Antivirus System Pro and Bankerfox.a & Win
Re: Antivirus System Pro and Bankerfox.a & Win
Post by Belahzur on Sun 29 Nov 2009, 3:36 pm
    In Internet Explorer
    In Firefox
Points Points : 245101
Post by buffm on Sun 29 Nov 2009, 4:53 pm
thanks so much for responding.
i've run the malware several times now. everyother time it identifies/allows me to deal with items.
problem is that the notepad.exe disappears too fast to read/copy it.
I can see seven log.text files now, but each time i try to open one, i get the message that notepad.exe is infected.
buffm
Posts Posts : 128
Joined Joined : 2009-11-29
OS OS : xp, Win7
Points Points : 27488
Post by Belahzur on Sun 29 Nov 2009, 9:11 pm
Lets try and get a Hijack This log.
If Hijack This wont run, run this next tool below, then try Hijack This again.
Post by buffm on Sun 29 Nov 2009, 9:24 pm
ok, couldn't install Hijack It ( a message that hjtinstall.exe was infected) and when I run exehelper.com, the black window appears every so briefly and then i get exehelperlog.txt. I can't open it long enough to read, but i *can* print the file. luckily (or not), it's only one line that says:
exehelper by Raktor.
oy.
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Belahzur on Sun 29 Nov 2009, 10:40 pm
Try running exeHelper more than once, I've had a few users where it says that top line over and over for the first 5 times or so, then it works.
Post by buffm on Sun 29 Nov 2009, 11:09 pm
I've run it dozens of times now. The dos window never stays longer than a second. I see only 2 lines of text.
when i open the exehelperlog.txt, it says:
exeHelper by Raktor
exeHelper by Raktor
Build 20091122
exeHelper by Raktor
exeHelper by Raktor
Build 20091122
Run at exeHelper by Raktor
Build 20091122
exeHelper by Raktor
Build 20091122
Run at 17:59:40exeHelper by Raktor
exeHelper by Raktor
exeHelper by Raktor
Build 20091122
exeHelper by Raktor
exeHelper by Raktor
Build 20091122
exeHelper by Raktor
Build 20091122
Run at 18:00:46
and, i worked around the notepad being infected and have this text from the Malwarebyte's Anti-Malware file mbam-info.txt - if it helps- :
Database version: 2775
Executable location: C:\Program Files\Malwarebytes' Anti-Malware
Database location: C:\Documents and Settings\All Users\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\rules.ref
Username: Buff
Windows folder: C:\WINDOWS
System folder: C:\WINDOWS\system32
Root drive: C:
Program Files: C:\Program Files
Common Files: C:\Program Files\Common Files
Desktop: C:\Documents and Settings\Administrator\Desktop
Desktop: C:\Documents and Settings\All Users\Desktop
Desktop: C:\Documents and Settings\Buff\Desktop
Desktop: C:\Documents and Settings\Default User\Desktop
Desktop: C:\Documents and Settings\LocalService\Desktop
Start Menu: C:\Documents and Settings\All Users\Start Menu
Start Menu: C:\Documents and Settings\Administrator\Start Menu
Start Menu: C:\Documents and Settings\Buff\Start Menu
Start Menu: C:\Documents and Settings\Default User\Start Menu
Start Menu: C:\Documents and Settings\LocalService\Start Menu
User Root: C:\Documents and Settings\Administrator
User Root: C:\Documents and Settings\All Users
User Root: C:\Documents and Settings\Buff
User Root: C:\Documents and Settings\Default User
User Root: C:\Documents and Settings\LocalService
User Root: C:\Documents and Settings\NetworkService
Favorite: C:\Documents and Settings\Administrator\Favorites
Favorite: C:\Documents and Settings\All Users\Favorites
Favorite: C:\Documents and Settings\Buff\Favorites
Favorite: C:\Documents and Settings\Default User\Favorites
Application Data: C:\Documents and Settings\All Users\Application Data
Application Data: C:\Documents and Settings\Administrator\Application Data
Application Data: C:\Documents and Settings\Buff\Application Data
Application Data: C:\Documents and Settings\Default User\Application Data
Application Data: C:\Documents and Settings\LocalService\Application Data
Application Data: C:\Documents and Settings\NetworkService\Application Data
Quick Launch: C:\Documents and Settings\Buff\Application Data\Microsoft\Internet Explorer\Quick Launch
Temporary Folder: C:\WINDOWS\Temp
Temporary Folder: C:\Documents and Settings\Buff\Local Settings\Temp
Temporary Folder: C:\Documents and Settings\Default User\Local Settings\Temp
Temporary Folder: C:\Documents and Settings\LocalService\Local Settings\Temp
