Antivirus System Pro virus help needed
Post by Jay Cee on 28th November 2009, 3:11 pm
I got hit with antivirus system pro on my computer. I'm thinking one of my little cousins did something on Thanksgiving tho I am not sure. It is not allowing me to run malwarebytes. I tried downloading hijackthis but it will not allow me to open it. What can I do? This thing is a terror.
Jay Cee
Posts Posts : 98
Joined Joined : 2009-09-25
Points Points : 27148
Re: Antivirus System Pro virus help needed
Post by Belahzur on 28th November 2009, 6:50 pm
Points Points : 245111
Post by Jay Cee on 28th November 2009, 10:17 pm
Moderated Message: Hello, your comment has been removed. Please do not post in another member's topic. If you need help, please read [You must be registered and logged in to see this link.] over and [You must be registered and logged in to see this link.] to open a new topic. -Doctor Inferno
Jay Cee
Posts Posts : 98
Post by Belahzur on 29th November 2009, 1:52 am
Looks like Doc made a mistake and removed the wrong post. LMBO or ROFL
Can you re-post whatever you posted before?
Post by Jay Cee on 29th November 2009, 2:35 am
I said the virus will not let me run the program.
Jay Cee
Posts Posts : 98
Post by Belahzur on 29th November 2009, 7:07 pm
Rename it from exeHelper to explorer and see if it runs then.
Post by Jay Cee on 30th November 2009, 1:47 am
That didnt work either. Also tried downloading combofix and renaming it to commy and running it from start run but I keep getting the same error message.
Jay Cee
Posts Posts : 98
Antivirus System Pro solution
Post by JScadden on 30th November 2009, 1:52 am
I tried to reboot in safe mode, it wouldn't let me, however, in Vista 64-bit it created a "start' error, which allowed me to restore my computer at a point from the day before. That seems to have gotten rid of it. Maybe if you can reboot in safe mode and restore to that point prior to infection, it will work for you also. I had tried everything, it had taken over my taskmgr, etc. this is all that worked. I then downloaded Malwarebytes and swept my computer with it. It did not detect Antivirus system pro on computer any longer.
JScadden
Joined Joined : 2009-11-29
OS OS : Vista 64-bit
Points Points : 25710
Post by Belahzur on 30th November 2009, 8:34 pm
  • Download combofix from here
Post by Jay Cee on 30th November 2009, 11:24 pm
ComboFix 09-11-30.02 - JC 11/30/2009 18:12.3.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.2038.1444 [GMT -5:00]
Running from: c:\documents and settings\JC\Desktop\Combo-Fix.exe
AV: Symantec Endpoint Protection *On-access scanning disabled* (Updated) {FB06448E-52B8-493A-90F3-E43226D3305C}
FW: Symantec Endpoint Protection *disabled* {BE898FE3-CD0B-4014-85A9-03DB9923DDB6}
* Created a new restore point
c:\documents and settings\JC\Local Settings\Application Data\tmskhh
c:\documents and settings\JC\Local Settings\Application Data\tmskhh\solmsysguard.exe
C:\LOG.TXT
Infected copy of c:\windows\system32\DRIVERS\atapi.sys was found and disinfected
Restored copy from - Kitty ate it :p
((((((((((((((((((((((((( Files Created from 2009-10-28 to 2009-11-30 )))))))))))))))))))))))))))))))
2009-11-10 23:13 . 2009-11-10 23:13 -------- d-----w- c:\program files\IrfanView
2009-11-07 02:08 . 2007-12-26 22:30 1970176 ----a-w- c:\windows\system32\d3dx9.dll
2009-11-07 02:08 . 2009-11-07 23:06 -------- d-----w- c:\program files\Cheat Engine
2009-11-07 02:08 . 2007-12-26 22:30 679936 ----a-w- c:\windows\system32\D3DX81ab.dll
2009-11-03 22:52 . 2009-11-03 22:52 -------- d-----w- c:\documents and settings\JC\Local Settings\Application Data\Identities
2009-11-29 00:47 . 2009-10-18 23:51 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-10-21 23:15 . 2009-10-21 23:15 -------- d-----w- c:\program files\ESET
2009-10-19 21:56 . 2009-10-18 23:36 0 ----a-w- c:\windows\system32\sck236jn.dat
2009-10-19 01:05 . 2009-10-19 01:05 -------- d-----w- c:\program files\Trend Micro
2009-10-19 00:14 . 2006-02-18 15:56 -------- d-----w- c:\program files\Google
2009-10-18 23:51 . 2009-10-18 23:51 -------- d-----w- c:\documents and settings\JC\Application Data\Malwarebytes
2009-10-18 23:51 . 2009-10-18 23:51 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-10-18 23:50 . 2009-10-18 23:35 1 ----a-w- c:\windows\system32\perfc7683.dat
