolder
Google Chrome
Google SketchUp 7
Google Update Helper
HijackThis 2.0.2
HP Game Console and games
HP Help and Support
HP Imaging Device Functions 6.0
HP Photosmart Premier Software 6.0
HP QuickPlay 2.0
HP Rhapsody
HP Software Update
HP User Guides--System Recovery
HP User Guides 0025
HP Wireless Assistant 2.00 C1
HpSdpAppCoreApp
Insaniquarium Deluxe from Hewlett-Packard Laptops (remove only)
InstantShareDevices
iTunes
Java(TM) 6 Update 15
Jewel Quest from Hewlett-Packard Laptops (remove only)
Lemonade Tycoon 2 from Hewlett-Packard Laptops (remove only)
Lexibox Deluxe from Hewlett-Packard Laptops (remove only)
LightScribe 1.4.56.1
MagicDisc 2.7.106
Mah Jong Quest from Hewlett-Packard Laptops (remove only)
Microsoft .NET Framework 1.1
Microsoft Choice Guard
Microsoft Money 2006
Microsoft Works
Mozilla Firefox (3.5.5)
MSN
MSVCRT
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
muvee autoProducer 4.5
Oasis from Hewlett-Packard Laptops (remove only)
Office 2003 Trial Assistant
OptionalContentQFolder
PhotoGallery
Polar Bowler from Hewlett-Packard Laptops (remove only)
Polar Golfer from Hewlett-Packard Laptops (remove only)
Power Tab Editor 1.7
Puzzle Express from Hewlett-Packard Laptops (remove only)
Quick Launch Buttons 5.20 F2
Quicken 2006
QuickTime
RandMap
RealPlayer
SCRABBLE from Hewlett-Packard Laptops (remove only)
Security Update for Windows XP (KB961371-v2)
Security Update for Windows XP (KB974455)
Segoe UI
SkinsHP1
Skype™ 4.1
Slingo Deluxe from Hewlett-Packard Laptops (remove only)
Slyder from Hewlett-Packard Laptops (remove only)
Snowboard SuperJam
Soft Data Fax Modem with SmartCP
Sonic Audio Module
Sonic Copy Module
Sonic Data Module
Sonic Express Labeler
Sonic MyDVD Plus
Sonic Update Manager
Sonic_PrimoSDK
Super Granny from Hewlett-Packard Laptops (remove only)
Synaptics Pointing Device Driver
Texas Instruments PCIxx21/x515/xx12 drivers.
TIPCI
TourSetup
Tradewinds Classic
Tradewinds from Hewlett-Packard Laptops (remove only)
Unload
Update for Windows XP (KB961503)
Update for Windows XP (KB976749)
Warcraft III
WebFldrs XP
WildTangent Web Driver
Windows Live Call
Windows Live Essentials
Windows Live Messenger
Windows Live Upload Tool
Windows XP Service Pack 3
Wireless Home Network Setup
Zuma Deluxe from Hewlett-Packard Laptops (remove only)
12/3/2009 6:14:48 PM, error: sr [1] - The System Restore filter encountered the unexpected error '0xC0000001' while processing the file '' on the volume 'HarddiskVolume1'. It has stopped monitoring the volume.
12/3/2009 6:14:48 PM, error: Ftdisk [49] - Configuring the Page file for crash dump failed. Make sure there is a page file on the boot partition and that is large enough to contain all physical memory.
12/3/2009 6:14:48 PM, error: Ftdisk [45] - The system could not sucessfully load the crash dump driver.
12/3/2009 6:14:47 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: AliIde IntelIde Pcmcia ViaIde
12/1/2009 6:09:03 AM, error: Dhcp [1001] - Your computer was not assigned an address from the network (by the DHCP Server) for the Network Card with network address 0014A578C16C. The following error occurred: The operation was canceled by the user. . Your computer will continue to try and obtain an address on its own from the network address (DHCP) server.
11/30/2009 9:04:55 PM, error: SideBySide [59] - Resolve Partial Assembly failed for Microsoft.VC80.MFCLOC. Reference error message: The referenced assembly is not installed on your system. .
11/30/2009 9:04:55 PM, error: SideBySide [59] - Generate Activation Context failed for C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_b77cec8e\MFC80U.DLL. Reference error message: The operation completed successfully. .
11/30/2009 9:04:55 PM, error: SideBySide [32] - Dependent Assembly Microsoft.VC80.MFCLOC could not be found and Last Error was The referenced assembly is not installed on your system.
