Help with Antivrus System Pro
Post by Mikky on 22nd November 2009, 10:38 pm
Hi, i really need help.
I tried downloading Malwarebytes. I installed it, and it wouldnt let me open the program. I tried downloading the Hijacker thing, and it wouldn't even let me install that. Help please.
Mikky
Posts Posts : 6
Joined Joined : 2009-11-22
Points Points : 25804
Re: Help with Antivrus System Pro
Post by Belahzur on 23rd November 2009, 12:37 am
Points Points : 245101
Post by Mikky on 23rd November 2009, 2:30 am
I managed to get the program onto my computer, but now it wont let me open it.
Mikky
Posts Posts : 6
Post by Belahzur on 23rd November 2009, 8:37 pm
Rename the installer to something else, see if it lets you now.
Post by Mikky on 24th November 2009, 12:15 am
OK, I have it now:
Scan saved at 6:14:26 PM, on 11/23/2009
Platform: Unknown Windows (WinNT 6.01.3504)
MSIE: Internet Explorer v8.00 (8.00.7600.16385)
C:\Windows\system32\taskhost.exe
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Program Files\Winamp\winampa.exe
C:\Program Files\Pando Networks\Media Booster\PMB.exe
C:\Users\Michael\AppData\Local\qrbito\oxypsysguard.exe
C:\Windows\system32\SearchFilterHost.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files\Winamp\winampa.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKCU\..\Run: [Pando Media Booster] C:\Program Files\Pando Networks\Media Booster\PMB.exe
O4 - HKCU\..\Run: [qhhagatq] C:\Users\Michael\AppData\Local\qrbito\oxypsysguard.exe
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
O13 - Gopher Prefix:
End of file - 2575 bytes
Mikky
Posts Posts : 6
Post by Belahzur on 24th November 2009, 12:58 am
Post by Mikky on 24th November 2009, 1:16 am
Database version: 2775
Windows 6.1.7600
11/23/2009 7:15:43 PM
mbam-log-2009-11-23 (19-15-43).txt
Objects scanned: 78546
Time elapsed: 6 minute(s), 39 second(s)
Registry Keys Infected: 1
Mikky
Posts Posts : 6
Post by Mikky on 24th November 2009, 2:31 am
Everything seems to be working fine now, thanks alot guys. Thank You!
Mikky
Posts Posts : 6
Post by Belahzur on 24th November 2009, 9:32 pm
Please re-open Malwarebytes, click the Update tab, and click Check for Updates. Then, click the Scanner tab, select Perform Quick Scan, and press Scan.
