Antivirus System Pro - NEED HELP
Post by cjryan1076 on 29th November 2009, 3:42 am
I've seen so many things to download to get rid of this stupid thing and i can download them but i cannot get anything to open! what do i do?? i'm getting so frustrated and i'm no computer genius.
cjryan1076
Joined Joined : 2009-11-29
Points Points : 25688
Re: Antivirus System Pro - NEED HELP
Post by Belahzur on 29th November 2009, 7:07 pm
Points Points : 245101
Post by cjryan1076 on 30th November 2009, 2:29 am
they both saved to my desktop but the virus is keeping them from opening. i can see the black screen for about two seconds and then it's gone.
cjryan1076
Post by Belahzur on 30th November 2009, 8:41 pm
Can you try renaming it to explorer and then see if it runs?