2009-09-11 14:18 . 2006-02-15 14:03 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-10 19:54 . 2009-10-18 23:51 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-10 19:53 . 2009-10-18 23:51 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-09-04 21:03 . 2006-02-15 14:03 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-09-03 07:07 . 2006-02-16 16:59 67528 ----a-w- c:\documents and settings\Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-09-02 01:48 . 2006-02-15 15:37 87931 ----a-w- c:\windows\pchealth\helpctr\OfflineCache\index.dat
+ 2009-11-30 23:12 . 2009-11-30 23:12 16384 c:\windows\Temp\Perflib_Perfdata_420.dat
- 2008-10-22 09:47 . 2009-07-14 11:03 46080 c:\windows\system32\tzchange.exe
+ 2008-10-22 09:47 . 2009-10-28 15:07 46080 c:\windows\system32\tzchange.exe
+ 2006-02-15 14:03 . 2009-08-29 07:36 44544 c:\windows\system32\pngfilt.dll
- 2006-02-15 14:03 . 2009-06-29 16:12 44544 c:\windows\system32\pngfilt.dll
+ 2006-02-15 14:03 . 2009-11-01 13:27 72134 c:\windows\system32\perfc009.dat
- 2006-02-15 14:03 . 2009-10-17 07:08 72134 c:\windows\system32\perfc009.dat
- 2007-08-13 22:54 . 2009-06-29 16:12 52224 c:\windows\system32\msfeedsbs.dll
+ 2007-08-13 22:54 . 2009-08-29 07:36 52224 c:\windows\system32\msfeedsbs.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 27648 c:\windows\system32\jsproxy.dll
- 2006-02-15 14:02 . 2009-06-29 16:12 27648 c:\windows\system32\jsproxy.dll
+ 2007-08-13 22:39 . 2009-08-28 10:28 13824 c:\windows\system32\ieudinit.exe
- 2007-08-13 22:39 . 2009-06-29 11:07 13824 c:\windows\system32\ieudinit.exe
- 2006-02-15 14:02 . 2009-06-29 16:12 44544 c:\windows\system32\iernonce.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 44544 c:\windows\system32\iernonce.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 78336 c:\windows\system32\ieencode.dll
- 2006-02-15 14:02 . 2009-06-29 16:12 78336 c:\windows\system32\ieencode.dll
+ 2006-02-15 14:02 . 2009-08-28 10:28 70656 c:\windows\system32\ie4uinit.exe
- 2006-02-15 14:02 . 2009-06-29 11:07 70656 c:\windows\system32\ie4uinit.exe
+ 2007-08-13 22:36 . 2009-08-29 07:36 63488 c:\windows\system32\icardie.dll
- 2007-08-13 22:36 . 2009-06-29 16:12 63488 c:\windows\system32\icardie.dll
+ 2007-08-13 22:36 . 2009-08-29 07:36 44544 c:\windows\system32\dllcache\pngfilt.dll
- 2007-08-13 22:36 . 2009-06-29 16:12 44544 c:\windows\system32\dllcache\pngfilt.dll
- 2009-09-20 14:38 . 2009-06-29 16:12 52224 c:\windows\system32\dllcache\msfeedsbs.dll
+ 2009-09-20 14:38 . 2009-08-29 07:36 52224 c:\windows\system32\dllcache\msfeedsbs.dll
- 2007-08-13 22:54 . 2009-06-29 16:12 27648 c:\windows\system32\dllcache\jsproxy.dll
+ 2007-08-13 22:54 . 2009-08-29 07:36 27648 c:\windows\system32\dllcache\jsproxy.dll
+ 2009-09-20 14:38 . 2009-08-28 10:28 13824 c:\windows\system32\dllcache\ieudinit.exe
- 2009-09-20 14:38 . 2009-06-29 11:07 13824 c:\windows\system32\dllcache\ieudinit.exe
- 2007-08-13 22:39 . 2009-06-29 16:12 44544 c:\windows\system32\dllcache\iernonce.dll
+ 2007-08-13 22:39 . 2009-08-29 07:36 44544 c:\windows\system32\dllcache\iernonce.dll
+ 2009-04-29 04:46 . 2009-08-29 07:36 78336 c:\windows\system32\dllcache\ieencode.dll
- 2009-04-29 04:46 . 2009-06-29 16:12 78336 c:\windows\system32\dllcache\ieencode.dll
- 2007-08-13 22:39 . 2009-06-29 11:07 70656 c:\windows\system32\dllcache\ie4uinit.exe
+ 2007-08-13 22:39 . 2009-08-28 10:28 70656 c:\windows\system32\dllcache\ie4uinit.exe
- 2009-09-20 14:38 . 2009-06-29 16:12 63488 c:\windows\system32\dllcache\icardie.dll
+ 2009-09-20 14:38 . 2009-08-29 07:36 63488 c:\windows\system32\dllcache\icardie.dll
- 2007-08-13 22:42 . 2009-06-29 16:12 17408 c:\windows\system32\dllcache\corpol.dll
+ 2007-08-13 22:42 . 2009-08-29 07:36 17408 c:\windows\system32\dllcache\corpol.dll
+ 2004-08-03 22:59 . 2008-04-13 18:40 96512 c:\windows\system32\dllcache\atapi.sys
- 2006-02-15 14:02 . 2009-06-29 16:12 17408 c:\windows\system32\corpol.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 17408 c:\windows\system32\corpol.dll
+ 2006-02-15 15:41 . 2009-11-30 22:59 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
- 2006-02-15 15:41 . 2009-09-18 21:02 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
- 2006-02-15 15:41 . 2009-09-18 21:02 16384 c:\windows\system32\config\systemprofile\Cookies\index.dat
