antivirus system pro/nuqel.e and bankerfox.a problem
Post by azseb on 27th November 2009, 5:55 pm
Hello everyone,
I have problems with antivirus system pro/nuqel.e and bankerfox.a, i tried reading your guides for removal... but the thruth is my pc does not allow me to open anyfiles.... as soon as as triy to open a file tells me security warning and that the file i try to open is infected. The problem started 2 days ago. I usually use firefox but since the problem internet explorer opens to viagra pages and adult sites by itself. I would appreciate any help i can get. Smile
azseb
Posts Posts : 3
Joined Joined : 2009-11-26
Points Points : 25733
Re: antivirus system pro/nuqel.e and bankerfox.a problem
Post by Belahzur on 27th November 2009, 11:39 pm
Points Points : 245101
Post by azseb on 28th November 2009, 7:20 pm
Hello I tried download exehelper with firefox and it says this download has been blocked by your security zone policy raktor.net. I tried internet explorer and It does not connect to the internet. let me know whats the next step, thanks Belahzur!!
azseb
Posts Posts : 3
Post by azseb on 28th November 2009, 7:25 pm
Ok i changed security settings and i can download file, but once i open file i get a window that says exehelper.exe has encounter a problem and needs to close, we are sorry for the inconvenience it has a debug and send error report and dont sent buttons.
azseb
Posts Posts : 3
Post by Belahzur on 29th November 2009, 1:58 am
What security program blocked it in the first place? can you disable that program?