Thethetheluis
Posts Posts : 22
Post by Belahzur on 6th December 2009, 12:04 pm
    µTorrent
    Ask Toolbar
  • Download combofix from here
Post by Thethetheluis on 6th December 2009, 6:41 pm
Wait so Utorrent has a virus???????????
Thethetheluis
Posts Posts : 22
Post by Belahzur on 7th December 2009, 1:19 am
No, but P2P clients are dangerous, anything you download could be infected, so we ask all P2P programs be removed.
Post by Thethetheluis on 7th December 2009, 1:44 am
Well can't I just scan the downloaded files for viruses?
Thethetheluis
Posts Posts : 22
Post by Belahzur on 7th December 2009, 8:59 pm
Yes, but your missing the point. Virus scanners only detect what they can, they wont detect new malware if they don't get a sample before it infects someone and spreads worldwide.
Post by Thethetheluis on 8th December 2009, 2:45 am
Ok fine I'll do it. Sad tearing
Also if you guys have all these programs that came from your website why don't you guys just make one program that does it all instead of multiple programs.
Also: When I tried to remove Ask Toolbar I got this:
Error 1905.Module C:/Program
Files/Ask.com/GenericAskToolbar.dll failed to
unregister. HRESULT-2147220472. Contact your
support personnel.
Thethetheluis
Posts Posts : 22
Post by Thethetheluis on 8th December 2009, 2:47 am
NVM It said that but what I didn't noticed is it still deleted it so it's all good.
Thethetheluis
Posts Posts : 22
Post by Thethetheluis on 8th December 2009, 3:26 am
ComboFix 09-12-07.05 - luis castro 12/07/2009 19:13.1.1 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.382.166 [GMT -8:00]
Running from: c:\documents and settings\luis castro\Desktop\Combo-Fix.exe
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
c:\documents and settings\luis castro\Local Settings\Application Data\rrgofl
c:\documents and settings\luis castro\Local Settings\Application Data\rrgofl\vvgwsysguard.exe
c:\windows\system32\_000006_.tmp.dll
c:\windows\system32\_000007_.tmp.dll
c:\windows\system32\_000008_.tmp.dll
c:\windows\system32\_000009_.tmp.dll
c:\windows\system32\_000010_.tmp.dll
c:\windows\system32\_000022_.tmp.dll
c:\windows\system32\_000023_.tmp.dll
c:\windows\system32\_000024_.tmp.dll
c:\windows\system32\_000025_.tmp.dll
D:\Autorun.inf
Infected copy of c:\windows\system32\DRIVERS\atapi.sys was found and disinfected
Restored copy from - Kitty ate it :p
((((((((((((((((((((((((( Files Created from 2009-11-08 to 2009-12-08 )))))))))))))))))))))))))))))))
2009-12-04 02:03 . 2009-12-04 02:03 -------- d-----w- c:\documents and settings\luis castro\Application Data\Malwarebytes
2009-12-04 02:03 . 2009-12-04 00:14 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-12-04 02:03 . 2009-12-04 02:03 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-12-04 02:03 . 2009-12-04 02:03 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-12-04 02:03 . 2009-12-04 00:13 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-12-03 06:53 . 2009-12-03 06:53 -------- d-----w- c:\documents and settings\luis castro\Local Settings\Application Data\Identities
2009-12-03 02:30 . 2009-12-03 02:30 -------- d-----w- c:\program files\Trend Micro
2009-12-02 06:32 . 2009-12-02 06:32 -------- d-----w- c:\documents and settings\Guest\Local Settings\Application Data\Mozilla
2009-12-02 06:30 . 2009-12-03 00:05 -------- d-----w- c:\documents and settings\Guest\Tracing