+ 2009-11-28 22:13 . 2009-11-30 22:59 16384 c:\windows\system32\config\systemprofile\Cookies\index.dat
+ 2009-11-25 08:00 . 2009-11-25 08:00 32768 c:\windows\Installer\{F662A8E6-F4DC-41A2-901E-8C11F044BDEC}\icon.exe
+ 2009-10-22 07:00 . 2009-06-29 16:12 44544 c:\windows\ie7updates\KB974455-IE7\pngfilt.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 52224 c:\windows\ie7updates\KB974455-IE7\msfeedsbs.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 27648 c:\windows\ie7updates\KB974455-IE7\jsproxy.dll
+ 2009-10-22 07:00 . 2009-06-29 11:07 13824 c:\windows\ie7updates\KB974455-IE7\ieudinit.exe
+ 2009-10-22 07:00 . 2009-06-29 16:12 44544 c:\windows\ie7updates\KB974455-IE7\iernonce.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 78336 c:\windows\ie7updates\KB974455-IE7\ieencode.dll
+ 2009-10-22 07:00 . 2009-06-29 11:07 70656 c:\windows\ie7updates\KB974455-IE7\ie4uinit.exe
+ 2009-10-22 07:00 . 2009-06-29 16:12 63488 c:\windows\ie7updates\KB974455-IE7\icardie.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 17408 c:\windows\ie7updates\KB974455-IE7\corpol.dll
+ 2009-10-22 07:00 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB974455-IE7\update\spcustom.dll
+ 2009-10-22 07:00 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB974455-IE7\spmsg.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 44544 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\pngfilt.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 52224 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\msfeedsbs.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 27648 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\jsproxy.dll
+ 2009-08-28 10:01 . 2009-08-28 10:01 13824 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ieudinit.exe
+ 2009-08-29 07:31 . 2009-08-29 07:31 44544 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\iernonce.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 78336 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ieencode.dll
+ 2009-08-28 10:01 . 2009-08-28 10:01 70656 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ie4uinit.exe
+ 2009-08-29 07:31 . 2009-08-29 07:31 63488 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\icardie.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 17408 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\corpol.dll
+ 2006-02-15 14:04 . 2009-08-29 07:36 832512 c:\windows\system32\wininet.dll
- 2006-02-15 14:04 . 2009-06-29 16:12 233472 c:\windows\system32\webcheck.dll
+ 2006-02-15 14:04 . 2009-08-29 07:36 233472 c:\windows\system32\webcheck.dll
- 2006-02-15 14:04 . 2009-06-29 16:12 105984 c:\windows\system32\url.dll
+ 2006-02-15 14:04 . 2009-08-29 07:36 105984 c:\windows\system32\url.dll
- 2006-02-15 14:03 . 2009-10-17 07:08 443034 c:\windows\system32\perfh009.dat
+ 2006-02-15 14:03 . 2009-11-01 13:27 443034 c:\windows\system32\perfh009.dat
- 2006-02-15 14:03 . 2009-06-29 16:12 102912 c:\windows\system32\occache.dll
+ 2006-02-15 14:03 . 2009-08-29 07:36 102912 c:\windows\system32\occache.dll
- 2006-02-15 14:03 . 2009-06-29 16:12 671232 c:\windows\system32\mstime.dll
+ 2006-02-15 14:03 . 2009-08-29 07:36 671232 c:\windows\system32\mstime.dll
+ 2006-02-15 14:03 . 2009-08-29 07:36 193024 c:\windows\system32\msrating.dll
- 2006-02-15 14:03 . 2009-06-29 16:12 193024 c:\windows\system32\msrating.dll
- 2006-02-15 14:03 . 2009-06-29 16:12 477696 c:\windows\system32\mshtmled.dll
+ 2006-02-15 14:03 . 2009-08-29 07:36 477696 c:\windows\system32\mshtmled.dll
- 2007-08-13 22:54 . 2009-06-29 16:12 459264 c:\windows\system32\msfeeds.dll
+ 2007-08-13 22:54 . 2009-08-29 07:36 459264 c:\windows\system32\msfeeds.dll
+ 2007-08-13 22:34 . 2009-08-29 07:36 268288 c:\windows\system32\iertutil.dll
- 2007-08-13 22:34 . 2009-06-29 16:12 268288 c:\windows\system32\iertutil.dll
- 2006-02-15 14:02 . 2009-06-29 16:12 385024 c:\windows\system32\iedkcs32.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 385024 c:\windows\system32\iedkcs32.dll
+ 2007-07-11 16:27 . 2009-08-29 07:36 380928 c:\windows\system32\ieapfltr.dll
- 2007-07-11 16:27 . 2009-06-29 16:12 380928 c:\windows\system32\ieapfltr.dll
+ 2006-02-15 14:02 . 2009-08-27 05:18 161792 c:\windows\system32\ieakui.dll
- 2006-02-15 14:02 . 2009-06-29 08:33 161792 c:\windows\system32\ieakui.dll
