Antivirus System PRO--removed it via DOS so easy, but will it come back?
Post by m00nsh1ne on 2nd December 2009, 2:25 am
I got hit by the AVS PRO rogue yesterday and was freaking out as I couldn't open task manager, etc. (I am sure you are familiar with its irritating traits) and I removed it by doing this:
First,
When the large window trying to prompt you to purchase it came up, I right clicked and chose Properties. I wrote down the filename path (it started with [You must be registered and logged in to see this link.] instead of [You must be registered and logged in to see this link.]
Then I restarted my computer (bad probably but i had no choice at the time) and before the AVS PRO could start up I quickly right clicked on the task bar and got the task manager up. I found what I suspected was the process and stopped it.
Then I opened up Command Prompt. I found the folder called onugrl and the file called rfgsysguard.exe in my system32 subdirectory and deleted it. Then I rmdir the folder "onugrl" and rebooted. I also ran Malwarebytes' software and it removed the registry key. So far, so good, although I downloaded the new version of adobe after joining the forum and now the adobe downloader screen keeps popping up randomly so perhaps my troubles are not over? Seems like it all worked out too easily...please let me know if you know more about this malware, if its going to damage my computer if I do not do some of these more complicated fixes? Thank you I am very happy to have found this site and will tell everyone I know!!!
Betsy
m00nsh1ne
Posts Posts : 16
Joined Joined : 2009-12-02
Protection Protection : AVG 8.5
Points Points : 25864
Re: Antivirus System PRO--removed it via DOS so easy, but will it come back?
Post by Dr Jay on 2nd December 2009, 4:07 am
Posts Posts : 14314
Points Points : 302999
Post by m00nsh1ne on 2nd December 2009, 12:27 pm
ComboFix 09-12-02.01 - Betsy 12/02/2009 7:14.1.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.1015.380 [GMT -5:00]
Running from: c:\documents and settings\Betsy\desktop\commy.exe
AV: AVG Anti-Virus Free *On-access scanning disabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
c:\recycler\S-1-5-21-783013601-2911902795-2016744192-1003
c:\recycler\S-1-5-21-783013601-2911902795-2016744192-1003\desktop.ini
c:\recycler\S-1-5-21-783013601-2911902795-2016744192-1003\INFO2
((((((((((((((((((((((((( Files Created from 2009-11-02 to 2009-12-02 )))))))))))))))))))))))))))))))
2009-12-02 01:54 . 2009-10-10 07:07 38208 ----a-w- c:\documents and settings\Betsy\Application Data\Macromedia\Flash Player\[You must be registered and logged in to see this link.]
2009-12-02 01:54 . 2009-10-10 07:07 38208 ----a-w- c:\documents and settings\Default User\Application Data\Macromedia\Flash Player\[You must be registered and logged in to see this link.]
2009-12-02 01:54 . 2009-12-02 01:54 -------- d-----w- c:\program files\Common Files\Adobe AIR
2009-12-02 01:53 . 2009-12-02 01:53 86016 ----a-w- c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\arh.exe
2009-12-01 01:33 . 2009-12-01 01:33 -------- d-----w- c:\documents and settings\Betsy\Local Settings\Application Data\Cooliris
2009-12-01 01:33 . 2009-10-20 18:33 545280 ----a-w- c:\documents and settings\Betsy\Application Data\Mozilla\Firefox\Profiles\l0fhdo3q.default\extensions\piclens@cooliris.com\libs\PicLensHelper.exe
2009-12-01 01:33 . 2009-10-20 18:33 103424 ----a-w- c:\documents and settings\Betsy\Application Data\Mozilla\Firefox\Profiles\l0fhdo3q.default\extensions\piclens@cooliris.com\libs\pixomatic.dll
2009-12-01 01:33 . 2009-10-20 18:33 4716544 ----a-w- c:\documents and settings\Betsy\Application Data\Mozilla\Firefox\Profiles\l0fhdo3q.default\extensions\piclens@cooliris.com\components\cooliris.dll