2009-11-22 18:47 . 2009-08-13 15:16 512000 ------w- c:\windows\system32\dllcache\jscript.dll
2009-11-21 18:45 . 2009-11-21 18:45 -------- d-----w- c:\windows\system32\scripting
2009-11-21 18:45 . 2009-11-21 18:45 -------- d-----w- c:\windows\l2schemas
2009-11-21 18:45 . 2009-11-21 18:45 -------- d-----w- c:\windows\system32\en
2009-11-21 18:45 . 2009-11-21 18:45 -------- d-----w- c:\windows\system32\bits
2009-11-21 18:34 . 2009-11-21 18:34 -------- d-----w- c:\windows\EHome
2009-11-15 07:15 . 2008-04-14 00:12 26624 ----a-w- c:\documents and settings\LocalService\Application Data\Microsoft\UPnP Device Host\upnphost\udhisapi.dll
2009-11-15 07:07 . 2009-11-15 07:07 -------- d-----w- c:\program files\Windows Media Connect 2
2009-11-15 07:02 . 2009-11-15 07:05 -------- d-----w- c:\windows\system32\drivers\UMDF
2009-11-15 07:02 . 2009-11-15 07:02 -------- d-----w- c:\windows\system32\LogFiles
2009-12-08 02:46 . 2006-02-28 04:51 -------- d-----w- c:\program files\Java
2009-12-08 02:42 . 2009-09-20 19:54 -------- d-----w- c:\program files\Ask.com
2009-12-08 02:41 . 2009-09-20 19:50 -------- d-----w- c:\documents and settings\luis castro\Application Data\uTorrent
2009-12-05 10:42 . 2009-09-18 13:26 -------- d-----w- c:\documents and settings\luis castro\Application Data\HP
2009-12-05 00:21 . 2004-08-04 00:59 96512 ----a-w- c:\windows\system32\drivers\atapi.sys
2009-11-30 03:21 . 2009-09-20 04:58 -------- d-----w- c:\documents and settings\luis castro\Application Data\Skype
2009-11-30 02:55 . 2006-02-28 05:42 -------- d-----w- c:\program files\Google
2009-11-30 00:06 . 2009-09-20 04:59 -------- d-----w- c:\documents and settings\luis castro\Application Data\skypePM
2009-11-28 22:15 . 2009-11-06 05:42 1324 ----a-w- c:\windows\system32\d3d9caps.dat
2009-11-23 22:31 . 2009-09-30 23:42 -------- d-----w- c:\program files\Warcraft III
2009-11-21 18:48 . 2004-08-07 13:10 79395 ----a-w- c:\windows\pchealth\helpctr\OfflineCache\index.dat
2009-11-15 23:04 . 2009-10-08 22:35 -------- d-----w- c:\program files\Empire Earth
2009-11-13 00:00 . 2006-02-28 05:36 -------- d-----w- c:\program files\Common Files\Symantec Shared
2009-11-07 21:18 . 2009-11-07 21:18 552 ----a-w- c:\windows\system32\d3d8caps.dat
2009-11-06 15:12 . 2009-11-04 06:09 -------- d-----w- c:\program files\BitZipper
2009-11-04 06:10 . 2009-11-04 06:10 -------- d-----w- c:\documents and settings\luis castro\Application Data\BitZipper
2009-11-01 18:23 . 2009-10-10 04:50 62728 ----a-w- c:\documents and settings\Guest\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-10-29 02:54 . 2009-10-29 02:49 63 ----a-w- c:\documents and settings\luis castro\jagex_runescape_preferences2.dat
2009-10-29 02:50 . 2009-10-29 02:41 38 ----a-w- c:\documents and settings\luis castro\jagex_runescape_preferences.dat
2009-10-27 13:52 . 2009-10-27 13:52 -------- d-----w- c:\documents and settings\luis castro\Application Data\Sonic
2009-10-25 18:59 . 2009-09-21 05:57 -------- d-----w- c:\documents and settings\luis castro\Application Data\Apple Computer
2009-10-14 14:05 . 2009-10-14 14:05 49168 ---ha-w- c:\windows\system32\mlfcache.dat
2009-10-13 00:38 . 2009-10-08 22:31 -------- d-----w- c:\documents and settings\All Users\Application Data\WinZip
2009-10-11 16:45 . 2009-09-18 06:46 62728 ----a-w- c:\documents and settings\luis castro\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-10-11 00:49 . 2009-10-11 00:49 3310 ----a-r- c:\documents and settings\luis castro\Application Data\Microsoft\Installer\{6B3CA80E-6AC0-4725-BABF-9B0FEF880CB3}\_16496df1.exe
