antivirus system pro - ie does not function
Post by darinacammay on 30th November 2009, 12:44 am
Thank you for the information posted so far! i have used malware bytes and antivirus system pro no longer comes up. I checked in program files on C drive and it is not there. However, I cannot use internet explorer on that computer. Even though I can use other programs where I need to be connected to the internet (like my Outlook). Any web address I put in gets changed to "http:///" and I get a message stating "the address is not valid". Please help!
darinacammay
Posts Posts : 4
Joined Joined : 2009-11-30
Points Points : 25728
Re: antivirus system pro - ie does not function
Post by Dr Jay on 30th November 2009, 12:55 am
Posts Posts : 14314
Points Points : 302999
Post by darinacammay on 30th November 2009, 1:02 am
I cannot get to any websites at all using the infected laptop. So what do I do?
darinacammay
Posts Posts : 4
Post by darinacammay on 30th November 2009, 1:23 am
the answer above doesn't address the fact that i can't get onto any website!
darinacammay
Posts Posts : 4
Post by Dr Jay on 30th November 2009, 2:51 am
Hello again. Sorry about that spammer above.
Please start Internet Explorer, and when the program is open, click on the Tools menu and then select Internet Options.
  • Now click on the Connections tab and then the Lan Settings button
  • Under the Proxy Server section, please uncheck the checkbox labeled Use a proxy server for your LAN. Then press the OK button to close this screen. Then press the Apply button and then the OK button to close the Internet Options screen. Now that you have disabled the proxy server you will be able to browse the web again with Internet Explorer.
If you are able to browse the web, please follow the instructions in my first reply. If not, please reply and tell me it did not work.
Posts Posts : 14314
Post by darinacammay on 30th November 2009, 5:08 am
Thanks! IE is working again.
darinacammay
Posts Posts : 4
Post by Dr Jay on 30th November 2009, 5:30 am
Posts Posts : 14314