- 2006-02-15 14:02 . 2009-06-29 16:12 230400 c:\windows\system32\ieaksie.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 230400 c:\windows\system32\ieaksie.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 153088 c:\windows\system32\ieakeng.dll
- 2006-02-15 14:02 . 2009-06-29 16:12 153088 c:\windows\system32\ieakeng.dll
- 2006-02-15 07:29 . 2009-09-03 07:07 255864 c:\windows\system32\FNTCACHE.DAT
+ 2006-02-15 07:29 . 2009-11-11 08:19 255864 c:\windows\system32\FNTCACHE.DAT
- 2006-02-15 14:02 . 2009-06-29 16:12 133120 c:\windows\system32\extmgr.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 133120 c:\windows\system32\extmgr.dll
- 2006-02-15 14:02 . 2009-06-29 16:12 214528 c:\windows\system32\dxtrans.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 214528 c:\windows\system32\dxtrans.dll
- 2006-02-15 14:02 . 2009-06-29 16:12 347136 c:\windows\system32\dxtmsft.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 347136 c:\windows\system32\dxtmsft.dll
+ 2007-06-19 23:08 . 2009-04-21 03:12 149768 c:\windows\system32\drivers\WpsHelper.sys
- 2007-06-19 23:08 . 2009-04-21 02:12 149768 c:\windows\system32\drivers\WpsHelper.sys
+ 2009-04-29 04:46 . 2009-08-29 07:36 832512 c:\windows\system32\dllcache\wininet.dll
- 2007-08-13 22:54 . 2009-06-29 16:12 233472 c:\windows\system32\dllcache\webcheck.dll
+ 2007-08-13 22:54 . 2009-08-29 07:36 233472 c:\windows\system32\dllcache\webcheck.dll
+ 2007-08-13 22:44 . 2009-08-29 07:36 105984 c:\windows\system32\dllcache\url.dll
- 2007-08-13 22:44 . 2009-06-29 16:12 105984 c:\windows\system32\dllcache\url.dll
+ 2007-08-13 22:44 . 2009-08-29 07:36 102912 c:\windows\system32\dllcache\occache.dll
- 2007-08-13 22:44 . 2009-06-29 16:12 102912 c:\windows\system32\dllcache\occache.dll
+ 2007-08-13 22:54 . 2009-08-29 07:36 671232 c:\windows\system32\dllcache\mstime.dll
- 2007-08-13 22:54 . 2009-06-29 16:12 671232 c:\windows\system32\dllcache\mstime.dll
+ 2007-08-13 22:44 . 2009-08-29 07:36 193024 c:\windows\system32\dllcache\msrating.dll
- 2007-08-13 22:44 . 2009-06-29 16:12 193024 c:\windows\system32\dllcache\msrating.dll
- 2007-08-13 22:54 . 2009-06-29 16:12 477696 c:\windows\system32\dllcache\mshtmled.dll
+ 2007-08-13 22:54 . 2009-08-29 07:36 477696 c:\windows\system32\dllcache\mshtmled.dll
+ 2009-09-20 14:38 . 2009-08-29 07:36 459264 c:\windows\system32\dllcache\msfeeds.dll
- 2009-09-20 14:38 . 2009-06-29 16:12 459264 c:\windows\system32\dllcache\msfeeds.dll
+ 2007-08-13 22:43 . 2009-08-27 05:18 634648 c:\windows\system32\dllcache\iexplore.exe
- 2009-09-20 14:38 . 2009-06-29 16:12 268288 c:\windows\system32\dllcache\iertutil.dll
+ 2009-09-20 14:38 . 2009-08-29 07:36 268288 c:\windows\system32\dllcache\iertutil.dll
- 2007-08-13 22:39 . 2009-06-29 16:12 385024 c:\windows\system32\dllcache\iedkcs32.dll
+ 2007-08-13 22:39 . 2009-08-29 07:36 385024 c:\windows\system32\dllcache\iedkcs32.dll
- 2009-09-20 14:38 . 2009-06-29 16:12 380928 c:\windows\system32\dllcache\ieapfltr.dll
+ 2009-09-20 14:38 . 2009-08-29 07:36 380928 c:\windows\system32\dllcache\ieapfltr.dll
+ 2007-08-13 21:56 . 2009-08-27 05:18 161792 c:\windows\system32\dllcache\ieakui.dll
- 2007-08-13 21:56 . 2009-06-29 08:33 161792 c:\windows\system32\dllcache\ieakui.dll
+ 2007-08-13 22:39 . 2009-08-29 07:36 230400 c:\windows\system32\dllcache\ieaksie.dll
- 2007-08-13 22:39 . 2009-06-29 16:12 230400 c:\windows\system32\dllcache\ieaksie.dll
- 2007-08-13 22:39 . 2009-06-29 16:12 153088 c:\windows\system32\dllcache\ieakeng.dll
+ 2007-08-13 22:39 . 2009-08-29 07:36 153088 c:\windows\system32\dllcache\ieakeng.dll
- 2007-08-13 22:54 . 2009-06-29 16:12 133120 c:\windows\system32\dllcache\extmgr.dll
+ 2007-08-13 22:54 . 2009-08-29 07:36 133120 c:\windows\system32\dllcache\extmgr.dll
+ 2007-08-13 22:35 . 2009-08-29 07:36 214528 c:\windows\system32\dllcache\dxtrans.dll
- 2007-08-13 22:35 . 2009-06-29 16:12 214528 c:\windows\system32\dllcache\dxtrans.dll
+ 2007-08-13 22:35 . 2009-08-29 07:36 347136 c:\windows\system32\dllcache\dxtmsft.dll
- 2007-08-13 22:35 . 2009-06-29 16:12 347136 c:\windows\system32\dllcache\dxtmsft.dll
+ 2007-08-13 22:39 . 2009-08-29 07:36 124928 c:\windows\system32\dllcache\advpack.dll
- 2007-08-13 22:39 . 2009-06-29 16:12 124928 c:\windows\system32\dllcache\advpack.dll
