Antivirus System pro has a hold on me....
Post by maestro1313 on 25th November 2009, 2:55 pm
On an XP system, I've downloaded Malwarebytes...
It wouldn't even let me get to the task manager to kill applications.
I found a file at bleepingcomputer.com called rkill.com which I run a few times and it removes things from the task manager so I can continue on. It takes 3 or 4 times.
Then, I run Malwarebytes Anti Malware and it finds 1 file. (Doesn't seem to matter if I do quick or full scan)
Anyway, then everything seems to run Ok... BUT... then I reboot and it seems to start all over again.
Not sure if I've just got files in there... or if we're dealing with registry settings now, but could sure use some help.
Please post any thoughts you have.
Mark
maestro1313
Joined Joined : 2009-11-25
Points Points : 25708
Re: Antivirus System pro has a hold on me....
Post by maestro1313 on 25th November 2009, 3:44 pm
I will run the hijack log this afternoon... and post soon afterward...
maestro1313
Post by Belahzur on 25th November 2009, 7:30 pm
Okay, standing by.
Points Points : 245079
