Antivirus Pro help
Antivirus Pro help
Post by Rettaman on Tue 01 Dec 2009, 1:21 pm
My system got infected with this nasty bugger two days ago. I can not run any programs on it that many web-sites including this one (malewarebytes, hackthis, etc.) it blocks them all. I have attempted to install all of thise programs on flashdrives, and cd's have still no avail.
I can't even access my registry to attempt to do it manually.
what else can I do aside from a complete restore?
This is on an xp based system.
Operating System : xp, vista
Re: Antivirus Pro help
Post by Belahzur on Wed 02 Dec 2009, 8:54 am
Link 1
Link 2
  • Double-click on or exeHelper.scr to run the fix.
  • Post the contents of log.txt (Will be created in the directory where you ran
Manager | Tech Officer
