Java uninstall help?
Post by ChocolateWayne on Tue Nov 24, 2009 10:55 am
OK so I am trying to uninstall java 6 update (11) and when i click uninstall it says fatal error occurred. How do i remove it? please help!
ChocolateWayne
OS : XP
# Likes : 0
Re: Java uninstall help?
Post by Dr Jay on Tue Nov 24, 2009 2:50 pm
Try JavaRA.
Please download JavaRa and unzip it to your Desktop.
Double click JavaRa.exe then click Remove Older Versions.
Follow any prompts.
Next, open JavaRa.exe again, and select Search For Updates.
Select Update Using Sun Java's Website --> Search, and continue the instructions for downloading and installing the latest Java version.
Topic moved.
OS : Windows 10 Home & Pro
# Likes : 10