2009-12-01 01:33 . 2009-10-20 18:33 344064 ----a-w- c:\documents and settings\Betsy\Application Data\Mozilla\Firefox\Profiles\l0fhdo3q.default\extensions\piclens@cooliris.com\libs\LaunchCooliris.exe
2009-12-01 01:33 . 2009-10-20 18:33 153600 ----a-w- c:\documents and settings\Betsy\Application Data\Mozilla\Firefox\Profiles\l0fhdo3q.default\extensions\piclens@cooliris.com\plugins\npcoolirisplugin.dll
2009-12-01 00:36 . 2009-12-01 00:36 -------- d-----w- c:\documents and settings\Kids\Application Data\Malwarebytes
2009-11-30 15:48 . 2009-11-30 20:33 -------- d-----w- c:\program files\Spyware Doctor
2009-11-30 15:33 . 2009-10-30 16:11 233136 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-11-30 15:32 . 2009-11-09 16:20 207792 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-11-30 15:32 . 2009-10-06 21:31 87784 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2009-11-30 15:32 . 2009-09-03 14:45 70408 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2009-11-30 15:32 . 2009-11-30 15:32 -------- d-----w- c:\program files\Common Files\PC Tools
2009-11-30 15:32 . 2009-11-30 15:32 -------- d-----w- c:\documents and settings\Betsy\Application Data\PC Tools
2009-11-30 15:32 . 2009-11-30 15:32 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Tools
2009-11-30 15:31 . 2009-11-30 20:33 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-11-30 14:44 . 2009-11-30 14:44 -------- d-----w- c:\documents and settings\Betsy\Application Data\Malwarebytes
2009-11-30 14:42 . 2009-09-10 19:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-11-30 14:42 . 2009-11-30 14:42 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-30 14:42 . 2009-11-30 14:42 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-11-30 14:42 . 2009-09-10 19:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-11-28 18:11 . 2008-04-14 12:00 26624 ----a-w- c:\documents and settings\LocalService\Application Data\Microsoft\UPnP Device Host\upnphost\udhisapi.dll
2009-11-28 13:51 . 2009-12-02 04:08 0 ----a-w- c:\documents and settings\Betsy\Local Settings\Application Data\prvlcl.dat
2009-11-27 02:44 . 2009-11-24 22:38 1699384 ----a-w- c:\documents and settings\Kris\Application Data\PictureMover\EN-US\Presentation.dll
2009-11-27 02:44 . 2009-11-27 02:44 -------- d-----w- c:\documents and settings\Kris\Application Data\PictureMover
2009-11-27 02:44 . 2009-11-24 22:39 12160056 ----a-w- c:\documents and settings\Kris\Application Data\PictureMover\Bin\Core.dll
2009-11-24 22:38 . 2009-11-24 22:39 12160056 ----a-w- c:\documents and settings\All Users\Application Data\PictureMover\Bin\Core.dll
2009-11-24 22:38 . 2009-11-24 22:38 1249336 ----a-w- c:\documents and settings\All Users\Application Data\PictureMover\Bin\AgentScr.scr
2009-11-24 22:38 . 2009-11-24 22:38 1699384 ----a-w- c:\documents and settings\All Users\Application Data\PictureMover\EN-US\Presentation.dll
2009-11-17 01:01 . 2009-11-24 22:38 1699384 ----a-w- c:\documents and settings\Kids\Application Data\PictureMover\EN-US\Presentation.dll
2009-11-17 01:01 . 2009-11-24 22:39 12160056 ----a-w- c:\documents and settings\Kids\Application Data\PictureMover\Bin\Core.dll
2009-11-17 01:01 . 2009-11-17 01:01 -------- d-----w- c:\documents and settings\Kids\Application Data\PictureMover
2009-11-14 19:58 . 2009-11-14 19:58 152576 ----a-w- c:\documents and settings\Betsy\Application Data\Sun\Java\jre1.6.0_17\lzma.dll
2009-11-14 19:58 . 2009-11-14 19:58 79488 ----a-w- c:\documents and settings\Betsy\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
2009-11-12 17:44 . 2009-11-12 17:44 3963648 ----a-w- c:\documents and settings\All Users\Application Data\avg9\update\backup\avgcorex.dll