Temporary Folder: C:\Documents and Settings\NetworkService\Local Settings\Temp
Programs: C:\Documents and Settings\Administrator\Start Menu\Programs
Programs: C:\Documents and Settings\All Users\Start Menu\Programs
Programs: C:\Documents and Settings\Buff\Start Menu\Programs
Programs: C:\Documents and Settings\Default User\Start Menu\Programs
Programs: C:\Documents and Settings\LocalService\Start Menu\Programs
Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup
Startup: C:\Documents and Settings\Administrator\Start Menu\Programs\Startup
Startup: C:\Documents and Settings\Buff\Start Menu\Programs\Startup
Startup: C:\Documents and Settings\Default User\Start Menu\Programs\Startup
Documents: C:\Documents and Settings\All Users\Documents
Documents: C:\Documents and Settings\Administrator\My Documents
Documents: C:\Documents and Settings\Buff\My Documents
Documents: C:\Documents and Settings\Default User\My Documents
Documents: C:\Documents and Settings\LocalService\My Documents
thanks again for your help. b
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Doctor Inferno on Sun 29 Nov 2009, 11:59 pm
Moderated Message:Topic split from:
Points Points : 104630
Post by Belahzur on Mon 30 Nov 2009, 5:19 pm
When you download Hijack This, rename it to explorer.scr, see if it will run then.
antivirus system pro - the saga continues
Post by buffm on Mon 30 Nov 2009, 11:55 pm
Whew! finally got the hijack this log - which is below
One question: am i endangering everyone else - and my private info by keeping this infected computer on?
Scan saved at 6:29:17 PM, on 11/30/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16915)
Boot mode: Safe mode
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page =
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Browser Defender BHO - {2A0F3D1B-0909-4FF4-B272-609CCE6054E7} - C:\Program Files\Spyware Doctor\BDT\PCTBrowserDefender.dll (file missing)
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - E:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.3.4501.1418\swg.dll
O3 - Toolbar: PC Tools Browser Guard - {472734EA-242A-422B-ADF8-83D1E48CC825} - C:\Program Files\Spyware Doctor\BDT\PCTBrowserDefender.dll (file missing)
O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\SoundMAX\SMax4PNP.exe
O4 - HKLM\..\Run: [SoundMAX] "C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" /tray
O4 - HKLM\..\Run: [IMONTRAY] C:\Program Files\Intel\Intel(R) Active Monitor\imontray.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [zBrowser Launcher] C:\Program Files\Logitech\iTouch\iTouch.exe
O4 - HKLM\..\Run: [Logitech Utility] Logi_MwX.Exe
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\System32\spool\drivers\w32x86\3\hpztsb07.exe
O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1134844876\ee\AOLSoftware.exe
O4 - HKLM\..\Run: [AOLDialer] C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
O4 - HKLM\..\Run: [iTunesHelper] "E:\Itunes storage\iTunesHelper.exe"
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir Desktop\avgnt.exe" /min
O4 - HKLM\..\Run: [atktrhnm] C:\Documents and Settings\Buff\Local Settings\Application Data\aegius\ugalsysguard.exe
O4 - HKLM\..\Run: [SpyHunter Security Suite] C:\Program Files\Enigma Software Group\SpyHunter\SpyHunter3.exe
O4 - HKCU\..\Run: [ASUS SmartDoctor] C:\Program Files\ASUS\SmartDoctor\\SmartDoctor.exe /start
O4 - HKCU\..\Run: [atktrhnm] C:\Documents and Settings\Buff\Local Settings\Application Data\aegius\ugalsysguard.exe
O4 - HKUS\S-1-5-18\..\RunOnce: [RunNarrator] Narrator.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [RunNarrator] Narrator.exe (User 'Default user')
O4 - Global Startup: Adobe Gamma Loader.exe.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O4 - Global Startup: QuickBooks Update Agent.lnk = C:\Program Files\Common Files\Intuit\QuickBooks\QBUpdate\qbupdate.exe
O4 - Global Startup: TabUserW.exe.lnk = C:\WINDOWS\system32\WTablet\TabUserW.exe
O8 - Extra context menu item: &AOL Toolbar search - [You must be registered and logged in to see this link.] Files\AOL Toolbar\toolbar.dll/SEARCH.HTML
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\System32\Shdocvw.dll
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O16 - DPF: {11260943-421B-11D0-8EAC-0000C07D88CF} (iPIX ActiveX Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {1239CC52-59EF-4DFA-8C61-90FFA846DF7E} (Musicnotes Viewer) - [You must be registered and logged in to see this link.]
