I need a little help!
Post by tomdotcom89 on Sat Nov 21, 2009 4:38 am
I am having a problem with this program (i guess is what it is) Antivirus system pro trying to run on my computer. it keeps popping up saying things like "googletoolbaruser_32.exe is infected" it asks if i would like to purchase software from this website "http://osadwarekill2009.com/purchase?r=56.1". From what i have found on this site a few other people have had this problem, i tried following the instructions given to them but when i try to install the software this site recommends this antivirus system pro "program" cuts it off and says (software name here).exe may be infected, and stops the program from running. i tried using windows task manager to stop this program but it does the same as the software downloads and it says taskmgr.exe is infected ... buy our stuff. I don't really have any clue what to do about this so any help would be greatly appreciated!
Last edited by tomdotcom89 on Sat Nov 21, 2009 4:41 am; edited 1 time in total (Reason for editing : misspelling)
tomdotcom89
Joined Joined : 2009-11-21
OS OS : vista
Points Points : 25723
Re: I need a little help!
Post by Dr Jay on Sat Nov 21, 2009 4:53 am
Posts Posts : 13717
Points Points : 302127