2009-11-12 17:44 . 2009-11-10 14:57 4026136 ----a-w- c:\documents and settings\All Users\Application Data\avg9\update\backup\avgui.exe
2009-11-12 17:44 . 2009-11-10 14:57 2016536 ----a-w- c:\documents and settings\All Users\Application Data\avg9\update\backup\avgtray.exe
2009-11-12 17:44 . 2009-11-10 14:57 1257240 ----a-w- c:\documents and settings\All Users\Application Data\avg9\update\backup\avgfrw.exe
2009-11-12 17:44 . 2009-11-12 17:44 497944 ----a-w- c:\documents and settings\All Users\Application Data\avg9\update\backup\avgchjwx.dll
2009-11-10 14:57 . 2009-11-10 14:57 1657112 ----a-w- c:\documents and settings\All Users\Application Data\avg9\update\backup\avgupd.dll
2009-11-02 23:56 . 2009-11-04 13:05 -------- d-----w- c:\documents and settings\Betsy\Application Data\skypePM
2009-11-02 23:54 . 2009-11-04 17:58 -------- d-----w- c:\documents and settings\Betsy\Application Data\Skype
2009-12-02 12:12 . 2009-08-22 00:07 -------- d-----w- c:\documents and settings\All Users\Application Data\NOS
2009-12-02 01:55 . 2009-05-05 16:27 -------- d-----w- c:\program files\Common Files\Adobe
2009-11-27 02:44 . 2009-08-23 01:26 60664 -c--a-w- c:\documents and settings\Kris\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-11-24 22:39 . 2009-09-26 20:03 12160056 ----a-w- c:\documents and settings\Betsy\Application Data\PictureMover\Bin\Core.dll
2009-11-24 22:39 . 2008-08-13 13:11 51768 ----a-w- c:\documents and settings\All Users\Application Data\PictureMover\Bin\Proxy4WLPG.exe
2009-11-24 22:38 . 2009-09-26 20:03 1699384 ----a-w- c:\documents and settings\Betsy\Application Data\PictureMover\EN-US\Presentation.dll
2009-11-14 20:00 . 2009-09-05 14:53 -------- d-----w- c:\program files\Java
2009-11-14 13:10 . 2009-05-05 16:43 -------- d-----w- c:\documents and settings\All Users\Application Data\Microsoft Help
2009-11-10 14:57 . 2009-08-23 18:31 360584 ----a-w- c:\windows\system32\drivers\avgtdix.sys
2009-11-02 23:56 . 2009-11-02 23:56 32 ----a-w- c:\documents and settings\All Users\Application Data\ezsid.dat
2009-10-29 22:48 . 2009-08-23 18:31 12464 ----a-w- c:\windows\system32\avgrsstx.dll
2009-10-29 22:48 . 2009-08-23 18:31 28424 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
2009-10-29 22:47 . 2009-08-23 18:31 333192 ----a-w- c:\windows\system32\drivers\avgldx86.sys
2009-10-29 22:47 . 2009-10-29 22:47 -------- d-----w- c:\documents and settings\All Users\Application Data\avg9
2009-10-29 22:47 . 2009-08-23 18:30 -------- d-----w- c:\program files\AVG
2009-10-21 14:21 . 2009-10-21 14:21 -------- d-----w- c:\documents and settings\All Users\Application Data\WLInstaller
2009-10-21 13:44 . 2009-10-21 13:44 -------- d-----w- c:\program files\MSN Messenger
2009-10-21 13:15 . 2009-08-21 22:56 60664 -c--a-w- c:\documents and settings\Betsy\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-10-20 23:08 . 2009-05-05 16:33 -------- d-----w- c:\program files\Windows Live
2009-10-11 09:17 . 2009-09-05 14:53 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-10-03 21:38 . 2009-10-03 21:38 -------- d-----w- c:\program files\Microsoft Silverlight
2009-09-12 19:26 . 2009-09-12 19:26 127872 ----a-w- c:\documents and settings\Betsy\Application Data\Move Networks\uninstall.exe
2009-09-12 19:26 . 2009-06-16 06:35 4183416 ----a-w- c:\documents and settings\Betsy\Application Data\Move Networks\plugins\npqmp071503000010.dll
2009-09-11 14:18 . 2009-04-28 04:51 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-05 15:30 . 2009-09-05 15:30 152576 ----a-w- c:\documents and settings\Betsy\Application Data\Sun\Java\jre1.6.0_15\lzma.dll
2009-09-05 14:53 . 2009-09-05 14:53 152576 ----a-w- c:\documents and settings\Betsy\Application Data\Sun\Java\jre1.6.0_14\lzma.dll
