ANTI VIRUS PRO SYSTEM WONT GO AWAY EVEN AFTER MALWAREBYTES REMOVAL
Post by chazque on 30th November 2009, 9:27 am
Hi, My computer was infected with anti virus system pro yesterday and its just not goingg awayyy....I looked for ways to destroy it but it doesnt seem to work. Ive downloaded malwarebytes, scanned my computer, removed selected&restarted my computer...but when It restarted it was still there....Im trying to scan it one my time but unlike before its showing no files infected....
WHATT SHOULDDD I DOOO???? PLEASEE HELPP MEE....
I dont understand why my computer wasnt clean after i scanned it&removed it...
Iam Using windows XP btw...
PLEASEE HELPP MEE.....Its driving mee crazy...
chazque
Posts Posts : 6
Joined Joined : 2009-11-30
OS OS : XP & Vista
Points Points : 25687
Re: ANTI VIRUS PRO SYSTEM WONT GO AWAY EVEN AFTER MALWAREBYTES REMOVAL
Post by Belahzur on 30th November 2009, 8:11 pm
Points Points : 245079
Post by chazque on 1st December 2009, 3:16 am
ohh thankgoddd....yesterday while I was waiting for a reply I tried a full scan. The first time I did a quick scan like the instructions told me to. The quick scan removed a lot of viruses but the AntiVirus System Pro was still there even after I restarted the computer. The next time I did a Full Scan which took up to 3&1/2 hours...after removing the rest of the viruses it restarted but the icon was there on the task bar. Before it started anything I opened task manager & clicked end task and after that it never showed up again....So THANKYOUUUU SOOOO MUCHHHH FOR THE REMOVAL GUIDE&COMMENTS....IT HELPED A LOT....
NOW my problem is that my internet explorer doesnt work. I dont use firefox, my other web browser is Safari which also doesnt work....
Can you please help me make it work again....
Thankyouuuuu....
chazque
Posts Posts : 6
OS OS : XP & Vista
Post by Belahzur on 1st December 2009, 10:04 pm
    In Internet Explorer
    In Firefox
Does browsers work now?
Post by chazque on 2nd December 2009, 3:41 am
Thsnkyouuu!! yepp that workedd!! hmmm there is another problem...
When I restarted my computer the anti virus system pro started again...so I restarted the computer and before It started i Opened Task Manager And clicked end task for anything that as opening...
Something called Windows Installer loads by itself when the computer starts...and after that the virus starts...
Is there a way you can get rid of this? so I wont have to open task manager everytime I start the computer...
Thankyou So Much!!! Your helpinggg me a lot...
I did a hijackThis just Incase
Scan saved at 12:40:16 PM, on 12/2/2009
C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\pavsrv51.exe
C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\AVENGINE.EXE
C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\TPSrv.exe
C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\PsCtrls.exe
C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\PavFnSvr.exe
C:\Program Files\Common Files\Panda Software\PavShld\pavprsrv.exe
c:\program files\panda security\panda antivirus + firewall 2008\firewall\PSHOST.EXE
C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\PsImSvc.exe
c:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
C:\WINDOWS\system32\WgaTray.exe
C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
C:\WINDOWS\RTHDCPL.EXE
C:\WINDOWS\system32\RunDLL32.exe
C:\Program Files\QuickTime\qttask.exe
C:\WINDOWS\system32\UMonit.exe
C:\WINDOWS\tsnpstd3.exe
C:\WINDOWS\vsnpstd3.exe
C:\Program Files\Nokia\Nokia PC Suite 6\LaunchApplication.exe
C:\WINDOWS\system32\taskmgr.exe
C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\APVXDWIN.EXE
C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe
C:\Program Files\Common Files\MySoftware\intercom.exe
C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\WebProxy.exe
C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe
C:\Program Files\HP\Digital Imaging\bin\hpqbam08.exe
C:\Program Files\HP\Digital Imaging\bin\hpqgpc01.exe
C:\Program Files\Safari\Safari.exe
C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE
C:\Program Files\Symantec\LiveUpdate\AUPDATE.EXE
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: HP Print Enhancer - {0347C33E-8762-4905-BF09-768834316C61} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_printenhancer.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll
O2 - BHO: HP Smart BHO Class - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn0\yt.dll
O4 - HKLM\..\Run: [SkyTel] SkyTel.EXE
