AntiVirus System Pro Help?
Post by SilentShadowx on Fri Nov 27, 2009 10:02 pm
Hey guys.
Alright, so my other computer is infected with this malware system and we tried the method that is stickied. Once we restarted our computer, it is still there. We tried finding the file, but we remained unsuccessful.
Can someone help us get this off our computer? We're desperate! >.<
Thanks!
SilentShadowx
Gender : Female
OS : XP
# Likes : 0
Re: AntiVirus System Pro Help?
Post by Belahzur on Fri Nov 27, 2009 11:13 pm
# Likes : 1