O16 - DPF: {56336BCB-3D8A-11D6-A00B-0050DA18DE71} - [You must be registered and logged in to see this link.]
O16 - DPF: {88D969C0-F192-11D4-A65F-0040963251E5} (XML DOM Document 4.0) - [You must be registered and logged in to see this link.]
O16 - DPF: {EB387D2F-E27B-4D36-979E-847D1036C65D} (QDiagHUpdateObj Class) - [You must be registered and logged in to see this link.]
O23 - Service: Avira AntiVir Scheduler (AntiVirSchedulerService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\sched.exe
O23 - Service: Avira AntiVir Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\avguard.exe
O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
O23 - Service: Browser Defender Update Service - Threat Expert Ltd. - C:\Program Files\Spyware Doctor\BDT\BDTUpdateService.exe
O23 - Service: Intel(R) Active Monitor (imonNT) - Intel Corp. - C:\Program Files\Intel\Intel(R) Active Monitor\imonnt.exe
O23 - Service: ASUS Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
O23 - Service: PC Tools Startup and Shutdown Monitor service (PCToolsSSDMonitorSvc) - PC Tools - C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe
O23 - Service: Intuit QuickBooks FCS (QBFCService) - Intuit Inc. - C:\Program Files\Common Files\Intuit\QuickBooks\FCS\Intuit.QuickBooks.FCS.exe
O23 - Service: SoundMAX Agent Service (SoundMAX Agent Service (default)) - Analog Devices, Inc. - C:\Program Files\Analog Devices\SoundMAX\SMAgent.exe
O23 - Service: TabletService - Wacom Technology, Corp. - C:\WINDOWS\system32\Tablet.exe
O23 - Service: WAN Miniport (ATW) Service (WANMiniportService) - America Online, Inc. - C:\WINDOWS\wanmpsvc.exe
End of file - 9387 bytes
thanks thanks thanks again!
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Belahzur on Tue 01 Dec 2009, 7:01 pm
    In Firefox
Post by buffm on Wed 02 Dec 2009, 2:31 am
By George, that might have done it!
no Antivirus System Pro icon on the task bar.
and no extra windows popping open.
here's the log:
Database version: 3181
Windows 5.1.2600 Service Pack 3 (Safe Mode)
12/1/2009 9:21:47 PM
mbam-log-2009-12-01 (21-21-47).txt
Scan type: Full Scan (C:\|E:\|)
Objects scanned: 187216
Time elapsed: 1 hour(s), 0 minute(s), 31 second(s)
Registry Keys Infected: 1
Files Infected: 1
C:\Documents and Settings\Buff\Desktop\explorer.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
Thank you so much for the guidance.
hopefully this will hold. if not, i'll write again. happy holidays!
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Belahzur on Wed 02 Dec 2009, 6:02 pm
Can you update MBAM again? 3181 is fairly recent, but still quite the way behind in updates.
Post by buffm on Sat 05 Dec 2009, 2:36 pm
first time around i got an error code 732(0,0).
but i uninstalled and reinstalled MBAM and could update.