2009-10-11 00:49 . 2009-10-11 00:49 1078 ----a-r- c:\documents and settings\luis castro\Application Data\Microsoft\Installer\{6B3CA80E-6AC0-4725-BABF-9B0FEF880CB3}\_69525f90.exe
2009-10-11 00:49 . 2009-10-11 00:49 1078 ----a-r- c:\documents and settings\luis castro\Application Data\Microsoft\Installer\{6B3CA80E-6AC0-4725-BABF-9B0FEF880CB3}\_4ae13d6c.exe
2009-10-11 00:49 . 2009-10-11 00:49 1078 ----a-r- c:\documents and settings\luis castro\Application Data\Microsoft\Installer\{6B3CA80E-6AC0-4725-BABF-9B0FEF880CB3}\_2cd672ae.exe
2009-10-11 00:49 . 2009-10-11 00:49 1078 ----a-r- c:\documents and settings\luis castro\Application Data\Microsoft\Installer\{6B3CA80E-6AC0-4725-BABF-9B0FEF880CB3}\_294823.exe
2009-10-11 00:49 . 2009-10-11 00:49 1078 ----a-r- c:\documents and settings\luis castro\Application Data\Microsoft\Installer\{6B3CA80E-6AC0-4725-BABF-9B0FEF880CB3}\_18be6784.exe
2009-10-11 00:49 . 2009-10-11 00:49 -------- d-----w- c:\program files\Power Tab Software
2009-10-11 00:37 . 2009-10-11 00:37 -------- d-----w- c:\documents and settings\luis castro\Application Data\AdobeUM
2009-10-11 00:37 . 2009-10-11 00:37 -------- d-----w- c:\program files\Common Files\Adobe
2009-10-10 04:55 . 2009-10-10 04:50 128 ----a-w- c:\documents and settings\Guest\Local Settings\Application Data\fusioncache.dat
2009-10-04 16:25 . 2009-10-04 16:25 1961720 ----a-w- c:\documents and settings\luis castro\Application Data\Macromedia\Flash Player\[You must be registered and logged in to see this link.]
2009-09-25 05:37 . 2004-08-04 08:00 667136 ----a-w- c:\windows\system32\wininet.dll
2009-09-25 05:37 . 2004-08-04 08:00 81920 ----a-w- c:\windows\system32\ieencode.dll
2009-09-20 04:59 . 2009-09-20 04:59 56 ---ha-w- c:\windows\system32\ezsidmv.dat
2009-09-19 18:21 . 2009-09-19 18:20 15446136 ----a-w- c:\documents and settings\All Users\Application Data\WildTangent\My HP Game Console\Downloads\Installers\SetupGamesClient.exe
2009-09-18 13:21 . 2009-09-18 13:21 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-09-18 06:48 . 2009-09-18 06:46 134 ----a-w- c:\documents and settings\luis castro\Local Settings\Application Data\fusioncache.dat
2009-09-11 14:18 . 2004-08-04 08:00 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-09 04:43 . 2009-09-09 04:43 79144 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 9.0.0.70\SetupAdmin.exe
2006-08-01 06:59 . 2009-09-18 05:38 22 --sha-w- c:\windows\SMINST\HPCD.SYS
"msnmsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" [2009-07-26 3883856]
"hpWirelessAssistant"="c:\program files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe" [2005-12-13 507904]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2009-10-05 198160]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Photosmart Premier Fast Start.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HP Photosmart Premier Fast Start.lnk
backup=c:\windows\pss\HP Photosmart Premier Fast Start.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^luis castro^Start Menu^Programs^Startup^MagicDisc.lnk]
path=c:\documents and settings\luis castro\Start Menu\Programs\Startup\MagicDisc.lnk
backup=c:\windows\pss\MagicDisc.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ATIPTA]
2005-11-11 05:05 344064 ----a-w- c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\avast!]
