Problem scanning in safe mode
Post by Dididothat on 27th November 2009, 5:40 pm
Hi there,
hope someone can help me. Anti Virus System Pro attacked my laptop. I managed to download the Malwarebytes Anti-Malware in safe mode. I had to stay in safe mode as the virus will not let me open anything otherwise. The only problem is once it starts scanning my computer shuts down. What am I doing wrong??
Thanks in advance.
Annie
Dididothat
Joined Joined : 2009-11-27
Points Points : 25718
Re: Problem scanning in safe mode
Post by Belahzur on 27th November 2009, 11:38 pm
Points Points : 245111
Post by Dididothat on 27th November 2009, 11:59 pm
Thanks so much for responding so quickly. I actually think I am all set. I turned my comp off for a couple of hours and tried it again and it worked fine, managed to scan without it shutting down.
Thanks a bunch!
Dididothat