O4 - HKLM\..\Run: [NvMediaCenter] RunDLL32.exe NvMCTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [EPSON Stylus C45 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S4I3T1.EXE /P23 "EPSON Stylus C45 Series" /O5 "LPT1:" /M "Stylus C45"
O4 - HKLM\..\Run: [EPSON Stylus C45 Series (Copy 1)] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S4I3T1.EXE /P32 "EPSON Stylus C45 Series (Copy 1)" /O6 "USB001" /M "Stylus C45"
O4 - HKLM\..\Run: [UMonit] C:\WINDOWS\system32\UMonit.exe
O4 - HKLM\..\Run: [AttuneClientEngine] C:\PROGRA~1\Aveo\Attune\bin\attune_ce.exe
O4 - HKLM\..\Run: [CameraFixer] C:\WINDOWS\CameraFixer.exe
O4 - HKLM\..\Run: [tsnpstd3] C:\WINDOWS\tsnpstd3.exe
O4 - HKLM\..\Run: [snpstd3] C:\WINDOWS\vsnpstd3.exe
O4 - HKLM\..\Run: [hpqSRMon] C:\Program Files\HP\Digital Imaging\bin\hpqSRMon.exe
O4 - HKLM\..\Run: [PCSuiteTrayApplication] C:\Program Files\Nokia\Nokia PC Suite 6\LaunchApplication.exe -startup
O4 - HKLM\..\Run: [nujnmshd] C:\Documents and Settings\Aliyah\Local Settings\Application Data\brafur\bjnesysguard.exe
O4 - HKLM\..\Run: [APVXDWIN] "C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\APVXDWIN.EXE" /s
O4 - HKCU\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [Yahoo! Pager] "C:\PROGRA~1\Yahoo!\MESSEN~1\YAHOOM~1.EXE" -quiet
O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe"
O4 - HKCU\..\Run: [nujnmshd] C:\Documents and Settings\Aliyah\Local Settings\Application Data\brafur\bjnesysguard.exe
O4 - HKUS\S-1-5-19\..\Run: [kaveyofiho] Rundll32.exe "C:\WINDOWS\system32\petipado.dll",s (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [kaveyofiho] Rundll32.exe "C:\WINDOWS\system32\petipado.dll",s (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [Nokia.PCSync] C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe /NoDialog (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [RunNarrator] Narrator.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [Nokia.PCSync] C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe /NoDialog (User 'Default user')
O4 - HKUS\.DEFAULT\..\RunOnce: [RunNarrator] Narrator.exe (User 'Default user')
O4 - Global Startup: MySoftware InterCom.lnk = C:\Program Files\Common Files\MySoftware\intercom.exe
O8 - Extra context menu item: Add to AMV Convert Tool... - C:\Program Files\MP3 Player Utilities 3.70\AMVConverter\grab.html
O8 - Extra context menu item: Add to Media Manager... - C:\Program Files\MP3 Player Utilities 3.70\MediaManager\grab.html
O8 - Extra context menu item: Google Sidewiki... - [You must be registered and logged in to see this link.] Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_60D6097707281E79.dll/cmsidewiki.html
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: HP Smart Select - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} (Checkers Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{768A5E60-875C-4A20-B85C-86D404F167D9}: NameServer = 203.130.196.5,202.134.0.155,202.134.0.61,202.134.2.5
O18 - Protocol: skype4com - (no CLSID) - (no file)
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
O23 - Service: Symantec Lic NetConnect service (CLTNetCnService) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe (file missing)
O23 - Service: LiveUpdate - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
O23 - Service: Panda Software Controller - Panda Software International - C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\PsCtrls.exe
O23 - Service: Panda Function Service (PAVFNSVR) - Panda Software International - C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\PavFnSvr.exe
O23 - Service: Panda Process Protection Service (PavPrSrv) - Panda Software - C:\Program Files\Common Files\Panda Software\PavShld\pavprsrv.exe
O23 - Service: Panda anti-virus service (PAVSRV) - Panda Software International - C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\pavsrv51.exe
O23 - Service: Panda Host Service (PSHost) - Panda Software International - c:\program files\panda security\panda antivirus + firewall 2008\firewall\PSHOST.EXE
O23 - Service: Panda IManager Service (PSIMSVC) - Panda Software International - C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\PsImSvc.exe
O23 - Service: Protexis Licensing V2 (PSI_SVC_2) - Protexis Inc. - c:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
O23 - Service: Symantec Core LC - Unknown owner - C:\PROGRA~1\COMMON~1\SYMANT~1\CCPD-LC\symlcsvc.exe
O23 - Service: Panda TPSrv (TPSrv) - Panda Software International - C:\Program Files\Panda Security\Panda Antivirus + Firewall 2008\TPSrv.exe
End of file - 13916 bytes
chazque
Posts Posts : 6
OS OS : XP & Vista
