antivirus pro removal problems
Post by computerman7 on Sat Nov 21, 2009 1:46 pm
I was able to download the anti-malware software you suggested on a safe computer and I got it on the infected machine. I ran a couple of scans and got rid of infected files but the virus is still there and there always seems to be one infected file left after every scan I run. Any suggestions? thanks.
computerman7
Joined Joined : 2009-11-21
OS OS : windows 98
Re: antivirus pro removal problems
Post by Belahzur on Sat Nov 21, 2009 9:54 pm
