Anti-Virus System Pro - Me Too! Pls Help
Post by klapensee on 24th November 2009, 3:45 am
Hey Guys,
I am in dire need of your help. I have this anti-virus system Pro virus and My kids have allowed it to penetrate. The good thing is that I have a laptop that I can dowbnload and save files to the infected computers shared drives. Can you please help me? What should I do first. I have installed Malware Bytes and nothing is being found. I cant access the internet on the infected computer and when I try and open programs I get "File X has been infected" Please help....
KeV
klapensee
Posts Posts : 14
Joined Joined : 2009-11-23
OS OS : Windows Vista
Points Points : 25877
Re: Anti-Virus System Pro - Me Too! Pls Help
Post by Dr Jay on 24th November 2009, 4:24 am
Posts Posts : 13812
Points Points : 302439
Post by klapensee on 24th November 2009, 4:43 am
Hey DragonMaster,
It is not even letting me do that...it is saying that it cannot find the file?
Can i do this in Safe mode?
klapensee
Posts Posts : 14
Post by Dr Jay on 24th November 2009, 5:03 am
Yes, you can try in Safe Mode.
Posts Posts : 13812
Post by klapensee on 24th November 2009, 5:04 am
DragonMaster Jay wrote:Yes, you can try in Safe Mode.
Its working....
klapensee
Posts Posts : 14
Post by Dr Jay on 24th November 2009, 5:06 am
Good. Post when ready.
Posts Posts : 13812
Post by klapensee on 24th November 2009, 5:13 am
DragonMaster Jay wrote:Good. Post when ready.
Hey Dragon,
Do you know how people are getting this virus? it has just like blown up all at once....
klapensee
Posts Posts : 14
Post by Dr Jay on 24th November 2009, 5:19 am
It happens in bursts because that is the way attackers work. They usually work in big chunks. It is all about referrals, and hijacking. They find a way to trick the minds of normal people browsing the Internet. It is now the most common scam on the Internet, except for "ways to make money."
Posts Posts : 13812
Post by klapensee on 24th November 2009, 5:58 am
DragonMaster Jay wrote:It happens in bursts because that is the way attackers work. They usually work in big chunks. It is all about referrals, and hijacking. They find a way to trick the minds of normal people browsing the Internet. It is now the most common scam on the Internet, except for "ways to make money."
Hey Dragon,
Ran Combo fix and went through the process. System re-booted and then finished the final stages of the clean. Went to create Log file and stalled. Finally crashed. Went back to normal state to see if I could turn off Anti-Virus and it's Fixed! Am i clean now?
Should I run the additional tools: OTL, SREng, RBFA, and DragonFix?
klapensee
Posts Posts : 14
Post by Dr Jay on 24th November 2009, 6:13 am
Yes, please run the additional tools. Your system appears clean now, yes. Smile
But, it is damaged, so we must repair it.
Posts Posts : 13812
Post by klapensee on 24th November 2009, 6:34 am
DragonMaster Jay wrote:Yes, please run the additional tools. Your system appears clean now, yes. Smile
Hey Dragon,
Have run the Malwarebytes, House call with no threats found. Now with the OTL log files would you like me to post them or keep plugging along?
klapensee
Posts Posts : 14
Post by Dr Jay on 24th November 2009, 6:43 am
If you could post the ComboFix log, it would be good.
Posts Posts : 13812
Post by klapensee on 24th November 2009, 6:54 am
DragonMaster Jay wrote:If you could post the ComboFix log, it would be good.
Dragonmaster...when I am running The Dragonfix do I call the system restore (Runthisfirst: Dragonfix.reg?) I dont want to screw up all this progress
I addition, I was never able to save the ComboFix Log file due to my system crashing. So I just carried on with the tools and steps as per Rainbow 24
klapensee
Posts Posts : 14
Post by Dr Jay on 24th November 2009, 6:58 am
Ok. Forget those steps, please, and let us move on with this:
Click the Settings button.
Set it to Maximum
Posts Posts : 13812
Post by klapensee on 24th November 2009, 7:09 am
klapensee
Posts Posts : 14
Post by Dr Jay on 24th November 2009, 7:31 am
  • Click Start
  • Click Start
Posts Posts : 13812