2009-09-04 21:03 . 2009-04-28 04:51 58880 ----a-w- c:\windows\system32\msasn1.dll
"Eee Docking"="c:\program files\ASUS\Eee Docking\Eee Docking.exe" [2009-05-08 395776]
"MsnMsgr"="c:\program files\MSN Messenger\MsnMsgr.Exe" [2007-09-04 6856704]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2007-12-19 135168]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2007-12-19 159744]
"Persistence"="c:\windows\system32\igfxpers.exe" [2007-12-19 131072]
"AsusACPIServer"="c:\program files\EeePC\ACPI\AsAcpiSvr.exe" [2009-04-16 630784]
"AsusEPCMonitor"="c:\program files\EeePC\ACPI\AsEPCMon.exe" [2009-03-13 98304]
"AsusTray"="c:\program files\EeePC\ACPI\AsTray.exe" [2009-04-16 118784]
"IMJPMIG8.1"="c:\windows\IME\imjp8_1\IMJPMIG.EXE" [2008-04-14 208952]
"MSPY2002"="c:\windows\system32\IME\PINTLGNT\ImScInst.exe" [2008-04-14 59392]
"PHIME2002ASync"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2008-04-14 455168]
"PHIME2002A"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2008-04-14 455168]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2009-03-06 1434920]
"SynAsusAcpi"="c:\program files\Synaptics\SynTP\SynAsusAcpi.exe" [2009-03-06 79144]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-05-26 413696]
"AVG9_TRAY"="c:\progra~1\AVG\AVG9\avgtray.exe" [2009-11-12 2020120]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-10-03 35696]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-09-04 935288]
"RTHDCPL"="RTHDCPL.EXE" - c:\windows\RTHDCPL.EXE [2009-04-27 17881088]
SuperHybridEngine.lnk - c:\program files\ASUS\EeePC\Super Hybrid Engine\SuperHybridEngine.exe [2009-5-5 376832]
PictureMover.lnk - c:\program files\PictureMover\Bin\PictureMover.exe [2008-8-13 413696]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
2009-10-29 22:48 12464 ----a-w- c:\windows\system32\avgrsstx.dll
@="Driver"
"c:\\Program Files\\Windows Live\\Sync\\WindowsLiveSync.exe"=
"c:\\Program Files\\MSN Messenger\\msnmsgr.exe"=
"c:\\Program Files\\AVG\\AVG9\\avgemc.exe"=
"c:\\Program Files\\AVG\\AVG9\\avgupd.exe"=
"c:\\Program Files\\AVG\\AVG9\\avgnsx.exe"=
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [11/30/2009 10:32 AM 207792]
R1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [8/23/2009 1:31 PM 333192]
R1 AvgTdiX;AVG Free8 Network Redirector;c:\windows\system32\drivers\avgtdix.sys [8/23/2009 1:31 PM 360584]
R2 avg9emc;AVG Free E-mail Scanner;c:\program files\AVG\AVG9\avgemc.exe [10/29/2009 5:47 PM 906520]
R2 avg9wd;AVG Free WatchDog;c:\program files\AVG\AVG9\avgwdsvc.exe [10/29/2009 5:47 PM 285392]
R2 fssfltr;FssFltr;c:\windows\system32\drivers\fssfltr_tdi.sys [5/5/2009 11:39 AM 54752]
R3 L1c;NDIS Miniport Driver for Atheros AR8131/AR8132 PCI-E Ethernet Controller;c:\windows\system32\drivers\l1c51x86.sys [4/27/2009 8:59 PM 38912]
R3 uvclf;uvclf;c:\windows\system32\drivers\uvclf.sys [3/16/2009 4:27 PM 39040]
S3 Ambfilt;Ambfilt;c:\windows\system32\drivers\Ambfilt.sys [5/5/2009 11:00 AM 1684736]
S3 fsssvc;Windows Live Family Safety Service;c:\program files\Windows Live\Family Safety\fsssvc.exe [8/5/2009 9:48 PM 704864]
S3 SRS_PremiumSound_Service;SRS Labs Premium Sound;c:\windows\system32\drivers\SRS_PremiumSound_i386.sys [5/5/2009 12:16 PM 232872]
2009-11-23 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 16:34]
IE: Send to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
IE: Send To Bluetooth - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
Trusted Zone: facebook.com
Trusted Zone: insidetherevolution.org\www
FF - ProfilePath - c:\documents and settings\Betsy\Application Data\Mozilla\Firefox\Profiles\l0fhdo3q.default\
