Antivirus System Pro and Bankerfox.a
Post by KenMatrix on Mon Nov 30, 2009 7:46 pm
Antivirus System Pro and Bankerfox.a has taken over my computer and will not allow me to open ANYTHING or ANY program. Whether it be IE, FIREFOX or Chrome or anything from the 'Start' Menu.
It is demanding I pay $69 or stay 'locked' and 'unprotected'.
It also is attempting to display Porn.com sites and Viagra Ad sites.
I unplugged it from the internet.
Please help. Your help is greatly appreciated.
KenMatrix
OS : XP
Re: Antivirus System Pro and Bankerfox.a
Post by KenMatrix on Mon Nov 30, 2009 7:53 pm
...Forget to say I'm using another computer to post this stuff.
When running "TaskManager" the virus blocks you from running it.
I think I'll need a fix from 'Safe Mode'.
KenMatrix
OS : XP
Post by Belahzur on Mon Nov 30, 2009 8:20 pm
Plug it in, we'll need internet access.
Post by KenMatrix on Mon Nov 30, 2009 8:53 pm
It blocks exeHelper.com from running.
The 'black' window pops up then it closes very quickly and the virus says: 'Application Cannot be executed. The file exehelper.scr is infected. Do you want to activate your antivirus software now?' If you say "Yes"
it forwards you to pay $69 to their website: sysguard2010.com
KenMatrix
OS : XP
Post by traposa on Mon Nov 30, 2009 10:58 pm
I'm in the same boat as you. Just got this virus two days ago. I thought I had it off my computer using a program that was suggested on here to scan the computer... but even though I'm no longer getting pops or warnings, now I cannot access the internet at all. Hope they can help.
traposa
OS : XP
Post by KenMatrix on Mon Nov 30, 2009 11:45 pm
Crazy. One thing that does help is that I set up 'guest' accounts. They seem
to be 'not' infected.
So I can use those (luckily) to start transferring important files out of the computer.
On my other computer I will set up a 'user' account with full admin access just in case I get the virus on there.
KenMatrix
OS : XP
Post by Belahzur on Tue Dec 01, 2009 1:43 am
Okay, let me know how that goes, but we can still try removing it if your thinking of formatting....
