devistating antivirus system pro
Re: devistating antivirus system pro
Post by greyhawk on 3rd December 2009, 10:01 pm
Hello Belahzur,
I havn't heard from you for a couple of days now.
Are you prepared to continue to try to help me, or am I unhelpable?
Should I just give up on this computer and plan to buy another one. That would solve the current problem, but how do I prevent the same thing happening to a different machine, and I can't afford it anyway.
Hope to hear from you soon.
Thanks,
K.
greyhawk
Posts Posts : 16
Joined Joined : 2009-11-23
Points Points : 25948
Post by Belahzur on 4th December 2009, 12:51 am
Sorry, didn't leave you, just miss your post, you may have posted when I was posting to others and I didn't see it in the list as I use tabs.
DragonFix has a few bugs, I talked to the developer so he should fix them soon. For now, I'm not sure if we can repair it as malware damage can be ever lasting, like looking for a needle in a haystack.
Points Points : 245091
Post by greyhawk on 4th December 2009, 2:45 am
G'day,
I appreciate all your time and effort, thanks .
If DragonFix can be debugged and can be made available to me, I will gladly run it again and report on it's performance with my problem.
Thanks again for your help so far.
Regards,
K.
greyhawk
Posts Posts : 16
