AntiVirus System Pro Infection
Post by ***M5*** on Tue 24 Nov 2009, 4:24 pm
The virus has killed my internet connection. I tried removing this virus w/ avast , but after restart the virus reappeared. Also, I have trouble with running combo fix through the run command. It says that windows cannot find that file name ????
Your help will be greatly appreciated. Thanks in advance.
Operating System : XP
Re: AntiVirus System Pro Infection
Post by DragonMaster Jay on Tue 24 Nov 2009, 4:40 pm
Please transfer this download from a clean computer to the infected one.
Please download ComboFix from
Alternate link:
Alternate link:
GeekPolice Academy Manager
DragonMaster Jay
Manager | Tech Officer