- 2006-02-15 14:02 . 2009-06-29 16:12 124928 c:\windows\system32\advpack.dll
+ 2006-02-15 14:02 . 2009-08-29 07:36 124928 c:\windows\system32\advpack.dll
+ 2009-11-25 08:00 . 2009-11-25 08:00 429568 c:\windows\Installer\1dfd3487.msi
+ 2009-11-05 08:00 . 2009-05-26 11:40 382840 c:\windows\ie7updates\KB976749-IE7\spuninst\updspapi.dll
+ 2009-11-05 08:00 . 2009-05-26 11:40 231288 c:\windows\ie7updates\KB976749-IE7\spuninst\spuninst.exe
+ 2009-10-22 07:00 . 2009-06-29 16:12 827392 c:\windows\ie7updates\KB974455-IE7\wininet.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 233472 c:\windows\ie7updates\KB974455-IE7\webcheck.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 105984 c:\windows\ie7updates\KB974455-IE7\url.dll
+ 2009-10-22 07:00 . 2009-05-26 11:40 382840 c:\windows\ie7updates\KB974455-IE7\spuninst\updspapi.dll
+ 2009-10-22 07:00 . 2009-05-26 11:40 231288 c:\windows\ie7updates\KB974455-IE7\spuninst\spuninst.exe
+ 2009-10-22 07:00 . 2009-06-29 16:12 102912 c:\windows\ie7updates\KB974455-IE7\occache.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 671232 c:\windows\ie7updates\KB974455-IE7\mstime.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 193024 c:\windows\ie7updates\KB974455-IE7\msrating.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 477696 c:\windows\ie7updates\KB974455-IE7\mshtmled.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 459264 c:\windows\ie7updates\KB974455-IE7\msfeeds.dll
+ 2009-10-22 07:00 . 2009-06-29 08:35 634632 c:\windows\ie7updates\KB974455-IE7\iexplore.exe
+ 2009-10-22 07:00 . 2009-06-29 16:12 268288 c:\windows\ie7updates\KB974455-IE7\iertutil.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 385024 c:\windows\ie7updates\KB974455-IE7\iedkcs32.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 380928 c:\windows\ie7updates\KB974455-IE7\ieapfltr.dll
+ 2009-10-22 07:00 . 2009-06-29 08:33 161792 c:\windows\ie7updates\KB974455-IE7\ieakui.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 230400 c:\windows\ie7updates\KB974455-IE7\ieaksie.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 153088 c:\windows\ie7updates\KB974455-IE7\ieakeng.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 133120 c:\windows\ie7updates\KB974455-IE7\extmgr.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 214528 c:\windows\ie7updates\KB974455-IE7\dxtrans.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 347136 c:\windows\ie7updates\KB974455-IE7\dxtmsft.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 124928 c:\windows\ie7updates\KB974455-IE7\advpack.dll
+ 2009-10-22 07:00 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB974455-IE7\update\updspapi.dll
+ 2009-10-22 07:00 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB974455-IE7\update\update.exe
+ 2009-10-22 07:00 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB974455-IE7\spuninst.exe
+ 2009-08-29 07:31 . 2009-08-29 07:31 840704 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\wininet.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 233472 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\webcheck.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 105984 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\url.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 102912 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\occache.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 671232 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\mstime.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 193024 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\msrating.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 477696 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\mshtmled.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 459264 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\msfeeds.dll
+ 2009-08-27 05:18 . 2009-08-27 05:18 634648 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\iexplore.exe
+ 2009-08-29 07:31 . 2009-08-29 07:31 268288 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\iertutil.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 388608 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\iedkcs32.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 380928 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ieapfltr.dll