Malwarebytes' Anti-Malware 1.42
Database version: 3300
Internet Explorer 7.0.5730.13
12/5/2009 9:35:11 AM
mbam-log-2009-12-05 (09-35-10).txt
Objects scanned: 118572
Time elapsed: 13 minute(s), 2 second(s)
Files Infected: 1
C:\WINDOWS\system32\vinelewe.dll (Trojan.Vundo.H) -> Quarantined and deleted successfully.
Files Infected: 1
thanks
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Belahzur on Sat 05 Dec 2009, 2:52 pm
  • Download combofix from here
Post by buffm on Sat 05 Dec 2009, 5:27 pm
Here's the log file. fwiw, everytime my computer was re-started, i had to manually disable AVIRA antivirus. there was no permanent setting.
again, thanks.
ComboFix 09-12-04.05 - Buff 12/05/2009 12:03.1.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1023.605 [GMT -8]
Running from: c:\documents and settings\Buff\Desktop\Combo-Fix.exe
AV: AntiVir Desktop *On-access scanning disabled* (Updated) {AD166499-45F9-482A-A743-FDD3350758C7}
AV: Avira AntiVir PersonalEdition Classic *On-access scanning disabled* (Outdated) {8615ACC4-FFA4-0122-0D24-347CA8A3377C}
** please note: there were many of these lines of text, but the file was too large to post **
AV: Avira AntiVir PersonalEdition Classic *On-access scanning enabled* (Outdated) {86E77A5C-FFA4-00EF-0D24-347CA8A3377C}
AV: Avira AntiVir PersonalEdition Classic *On-access scanning enabled* (Outdated) {86E7A4BC-FFA4-00EF-0D24-347CA8A3377C}
AV: Avira AntiVir PersonalEdition Classic *On-access scanning enabled* (Outdated) {86ED8604-FFA4-0110-0D24-347CA8A3377C}
AV: Avira AntiVir PersonalEdition Classic *On-access scanning enabled* (Outdated) {BADB0D00-FFA4-00EF-0D24-347CA8A3377C}
AV: Avira AntiVir PersonalEdition Classic *On-access scanning enabled* (Outdated) {FFDFF121-FFA4-00EF-0D24-347CA8A3377C}
AV: Avira AntiVir PersonalEdition Classic *On-access scanning enabled* (Outdated) {FFFFFFFF-FFA4-00DE-0D24-347CA8A3377C}
AV: Spyware Doctor with AntiVirus *On-access scanning enabled* (Updated) {D3C23B96-C9DC-477F-8EF1-69AF17A6EFF6}
c:\documents and settings\All Users\Start Menu\HP Image Zone .lnk
c:\documents and settings\Buff\Local Settings\Application Data\aegius
c:\documents and settings\Buff\Local Settings\Application Data\aegius\ugalsysguard.exe
c:\windows\Downloaded Program Files\RdxIE.dll
c:\windows\Tasks\pnxvuest.job
Infected copy of c:\windows\system32\DRIVERS\atapi.sys was found and disinfected
Restored copy from - Kitty ate it :p
((((((((((((((((((((((((( Files Created from 2009-11-05 to 2009-12-05 )))))))))))))))))))))))))))))))
2009-12-05 17:18 . 2009-12-04 00:14 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-12-05 17:17 . 2009-12-05 17:18 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-12-05 17:17 . 2009-12-04 00:13 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-12-03 15:17 . 2009-10-30 19:11 233136 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-12-03 15:17 . 2009-11-09 19:20 207792 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-12-03 15:17 . 2009-10-07 00:31 87784 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2009-12-03 15:17 . 2009-09-03 17:45 70408 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2009-12-01 01:59 . 2009-12-01 01:59 -------- d-----w- c:\program files\Trend Micro
