AntiVirus System Pro
Post by annab on 24th November 2009, 4:13 am
What do I do if I can't even get internet access anymore because of this stupid thing. If I try to go to Start - Control Panel - can't even do anything there either. I start getting pop ups saying Application cannot be excuted. The file*******.exe is infected.
What do I do?.
annab
annab
Posts Posts : 6
Joined Joined : 2009-11-24
Points Points : 25764
Re: AntiVirus System Pro
Post by Dr Jay on 24th November 2009, 4:25 am
Please transfer this download from a clean computer on to the infected one, and then run it as instructed.
Posts Posts : 13743
Points Points : 302211
Post by annab on 24th November 2009, 4:43 am
When I click ok i get an error message saying I can't use this software.
annab
Posts Posts : 6
Post by annab on 24th November 2009, 4:47 am
Actual lwarning message says Application cannot be executed. The file commy.exe is infected. Do you want to activat3e your antivirus software now?
I click no.
Then another message pops up: C:\Docuemnts and Setting\Owner\Desktop\commy.exe
Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access the item.
annab
Posts Posts : 6
Post by Dr Jay on 24th November 2009, 5:05 am
Posts Posts : 13743
Post by annab on 24th November 2009, 2:38 pm
Good Morning. I got the Malwarebytes loaded to the infected computer via a jump drive. Double clicked on the software to start the scan and I got an error.
Application cannot be executed. The file mbam. exe is infected. Do you want to activate your antivirus software now?
What do you think?
annab
Posts Posts : 6
Post by Dr Jay on 24th November 2009, 2:49 pm
Your computer is infected with a dangerous infection:
We have hit a dead end. Please tell me when you have completed a reformat and reinstall.
I am sorry for the bad news. I do not understand why these mean people make such harsh viruses, and I wish there was a way to clean your system without everything being damaged. But, the problem is, cleaning the system, most files will be damaged. It is like trying to clean up a city that just had a tornado or hurricane run through it. Takes rebuilding, and time to set back up.
Posts Posts : 13743
Post by annab on 26th November 2009, 12:58 am
Thank you. Have FINALLY finished re-installing windows. Everything is back to normal. I appreciate your time.
annab
Posts Posts : 6
Post by Dr Jay on 26th November 2009, 5:08 am
Great. Here are some good malware prevention tips. Smile Please keep in mind, malware is a continuous danger on the Internet. It is highly important to stay safe while browsing, to prevent re-infection.
Software recommendations
Antivirus/Antispyware
  • [You must be registered and logged in to see this link.]: this is Microsoft's free antivirus/antispyware program. It equips you with protection against viruses, spyware, trojans, rootkits, and worms. It is also light on the computer's performance. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
  • [You must be registered and logged in to see this link.]: this is one of the most powerful, and easiest to use security software. The free version equips you with protection against viruses, spyware, trojans, rootkits, worms, and rogue software. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
Firewall
Note: Please keep ALL of these programs up-to-date and run them whenever you suspect a problem to prevent malware problems.
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 13743