+ 2009-08-27 05:18 . 2009-08-27 05:18 161792 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ieakui.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 230400 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ieaksie.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 153088 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ieakeng.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 132608 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\extmgr.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 214528 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\dxtrans.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 347136 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\dxtmsft.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 124928 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\advpack.dll
+ 2009-07-21 05:03 . 2009-07-21 05:03 1348432 c:\windows\WinSxS\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9876.0_x-ww_a621d1d5\msxml4.dll
+ 2006-02-15 14:04 . 2009-08-14 13:21 1850624 c:\windows\system32\win32k.sys
+ 2006-02-15 14:04 . 2009-08-29 07:36 1168384 c:\windows\system32\urlmon.dll
+ 2008-08-30 00:06 . 2009-07-31 15:05 1372672 c:\windows\system32\msxml6.dll
+ 2009-07-21 05:05 . 2009-07-21 05:05 1348432 c:\windows\system32\msxml4.dll
+ 2006-02-15 14:03 . 2009-07-31 04:35 1172480 c:\windows\system32\msxml3.dll
+ 2006-02-15 14:03 . 2009-10-21 04:08 3598336 c:\windows\system32\mshtml.dll
+ 2007-08-13 22:54 . 2009-08-29 07:36 6067200 c:\windows\system32\ieframe.dll
- 2007-08-13 22:54 . 2009-07-19 13:32 6067200 c:\windows\system32\ieframe.dll
+ 2009-04-17 12:26 . 2009-08-14 13:21 1850624 c:\windows\system32\dllcache\win32k.sys
+ 2009-04-29 04:46 . 2009-08-29 07:36 1168384 c:\windows\system32\dllcache\urlmon.dll
+ 2009-07-19 07:13 . 2009-07-31 15:05 1372672 c:\windows\system32\dllcache\msxml6.dll
+ 2009-07-19 07:01 . 2009-07-31 04:35 1172480 c:\windows\system32\dllcache\msxml3.dll
+ 2009-04-29 04:46 . 2009-10-21 04:08 3598336 c:\windows\system32\dllcache\mshtml.dll
+ 2009-09-20 14:38 . 2009-08-29 07:36 6067200 c:\windows\system32\dllcache\ieframe.dll
- 2009-09-20 14:38 . 2009-07-19 13:32 6067200 c:\windows\system32\dllcache\ieframe.dll
+ 2009-11-05 08:00 . 2009-08-29 07:36 3598336 c:\windows\ie7updates\KB976749-IE7\mshtml.dll
+ 2009-10-22 07:00 . 2009-06-29 16:12 1159680 c:\windows\ie7updates\KB974455-IE7\urlmon.dll
+ 2009-10-22 07:00 . 2009-07-19 23:03 3597824 c:\windows\ie7updates\KB974455-IE7\mshtml.dll
+ 2009-10-22 07:00 . 2009-07-19 13:32 6067200 c:\windows\ie7updates\KB974455-IE7\ieframe.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 1170944 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\urlmon.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 3600384 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\mshtml.dll
+ 2009-08-29 07:31 . 2009-08-29 07:31 6070784 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ieframe.dll
+ 2009-10-21 21:45 . 2009-06-29 08:33 2452872 c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\ieapfltr.dat
+ 2009-09-02 01:28 . 2009-11-05 17:36 26768832 c:\windows\system32\MRT.exe
-- Snapshot reset to current date --
"TOSCDSPD"="c:\program files\TOSHIBA\TOSCDSPD\toscdspd.exe" [2004-12-30 65536]
"Aim6"="c:\program files\AIM6\aim6.exe" [2009-07-09 49968]
"Messenger (Yahoo!)"="c:\program files\Yahoo!\Messenger\YahooMessenger.exe" [2009-05-27 4351216]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2009-10-10 68856]
"igfxtray"="c:\windows\system32\igfxtray.exe" [2005-11-28 98304]
"igfxhkcmd"="c:\windows\system32\hkcmd.exe" [2005-11-28 77824]
"igfxpers"="c:\windows\system32\igfxpers.exe" [2005-11-28 118784]
"PSQLLauncher"="c:\program files\Protector Suite QL\launcher.exe" [2005-12-22 30208]
"ehTray"="c:\windows\ehome\ehtray.exe" [2005-08-05 64512]
"THotkey"="c:\program files\Toshiba\Toshiba Applet\thotkey.exe" [2006-01-05 352256]
"SynTPLpr"="c:\program files\Synaptics\SynTP\SynTPLpr.exe" [2005-12-16 82009]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2005-12-16 761945]
"LtMoh"="c:\program files\ltmoh\Ltmoh.exe" [2004-08-18 184320]
"Tvs"="c:\program files\Toshiba\Tvs\TvsTray.exe" [2005-11-30 73728]
"SmoothView"="c:\program files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe" [2005-04-27 122880]