2009-11-29 19:32 . 2009-12-05 16:57 -------- d-----w- c:\program files\Enigma Software Group
2009-11-29 06:56 . 2009-11-29 06:56 -------- d-----w- c:\documents and settings\Buff\Application Data\Malwarebytes
2009-11-29 06:24 . 2009-11-29 06:24 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-11-29 00:04 . 2009-11-29 00:04 -------- d-----w- c:\program files\TeaTimer (Spybot - Search & Destroy)
2009-11-29 00:04 . 2009-11-29 00:04 -------- d-----w- c:\program files\SDHelper (Spybot - Search & Destroy)
2009-11-29 00:04 . 2009-11-29 00:04 -------- d-----w- c:\program files\Misc. Support Library (Spybot - Search & Destroy)
2009-11-29 00:03 . 2009-11-29 00:03 -------- d-----w- c:\program files\File Scanner Library (Spybot - Search & Destroy)
2009-11-28 23:55 . 2009-11-28 23:55 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\AOL
2009-12-05 20:16 . 2006-12-12 15:11 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-12-05 20:13 . 2009-10-31 02:47 -------- d-----w- c:\program files\Spyware Doctor
2009-12-05 20:13 . 2005-06-19 15:32 17242 ----a-w- c:\windows\system32\tablet.dat
2009-12-05 19:34 . 2004-09-03 01:40 -------- d-----w- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
2009-12-03 15:26 . 2009-10-29 01:13 -------- d-----w- c:\program files\Common Files\PC Tools
2009-11-10 18:28 . 2009-10-31 02:55 149456 ----a-w- c:\windows\SGDetectionTool.dll
2009-11-10 18:28 . 2009-10-31 02:55 165840 ----a-w- c:\windows\PCTBDRes.dll
2009-11-10 18:28 . 2009-10-31 02:55 1640400 ----a-w- c:\windows\PCTBDCore.dll
2009-11-10 18:26 . 2009-10-31 02:55 767952 ----a-w- c:\windows\BDTSupport.dll
2009-10-31 02:47 . 2009-10-31 02:47 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Tools
2009-10-29 01:16 . 2009-10-29 01:16 -------- d-----w- c:\documents and settings\Buff\Application Data\Registry Mechanic
2009-10-28 09:36 . 2009-10-31 02:55 1152444 ----a-w- c:\windows\UDB.zip
2009-10-07 22:21 . 2009-06-21 05:13 -------- d-----w- c:\program files\AOL 9.1
2009-10-02 17:15 . 2008-05-01 06:20 2341 -c--a-w- c:\documents and settings\All Users\Application Data\Intuit\QuickBooks 2007\qbbackup.sys
2009-10-02 16:03 . 2008-05-01 06:15 816392 ----a-w- c:\documents and settings\All Users\Application Data\Intuit\QuickBooks 2007\Components\DownloadQB17\Patch\qbpatch2.exe
2009-09-11 14:18 . 2008-11-15 20:51 136192 ----a-w- c:\windows\system32\msv1_0.dll
2007-05-19 02:39 . 2006-11-18 17:16 848 -csha-w- c:\windows\system32\KGyGaAvL.sys
"ASUS SmartDoctor"="c:\program files\ASUS\SmartDoctor\\SmartDoctor.exe " [X]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-06-22 68856]
"SoundMAXPnP"="c:\program files\Analog Devices\SoundMAX\SMax4PNP.exe" [2003-05-29 790528]
"IMONTRAY"="c:\program files\Intel\Intel(R) Active Monitor\imontray.exe" [2003-11-03 32768]
"NvCplDaemon"="c:\windows\System32\NvCpl.dll" [2003-05-02 4640768]
"zBrowser Launcher"="c:\program files\Logitech\iTouch\iTouch.exe" [2003-12-01 892928]
"HPDJ Taskbar Utility"="c:\windows\System32\spool\drivers\w32x86\3\hpztsb07.exe" [2002-12-10 188416]
"HostManager"="c:\program files\Common Files\AOL\1134844876\ee\AOLSoftware.exe" [2008-06-24 41824]
