ANTIVIRUS SYSTEM PRO HAS PARALYZED MY COMPUTER!!
Post by sunshyne298 on 21st November 2009, 3:45 am
I am running Windows XP and tonight, as I was about to shut my computer off, I was struck by the Anti-virus System Pro problem. I can't do a System Restore, it won't let me. I can't open Regedit, it won't let me. I can't get into my registry at all, it won't let me. I can't download any anti-virus programs to get rid of this because it doesn't let me. I've read the posts on this forum and can't do any of the things suggested. I've tried downloading Hijack This and it shuts me down every time.
I need help to get rid of this! I am absoƖute desperate for help because everything that has been suggested has been something this thing isn't allowing me to do. And I don't have the Windows CD, either.
PLEASE HELP! I have to fix this myself because I just don't have the money to take it somewhere to be fȋxed.
Thanks for your time!
sunshyne298
Joined Joined : 2009-11-21
Points Points : 25758
Re: ANTIVIRUS SYSTEM PRO HAS PARALYZED MY COMPUTER!!
Post by Dr Jay on 21st November 2009, 4:23 am
Posts Posts : 13810
Points Points : 302437
Post by sunshyne298 on 21st November 2009, 5:02 pm
Ok. I have gotten rid of it...at least for now. I shut my computer off after coming here for help last night. When I turned comp on this morning, I was able to get in to Safe Mode! I couldn't do that last night. In safe mode, I hunted it down and deleted what I could. The application name in my computer was "bpbxsysguard". The only thing I could find in my registry was located at HKEY_CURRENT_USER\SOFTWARE\AVSCAN. I deleted that as well.
Are there any programs out there that are able to prevent this from happening again? I have AVG free antivirus on my computer, but that didn't stop it from happening. Is there anything out there that can prevent it?
Thanks for all your help. I appreciate it!
sunshyne298
Post by Dr Jay on 22nd November 2009, 1:36 am
I will let you know of any preventative measures, after your computer is declared clean. It helps us work through the removal process better.
Please post the log from ComboFix, so I may check it.
Posts Posts : 13810