"dla"="c:\windows\system32\dla\DLACTRLW.exe" [2005-10-06 122940]
"Pinger"="c:\toshiba\ivp\ism\pinger.exe" [2005-03-18 151552]
"IntelZeroConfig"="c:\program files\Intel\Wireless\bin\ZCfgSvc.exe" [2005-12-05 667718]
"IntelWireless"="c:\program files\Intel\Wireless\Bin\ifrmewrk.exe" [2005-11-28 602182]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2007-11-09 115560]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-05-27 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
"TFncKy"="TFncKy.exe" [BU]
"TDispVol"="TDispVol.exe" - c:\windows\system32\TDispVol.exe [2005-03-11 73728]
"AGRSMMSG"="AGRSMMSG.exe" - c:\windows\agrsmmsg.exe [2005-10-15 88203]
"NDSTray.exe"="NDSTray.exe" [BU]
"TPSMain"="TPSMain.exe" - c:\windows\system32\TPSMain.exe [2005-06-01 282624]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\psfus]
2005-12-22 04:42 40448 ----a-w- c:\windows\system32\psqlpwd.dll
Notification Packages REG_MULTI_SZ scecli psqlpwd
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ccEvtMgr]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ccSetMgr]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Symantec Antivirus]
"EnableFirewall"= 0 (0x0)
"c:\\TOSHIBA\\ivp\\NetInt\\Netint.exe"=
"c:\\TOSHIBA\\Ivp\\ISM\\pinger.exe"= c:\\TOSHIBA\\IVP\\ISM\\pinger.exe
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe"=
"c:\\Program Files\\America Online 9.0\\waol.exe"=
"c:\\Program Files\\Common Files\\AOL\\TopSpeed\\2.0\\aoltsmon.exe"=
"c:\\Program Files\\Common Files\\AOL\\TopSpeed\\2.0\\aoltpspd.exe"=
"c:\\Program Files\\Common Files\\AOL\\1140083713\\EE\\AOLServiceHost.exe"=
"c:\\Program Files\\Common Files\\AOL\\System Information\\sinf.exe"=
"c:\\Program Files\\Common Files\\AOL\\AOL Spyware Protection\\AOLSP Scheduler.exe"=
"c:\\Program Files\\Common Files\\AOL\\AOL Spyware Protection\\asp.exe"=
"c:\\Program Files\\Common Files\\AolCoach\\en_en\\player\\AOLNySEV.exe"=
"c:\\Program Files\\Symantec\\Symantec Endpoint Protection\\Smc.exe"=
"c:\\Program Files\\Symantec\\Symantec Endpoint Protection\\SNAC.EXE"=
"c:\\Program Files\\Common Files\\Symantec Shared\\ccApp.exe"=
R2 FdRedir;FdRedir;c:\program files\Common Files\Protector Suite QL\Drivers\FdRedir.sys [12/21/2005 11:55 PM 13568]
R2 FileDisk2;FileDisk Protector Kernel Driver;c:\program files\Common Files\Protector Suite QL\Drivers\filedisk.sys [12/21/2005 11:55 PM 33024]
R2 smihlp;SMI helper driver;c:\program files\Protector Suite QL\smihlp.sys [12/21/2005 11:25 PM 3456]
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [7/18/2009 12:53 AM 24652]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [8/28/2009 4:00 PM 102448]
S3 COH_Mon;COH_Mon;c:\windows\system32\drivers\COH_Mon.sys [5/29/2007 3:55 PM 23888]
2009-11-26 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 19:34]
2009-07-13 c:\windows\Tasks\Registration reminder 1.job
- c:\windows\system32\OOBE\oobebaln.exe [2006-02-15 00:12]
2009-07-13 c:\windows\Tasks\Registration reminder 2.job
uInternet Connection Wizard,ShellNext = [You must be registered and logged in to see this link.]
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_60D6097707281E79.dll/cmsidewiki.html
FF - ProfilePath - c:\documents and settings\JC\Application Data\Mozilla\Firefox\Profiles\fillbma2.default\
FF - plugin: c:\program files\Java\jre1.5.0_04\bin\NPJava11.dll
FF - plugin: c:\program files\Java\jre1.5.0_04\bin\NPJava12.dll
FF - plugin: c:\program files\Java\jre1.5.0_04\bin\NPJava13.dll
FF - plugin: c:\program files\Java\jre1.5.0_04\bin\NPJava14.dll
FF - plugin: c:\program files\Java\jre1.5.0_04\bin\NPJava32.dll
FF - plugin: c:\program files\Java\jre1.5.0_04\bin\NPJPI150_04.dll
FF - plugin: c:\program files\Java\jre1.5.0_04\bin\NPOJI610.dll
---- FIREFOX POLICIES ----
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl3.rsa_seed_sha", true);
HKCU-Run-eqbqnrip - c:\documents and settings\JC\Local Settings\Application Data\tmskhh\solmsysguard.exe
HKLM-Run-eqbqnrip - c:\documents and settings\JC\Local Settings\Application Data\tmskhh\solmsysguard.exe
AddRemove-RealPlayer 6.0 - c:\program files\Common Files\Real\Update\\rnuninst.exe RealNetworks|RealPlayer|6.0
AddRemove-{2FCE4FC5-6930-40E7-A4F1-F862207424EF} - c:\program files\InstallShield Installation Information\{2FCE4FC5-6930-40E7-A4F1-F862207424EF}\setup.exe REMOVEALL