"AOLDialer"="c:\program files\Common Files\AOL\ACS\AOLDial.exe" [2006-10-23 71216]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-05-14 177472]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2009-05-27 413696]
"iTunesHelper"="e:\itunes storage\iTunesHelper.exe" [2009-06-05 292136]
"ISTray"="c:\program files\Spyware Doctor\pctsTray.exe" [2009-11-18 1243088]
"avgnt"="c:\program files\Avira\AntiVir Desktop\avgnt.exe" [2009-03-02 209153]
"nwiz"="nwiz.exe" - c:\windows\system32\nwiz.exe [2003-05-02 323584]
"Logitech Utility"="Logi_MwX.Exe" - c:\windows\LOGI_MWX.EXE [2003-11-07 19968]
"RunNarrator"="Narrator.exe" - c:\windows\system32\narrator.exe [2008-04-14 53760]
Adobe Gamma Loader.exe.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2004-8-8 113664]
Adobe Gamma Loader.lnk - c:\fonts\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2005-12-13 113664]
HP Image Zone Fast Start.lnk - c:\program files\HP\Digital Imaging\bin\hpqthb08.exe [2005-5-12 73728]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office\OSA9.EXE [1999-2-17 65588]
QuickBooks Update Agent.lnk - c:\program files\Common Files\Intuit\QuickBooks\QBUpdate\qbupdate.exe [2008-3-18 972064]
TabUserW.exe.lnk - c:\windows\system32\WTablet\TabUserW.exe [2005-6-19 77824]
BootExecute REG_MULTI_SZ autocheck autochk *\0SsiEfr.e
"c:\\Program Files\\Real\\RealPlayer\\realplay.exe"=
"c:\\Program Files\\Adobe\\Acrobat 5.0\\Reader\\AcroRd32.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\acsd.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe"=
"c:\\Program Files\\Common Files\\AOL\\1134844876\\EE\\AOLServiceHost.exe"=
"c:\\Program Files\\Common Files\\AOL\\System Information\\sinf.exe"=
"c:\\Program Files\\HP\\HP Software Update\\HPWUCli.exe"=
"c:\\Program Files\\NewTech Infosystems\\NTI CD-Maker\\LiveUpdate.exe"=
"c:\\WINDOWS\\system32\\java.exe"=
"c:\\Program Files\\Common Files\\AOL\\1134844876\\EE\\aolsoftware.exe"=
"e:\\more utils\\Yahoo! Music Jukebox\\YahooMusicEngine.exe"=
"c:\\Program Files\\Intuit\\QuickBooks Pro\\QBDBMgrN.exe"=
"%windir%\\system32\\drivers\\svchost.exe"=
"c:\\Program Files\\AOL 9.1\\waol.exe"=
"c:\\Program Files\\Common Files\\AOL\\TopSpeed\\3.0\\aoltpsd3.exe"=
"e:\\Itunes storage\\iTunes.exe"=
"c:\\Program Files\\Logitech\\MouseWare\\system\\EM_EXEC.EXE"=
"c:\\Program Files\\Avira\\AntiVir Desktop\\avgnt.exe"=
"3389:TCP"= 3389:TCP:@xpsp2res.dll,-22009
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [12/3/2009 7:17 AM 207792]
R1 ANVIOCTL;ANVIOCTL;c:\windows\system32\drivers\anvioctl.sys [8/8/2004 11:05 PM 233280]
R2 AntiVirSchedulerService;Avira AntiVir Scheduler;c:\program files\Avira\AntiVir Desktop\sched.exe [7/27/2009 6:18 PM 108289]
R2 Browser Defender Update Service;Browser Defender Update Service;c:\program files\Spyware Doctor\BDT\BDTUpdateService.exe [10/30/2009 6:55 PM 112592]
R2 PCToolsSSDMonitorSvc;PC Tools Startup and Shutdown Monitor service;c:\program files\Common Files\PC Tools\sMonitor\StartManSvc.exe [10/28/2009 5:13 PM 583640]
R2 sdauxservice;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [12/3/2009 7:17 AM 359624]
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [6/12/2008 6:41 PM 24652]
S3 Ndppogoo;Ndppogoo; [x]
