Antivirus System Pro
Post by bappycan on Fri Nov 27, 2009 8:58 pm
Antivirus System pro appeared on my lower task bar and I cannot get the program removed. I downloaded instructions from another computer and the every time I try to complete a step, such as getting into task manager, it blocks the function and tells me there is a virus in that function. I basically cannot do anything without getting pop-up error messages saying I "cannot go there". The only thing it would allow me to do is purchase the software and perform a scan/removal. I did not do that. Help!
bappycan
Joined Joined : 2009-11-27
Points Points : 25643
Re: Antivirus System Pro
Post by Belahzur on Fri Nov 27, 2009 11:07 pm
Points Points : 245049