FF - component: c:\documents and settings\Betsy\Application Data\Mozilla\Firefox\Profiles\l0fhdo3q.default\extensions\piclens@cooliris.com\components\cooliris.dll
FF - component: c:\program files\AVG\AVG9\Firefox\components\avgssff.dll
FF - plugin: c:\documents and settings\Betsy\Application Data\Move Networks\plugins\npqmp071503000010.dll
FF - plugin: c:\documents and settings\Betsy\Application Data\Mozilla\Firefox\Profiles\l0fhdo3q.default\extensions\piclens@cooliris.com\plugins\npcoolirisplugin.dll
FF - plugin: c:\program files\Google\Picasa3\npPicasa3.dll
FF - plugin: c:\program files\Windows Live\Photo Gallery\NPWLPG.dll
---- FIREFOX POLICIES ----
FF - user.js: yahoo.homepage.dontask - truec:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl3.rsa_seed_sha", true);
HKCU-Run-lyrcjkes - c:\documents and settings\Betsy\Local Settings\Application Data\onugrl\rgfwsysguard.exe
HKLM-Run-lyrcjkes - c:\documents and settings\Betsy\Local Settings\Application Data\onugrl\rgfwsysguard.exe
AddRemove-HijackThis - c:\documents and settings\Betsy\My Documents\Downloads\HijackThis.exe
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files:
- - - - - - - > 'winlogon.exe'(744)
c:\windows\system32\igfxdev.dll
Completion time: 2009-12-02 07:25
ComboFix-quarantined-files.txt 2009-12-02 12:24
Pre-Run: 139,921,080,320 bytes free
Post-Run: 139,963,908,096 bytes free
- - End Of File - - E0125B0372F4B24A04AE8DBE17087EE0
m00nsh1ne
Posts Posts : 16
Post by Dr Jay on 2nd December 2009, 1:24 pm
Posts Posts : 14314
Post by m00nsh1ne on 2nd December 2009, 2:09 pm
Thank you! I already had MalwareBytes installed from yesterday and I just reran the full scan, ZERO items infected so I think it is completely gone! I am going to look into the courses you posted about for learning how to fight Malware. I am very interested in this stuff!!
m00nsh1ne
Posts Posts : 16
Post by Dr Jay on 2nd December 2009, 8:25 pm
  • Click Scan now.
  • Read and put a Check next to Yes I accept the terms of use.
  • Click the Launching HouseCall>> button.
  • If confirmed that HouseCall can run on your system, under Using Java-based HouseCall kernel click the Starting HouseCall>> button.
  • You may receive a Security Warning about the TrendMicro Java applet, click YES.
  • Under Scan complete computer for malware, grayware, and vulnerabilities click the Next>> button.
  • Please be patient while it installs, updates, and scans your system.
  • Once the scan is complete, it will take you to the summary page.
  • Under Cleanup options, choose clean all detected infections automatically.
  • Click the Clean now>> button.
  • If anything was found you may be prompted to run the scan again, you can just close the browser window.
Posts Posts : 14314
Post by m00nsh1ne on 2nd December 2009, 9:46 pm
When I downloaded it, I did not see the information contained in your steps. I clicked on Scan Now and it just started scanning...It found nothing infected, however I am wondering if I did not install it correctly? Seemed simple enough...let me know if I need to do something further. Thanks again!
m00nsh1ne
Posts Posts : 16
Post by Dr Jay on 3rd December 2009, 2:11 am
Posts Posts : 14314
Post by m00nsh1ne on 3rd December 2009, 10:54 am
Windows XP Service Pack 3
Antivirus/Firewall Check:
Windows Firewall Enabled!
AVG Free 9.0
Spyware Doctor 7.0
HijackThis 2.0.2
Java(TM) 6 Update 17
Adobe Flash Player 10
Adobe Reader 9.2
Process Check:
objlist.exe by Laurent
AVG avgwdsvc.exe
AVG avgtray.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
AVG avgemc.exe
DNS Vulnerability Check:
m00nsh1ne
Posts Posts : 16
Post by Dr Jay on 3rd December 2009, 10:24 pm
Software recommendations
Firewall
AntiSpyware
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 14314