*Deregistered* - PCTSDInjDriver32
2009-10-21 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 19:34]
IE: &AOL Toolbar search - c:\program files\AOL Toolbar\toolbar.dll/SEARCH.HTML
FF - ProfilePath - c:\documents and settings\Buff\Application Data\Mozilla\Firefox\Profiles\c8p4awzl.Default User\
FF - component: c:\documents and settings\Buff\Application Data\Mozilla\Firefox\Profiles\c8p4awzl.Default User\extensions\{a7c6cf7f-112c-4500-a7ea-39801a327e5f}\platform\WINNT_x86-msvc\components\ipc.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npmusicn.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npqtplugin8.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npunagi2.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\QuickTime\Plugins\npqtplugin8.dll
FF - plugin: e:\itunes storage\Mozilla Plugins\npitunes.dll
---- FIREFOX POLICIES ----
c:\program files\Mozilla Firefox\defaults\pref\activex.js - pref("capability.policy.default.ClassID.CIDFE0BD779-44EE-4A4B-AA2E-743C63F2E5E6", "AllAccess");
HKCU-Run-Aim6 - (no file)
AddRemove-RealJukebox 1.0 - c:\program files\Common Files\Real\Update_OB\r1puninst.exe RealNetworks|RealPlayer|6.0
AddRemove-RealPlayer 6.0 - c:\program files\Common Files\Real\Update_OB\r1puninst.exe RealNetworks|RealPlayer|6.0
AddRemove-_{7C5123A9-30A8-4C44-89CA-A8C87A1FCC91} - c:\program files\Corel\CorelDRAW Graphics Suite 13\Programs\MSILauncher {7C5123A9-30A8-4C44-89CA-A8C87A1FCC91}
AddRemove-{08082022-2a50-4196-8196-a6f86d6e8f12} - c:\program files\Installshield Installation Information\{08082022-2a50-4196-8196-a6f86d6e8f12}\QBReplace.exe {08082022-2a50-4196-8196-a6f86d6e8f12}#{01288593-26bb-4b3a-a04e-0a4ed28cc937}
Rootkit scan 2009-12-05 12:15
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
- - - - - - - > 'winlogon.exe'(728)
c:\windows\system32\tabhook.dll
- - - - - - - > 'explorer.exe'(2472)
c:\program files\Spyware Doctor\pctgmhk.dll
c:\program files\Logitech\MouseWare\System\LgWndHk.dll
c:\program files\Common Files\AOL\ACS\WLHook.dll
c:\program files\Logitech\iTouch\iTchHk.dll
c:\program files\Common Files\Logitech\Scrolling\LgMsgHk.dll
c:\program files\WS_FTP Pro\nsftpch.dll
c:\program files\Avira\AntiVir Desktop\avguard.exe
c:\program files\Common Files\AOL\ACS\AOLAcsd.exe
c:\windows\System32\nvsvc32.exe
c:\program files\Spyware Doctor\pctsSvc.exe
c:\program files\Analog Devices\SoundMAX\SMAgent.exe
c:\windows\system32\Tablet.exe
c:\windows\wanmpsvc.exe
c:\program files\Intel\Intel(R) Active Monitor\imonnt.exe
c:\program files\Viewpoint\Viewpoint Manager\ViewMgr.exe
c:\program files\Logitech\MouseWare\system\em_exec.exe
c:\program files\ASUS\SmartDoctor\SmartDoctor.exe
c:\windows\System32\MDM.EXE
c:\program files\HP\Digital Imaging\bin\hpqimzone.exe
Completion time: 2009-12-05 12:19 - machine was rebooted
ComboFix-quarantined-files.txt 2009-12-05 20:19
Pre-Run: 4,044,537,856 bytes free
Post-Run: 4,090,617,856 bytes free
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
- - End Of File - - 44F23DBEFD3CBFD8DF816B711F90AD3C
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Belahzur on Sat 05 Dec 2009, 9:58 pm
Next,
  • Open HijackThis.
Post by buffm on Sat 05 Dec 2009, 10:51 pm
thanks....
