Flash player not working after virus removal
Solved Flash player not working after virus removal
Post by lynmak on 24th November 2009, 8:25 am
I used instructions on this site to remove banker Fox and (i think) the win32nugel viruses and since then, my Flash Player does not work when I try to watch a you tube video, or enter a website that requires it to play an intro, etc...
On youtube, it says to turn on javascript or to download the latest flashplayer. I have gone into "tools" on the internet browser > internet options >security > custom > active scripting > disabled it first and then "enabled" it later.....and I have also tried downloading the latest flash but both those attmepts did nothing.
I am totally computer illiterate and it was a miracle I understood the instructions to remove those viruses previously.
Please advise in easily understandable language. Thanks a lot.
ps. Recently someone posted this thread: Dangerous "unpatchable" flaw discovered in Adobe Flash. and I wonder if this is my problem?
lynmak
Posts Posts : 5
Joined Joined : 2009-10-20
Points Points : 26113
Solved Re: Flash player not working after virus removal
Post by Doctor Inferno on 24th November 2009, 10:41 am
Please try in an alternative browser like Firefox and let me know how it goes.
Points Points : 104630
Post by lynmak on 27th November 2009, 4:48 am
It does not work with firefox either.
lynmak
Posts Posts : 5
Post by Doctor Inferno on 27th November 2009, 9:31 am
Download this to completely uninstall flash player:
http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe
Download the latest version of flash player and install it here:
http://get.adobe.com/flashplayer/
Post by lynmak on 28th November 2009, 7:14 am
Hi, it still did not work. Youtube says the same thing as before.
lynmak
Posts Posts : 5
Post by lynmak on 7th December 2009, 8:53 am
Bump
lynmak
Posts Posts : 5
Post by Lance(HAOH) on 8th December 2009, 9:40 am
Try these solutions:
1. Mouse over the flash object. Right Click>settings
Uncheck the box which states 'enable hardware aceleration'
2. If you are using IE, Go to the menu bar. Tools>Internet Options>click the security tab>Click 'reset all zones to default level' button
3. If the above solutions do not work for you, Go to the menu bar. Tools>Internet Options>click the advanced tab>Find the section Reset Internet Explorer settings.>Click the reset button.
Hope these solutions will work for you.
Lance(HAOH)
Posts Posts : 138
Joined Joined : 2008-12-12
OS OS : Windows XP Professional, Windows 7 Enterprise, Windows 8 Professional WMC, Ubuntu Linux
Protection Protection : Avast 8
Points Points : 30210
Post by lynmak on 14th December 2009, 7:48 am
Hi Lance,
your instructions worked, although I didn't complete #1. I think it was #3 that did it.
Thanks very much for your help!
Lyn
lynmak
Posts Posts : 5
Post by Lance(HAOH) on 16th December 2009, 3:16 am
You are welcome! Smile
Lance(HAOH)
Posts Posts : 138
Solved Thanks!
Post by oldpole on 8th May 2012, 7:36 pm
I'm glad you guys leave these posted. Three years after this fix was posted, I used it. You saved me from hours [days?] of not having my computer accessible, couldn't get my email, [Comcast must use flash to access it]. This isn't the first time you guys have helped me, so I purchased a copy of the tips book! This site is a great source for those of us who may be semi literate, but don't do I.T. as a living!!!
oldpole
Posts Posts : 3
Joined Joined : 2009-06-11
OS OS : windows professional
Protection Protection : norton
Points Points : 27394
