mcdbus.sys problem SOLVED
Solved mcdbus.sys problem SOLVED
Post by PsychoLeet on Fri Nov 27, 2009 6:11 pm
EDIT: I tried uninstalling MagicDisc, and it worked! NO MORE Blue Screens Of Death!
Hello, every once in a while I seem to have a Blue Screen Of Death that is related to mcdbus.sys, after using google to search up mcdbus.sys, I found out that mcdbus.sys is a driver for my MagicDisc Virtual ISO Mounter. Please help me.
Last edited by Doctor Inferno on Sat Nov 28, 2009 2:45 am; edited 2 times in total (Reason for editing : Solved the problem!)
PsychoLeet
Posts Posts : 14
Joined Joined : 2009-07-02
OS OS : Windows XP Service Pack 3 32-bit
Points Points : 27152
Solved Re: mcdbus.sys problem SOLVED
Post by glenngawron on Sat Mar 30, 2013 2:27 pm
It's a Windows XP and MagicDisc issue that I used to have. I never had that problem with Windows 7 or 8, but I did have a problem getting the driver to install because the driver was not digitally signed.
I had to go through a tedious process to get the driver to be accepted by Windows 7 and 8! I wrote a step by step guide complete with links to download the modified files so no one else has to download Windows SDK and use Inf2cat.exe for the install process. Here is the url to my blog post http://onlineprojectupdates.blogspot.com/2013/03/fix-for-magicdisc-driver-mcdbusinf-not.html Hope it saves many people time because it sure took a lot of mine!
glenngawron
Joined Joined : 2013-03-30
OS OS : Windows 8 X64
Points Points : 13470
