Antivirus System Pro
Post by Barnaclebillbmc on 28th November 2009, 1:21 pm
Good morning, my computer has been infected with this virus and I just don't know what to do. I have looked at some of the other postings regarding the same issue and it looks a bit daunting. I'm not very experienced with computers and don't want to goof anything up. I am using my daughters computer to post this because I cant do anything with mine, and any time I try to do Anything I receive a pop up. Any help you could give me to get my computer working would be greatly appreciated.
Thank you
Bill
Barnaclebillbmc
Joined Joined : 2009-11-28
Points Points : 25708
Re: Antivirus System Pro
Post by Belahzur on 28th November 2009, 6:50 pm
Points Points : 245111
Post by Barnaclebillbmc on 28th November 2009, 8:45 pm
Good afternoon Belahzur, I cant dowlnoad anything on the computer because I cant open anything without a pop up coming up and blocking it. Is there anyway around this?
Barnaclebillbmc
Post by Belahzur on 29th November 2009, 1:49 am
It wont block everything, we just keep trying till we find something that works.