AddRemove-{91810AFC-A4F8-4EBA-A5AA-B198BBC81144} - c:\program files\InstallShield Installation Information\{91810AFC-A4F8-4EBA-A5AA-B198BBC81144}\setup.exe REMOVEALL
Rootkit scan 2009-11-30 18:20
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\vsdatant]
"ImagePath"="a"
- - - - - - - > 'winlogon.exe'(1252)
c:\program files\Protector Suite QL\infra.dll
c:\program files\Protector Suite QL\homefus2.dll
c:\windows\system32\biologon.dll
c:\program files\Protector Suite QL\homepass.dll
c:\program files\Protector Suite QL\bio.dll
c:\program files\Protector Suite QL\remote.dll
- - - - - - - > 'lsass.exe'(1308)
Completion time: 2009-11-30 18:22
ComboFix-quarantined-files.txt 2009-11-30 23:22
ComboFix2.txt 2009-10-21 04:27
ComboFix3.txt 2009-10-21 00:03
Pre-Run: 15,224,770,560 bytes free
Post-Run: 15,397,937,152 bytes free
- - End Of File - - 66625AC6AD8A697D4CDBDDAAA0ACD827
Jay Cee
Posts Posts : 98
Post by Belahzur on 1st December 2009, 1:39 am
Post by Jay Cee on 1st December 2009, 3:18 am
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Reader 7.0
AIM 6
America Online (Choose which version to remove)
AOL Coach Version 2.0(Build:20041026.5 en)
AOL Connectivity Services
AOL You've Got Pictures Screensaver
Apple Mobile Device Support
Bejeweled 2 Deluxe
Blasterball 2 Revolution
Bluetooth Stack for Windows by Toshiba
Bonjour
CD/DVD Drive Acoustic Silencer
Cheat Engine 5.5
Convert AVI to MP4 1.3
DVD-RAM Driver
ESET Online Scanner v3
ESPNMotion
FATE
Full Tilt Poker
GemMaster Mystic
High Definition Audio Driver Package - KB888111
HijackThis 2.0.2
Hotfix for Windows Media Player 10 (KB903157)
Intel(R) PRO Network Connections Drivers
Intel(R) PROSet/Wireless Software
IrfanView (remove only)
iTunes
J2SE Runtime Environment 5.0 Update 4
LiveUpdate 3.3 (Symantec Corporation)
Macromedia Flash Player 8
mCore
mDrWiFi
Metamail (Toshiba Registration Utility)
mHelp
Microsoft .NET Framework 1.0 Hotfix (KB953295)
Microsoft .NET Framework 1.1
Microsoft Office OneNote 2003
Microsoft Office Professional Edition 2003
Microsoft VC9 runtime libraries
Microsoft Works
mIWA
mLogView
mMHouse
Mozilla Firefox (3.5.5)
mPfMgr
mPfWiz
mProSafe
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
MSXML 6 Service Pack 2 (KB954459)
mWlsSafe
mXML
MyConnect Special Offer
mZConfig
Nero 8 Lite 8.3.6.0
Office 2003 Trial Assistant
Otto
PokerStars
Polar Golfer
Pure Networks Port Magic
QuickTime
SCRABBLE
SD Secure Module
Security Update for Windows XP (KB969897)
Sonic DLA
Sonic Encoders
Sonic RecordNow!
Synaptics Pointing Device Driver
Texas Instruments PCIxx21/x515/xx12 drivers.
TOSHIBA Assist
TOSHIBA ConfigFree
TOSHIBA Controls
TOSHIBA Game Console
TOSHIBA Hotkey Utility
TOSHIBA PC Diagnostic Tool
TOSHIBA Power Saver
TOSHIBA SD Memory Card Format
TOSHIBA Software Modem
TOSHIBA Software Upgrades
TOSHIBA Speech System Applications
TOSHIBA Speech System SR Engine(U.S.) Version1.0
TOSHIBA Speech System TTS Engine(U.S.) Version1.0
TOSHIBA TouchPad ON/Off Utility
TOSHIBA TV Tuner 4.0.12.73
TOSHIBA Utilities
TOSHIBA Virtual Sound
Update for Windows Internet Explorer 7 (KB976749)
Update for Windows Media Player 10 (KB910393)
Update for Windows Media Player 10 (KB913800)
Update for Windows Media Player 10 (KB926251)
Update Rollup 2 for Windows XP Media Center Edition 2005
Viewpoint Media Player
WildTangent Web Driver
Windows Imaging Component
Windows Media Format Runtime
Windows XP Media Center Edition 2005 KB888316
Windows XP Media Center Edition 2005 KB894553
Windows XP Media Center Edition 2005 KB895678
Windows XP Media Center Edition 2005 KB908250
Windows XP Media Center Edition 2005 KB973768
Windows XP Service Pack 3
WinRAR archiver
Yahoo! Messenger
Yahoo! Music Engine
Jay Cee
Posts Posts : 98
Post by Belahzur on 1st December 2009, 10:06 pm
Post by Jay Cee on 1st December 2009, 10:27 pm
It is working well tho I havent restarted yet. Also, just a fyi but I had to use rkill first in order to use combofix (even after renaming it). I'll restart and then let you know if anything comes up.
Jay Cee
Posts Posts : 98
Post by Jay Cee on 1st December 2009, 10:40 pm
Just restarted and nothing has popped up. Everything looks straight. Thanks for the help. Anything else I need to do now?
Jay Cee
Posts Posts : 98
Post by Belahzur on 1st December 2009, 11:36 pm