2009-08-17 16:07 81000 ----a-w- c:\progra~1\ALWILS~1\Avast4\ashDisp.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\CarboniteSetupLite]
2009-08-01 01:38 283792 ----a-w- c:\program files\Carbonite\CarbonitePreinstaller.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Cpqset]
2005-08-01 22:26 233534 ----a-w- c:\program files\HPQ\Default Settings\Cpqset.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\eabconfg.cpl]
2005-12-07 18:56 409600 ----a-w- c:\program files\HPQ\Quick Launch Buttons\eabservr.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Google Update]
2009-09-18 05:58 133104 ----atw- c:\documents and settings\luis castro\Local Settings\Application Data\Google\Update\GoogleUpdate.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HP Software Update]
2005-02-17 07:11 49152 ----a-w- c:\program files\HP\HP Software Update\hpwuSchd2.exe
2009-09-09 04:09 305440 ----a-w- c:\program files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\msnmsgr]
2009-07-26 23:44 3883856 ----a-w- c:\program files\Windows Live\Messenger\msnmsgr.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QPService]
2005-12-12 19:39 94208 ----a-w- c:\program files\HP\QuickPlay\QPService.exe
2009-09-05 08:54 417792 ----a-w- c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RecGuard]
2005-10-11 18:23 1187840 ----a-w- c:\windows\SMINST\Recguard.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SynTPEnh]
2005-06-19 20:50 729178 ----a-w- c:\program files\Synaptics\SynTP\SynTPEnh.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\TkBellExe]
2009-10-05 06:20 198160 ----a-w- c:\program files\Common Files\Real\Update_OB\realsched.exe
"c:\\Program Files\\Empire Earth\\Empire Earth.exe"=
R1 aswSP;avast! Self Protection;c:\windows\system32\drivers\aswSP.sys [9/18/2009 6:16 AM 114768]
R2 aswFsBlk;aswFsBlk;c:\windows\system32\drivers\aswFsBlk.sys [9/18/2009 6:16 AM 20560]
R3 HSFHWATI;HSFHWATI;c:\windows\system32\drivers\HSFHWATI.sys [8/22/2005 1:06 AM 231424]
S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [10/6/2009 7:47 PM 133104]
IE: &Google Search - c:\program files\Google\GoogleToolbar1.dll/cmsearch.html
IE: &Translate English Word - c:\program files\Google\GoogleToolbar1.dll/cmwordtrans.html
IE: Backward Links - c:\program files\Google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\Google\GoogleToolbar1.dll/cmcache.html
IE: Similar Pages - c:\program files\Google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate Page into English - c:\program files\Google\GoogleToolbar1.dll/cmtrans.html
FF - ProfilePath - c:\documents and settings\luis castro\Application Data\Mozilla\Firefox\Profiles\i271sulc.default\
FF - component: c:\program files\Real\RealPlayer\browserrecord\firefox\ext\components\nprpffbrowserrecordext.dll
FF - plugin: c:\documents and settings\luis castro\Local Settings\Application Data\Google\Update\1.2.183.13\npGoogleOneClick8.dll
FF - plugin: c:\program files\Google\Update\1.2.183.13\npGoogleOneClick8.dll
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl3.rsa_seed_sha", true);
WebBrowser-{D4027C7F-154A-4066-A1AD-4243D8127440} - (no file)
MSConfigStartUp-ccApp - c:\program files\Common Files\Symantec Shared\ccApp.exe
MSConfigStartUp-SunJavaUpdateSched - c:\program files\Java\jre6\bin\jusched.exe
AddRemove-HP Rhapsody - c:\progra~1\HPRHAP~1\Unwise32.exe
AddRemove-Microsoft Interactive Training - c:\windows\IsUninst.exe -fc:\windows\orun32.isu
Rootkit scan 2009-12-07 19:22
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
- - - - - - - > 'winlogon.exe'(616)
Completion time: 2009-12-07 19:25
ComboFix-quarantined-files.txt 2009-12-08 03:24
Pre-Run: 19,846,860,800 bytes free
Post-Run: 21,488,783,360 bytes free
Current=3 Default=3 Failed=1 LastKnownGood=4 Sets=1,2,3,4
- - End Of File - - 7A2CDC1CAACD0512AD2C3AC4A1CE4E57
Thethetheluis
Posts Posts : 22
Post by Belahzur on 8th December 2009, 9:31 pm
  • Save it to your desktop.
    :files
  • Close OTMoveIt
Please post the OTMoveIt log.
Post by Thethetheluis on 9th December 2009, 12:15 am
========== FILES ==========
c:\program files\Ask.com folder moved successfully.
c:\documents and settings\luis castro\Application Data\uTorrent folder moved successfully.
c:\program files\BitZipper\language folder moved successfully.
c:\program files\BitZipper\help folder moved successfully.
c:\program files\BitZipper\data folder moved successfully.
c:\program files\BitZipper folder moved successfully.
c:\documents and settings\luis castro\Application Data\BitZipper folder moved successfully.
OTM by OldTimer - Version 3.1.2.2 log created on 12082009_161422
Thethetheluis
Posts Posts : 22
Post by Belahzur on 9th December 2009, 12:43 am
ComboFix /uninstall
Post by Thethetheluis on 9th December 2009, 2:03 am
Well, thanks for the help SmileSmileSmileSmile
Also what programs should I keep and what can I get rid of? out of all the programs I had to download.
Thethetheluis
Posts Posts : 22
Post by Belahzur on 9th December 2009, 3:02 pm
Delete everything, but keep MBAM.
Post by Thethetheluis on 9th December 2009, 3:08 pm
Ok that's what I was thinkin. Thanks for the help Smile
Thethetheluis
Posts Posts : 22