Ad-Aware SE Personal
Adobe Acrobat 5.0
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Flash Player 9 ActiveX
Adobe InDesign 1.5
Adobe Photoshop 6.0
Adobe Reader 7.0.5 Language Support
Adobe Reader 7.0.9
AIM 6
Aladdin DropStuff 5.0
Aladdin Expander 5.0
AOL Uninstaller (Choose which Products to Remove)
Apple Mobile Device Support
ASUS Display Drivers
ASUS SmartDoctor
Avira AntiVir Personal - Free Antivirus
Browser Defender 2.0.6.11
CorelDRAW Graphics Suite X3
EN
ESPN Java Check
FFLM version 6.04
FontNav
Google Earth
hp deskjet 5550 series
hp deskjet 5550 series (Remove only)
HP Document Viewer 5.3
HP Image Zone 5.3
HP Imaging Device Functions 5.3
HP Memories Disc
HP Scanjet 4800 series
HP Software Update
HP Solution Center & Imaging Support Tools 5.3
iAUDIO U2 User's Guide
Intel(R) PRO Network Adapters and Drivers
iPod for Windows 2005-03-23
Ipswitch WS_FTP Pro
Ipswitch WS_FTP Pro
iTunes
J2SE Runtime Environment 5.0 Update 1
Java(TM) 6 Update 2
Java(TM) 6 Update 3
Java(TM) 6 Update 7
JetShell for iAUDIO U2
Logitech iTouch Software
Logitech MouseWare 9.79
Microsoft .NET Framework 1.1
Microsoft Data Access Components KB870669
Microsoft Office 2000 Premium
Microsoft Silverlight
Microsoft VC9 runtime libraries
Microsoft Visual C++ 2008 ATL Update kb973924 - x86 9.0.30729.4148
MobileMe Control Panel
Mozilla Firefox (3.0.15)
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
MSXML 4.0 SP2 Parser and SDK
Netflix Movie Viewer
NTI DVD-Maker Gold
Picasa 2
Picture Package Music Transfer
PowerDVD
QuickBooks Pro 2007
QuickTime
Registry Mechanic 9.0
Sony Picture Utility
Sony USB Driver
SoundMAX
Spybot - Search & Destroy 1.3
Spyware Doctor 7.0
SupportSoft Assisted Service
Update for Windows Internet Explorer 7 (KB976749)
Update Manager
USB-IDE Bridge Driver
VBA
Viewpoint Manager (Remove Only)
Viewpoint Media Player
Wacom Tablet
Windows Genuine Advantage v1.3.0254.0
Windows XP Service Pack 3
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Belahzur on Sun 06 Dec 2009, 8:53 am
You are running two antivirus', I see from the uninstall list you have Avast installed, along with Spyware Doctor. This is a bad idea as they can conflict and cause more problems. I would recommend that you remove Spyware Doctor to avoid conflict and other future problems.
    Java(TM) 6 Update 2
    Java(TM) 6 Update 3
    Java(TM) 6 Update 7
    Spyware Doctor 7.0
Update Avast because it's outdated at the moment.
ComboFix /uninstall
Post by buffm on Sun 06 Dec 2009, 2:55 pm
Avast is a freeware and I have a paid subscription to Spyware Doctor and a paid subscription to Reg Mechanic.
do you think it would be alright to remove the Avira Antiviral instead?
once more. thank you so much.
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Belahzur on Sun 06 Dec 2009, 10:18 pm
Yes, remove Avira instead. Smile
Post by buffm on Sun 06 Dec 2009, 10:45 pm
OK.
I uninstalled as you described - except AVIRA instead of Spyware Docter and RegMechanic.
I also removed Spybot Search& Destroy - was that a mistake?
I think the computer's running better.
No more porn - which is a huge relief.
the only problem is that before I was able to see this computer (xp) on my laptop (vista) - which is necessary, since I use files on my E drive and I use the printer attached to the XP.
Do you have any idea if any of the steps I followed to get rid of the virus would have fried my home network?
one more time. thank your for all your time and effort.
b Smile Thank You!
buffm
Posts Posts : 128
OS OS : xp, Win7
Post by Belahzur on Mon 07 Dec 2009, 6:01 pm
Spybots TeaTimer is a rather good defence module, but their removal methods aren't that great.
As for the network, I doubt it, this malware doesn't spread via networks.
