Please I need help, I'm so bummed at my mistake.
Re: Please I need help, I'm so bummed at my mistake.
Post by Belahzur on 19th November 2009, 2:06 am
Sorry, but we can't help you. Your log shows you have used a crack for Windows which is ILLEGAL, and in most likely terms, malware anyhow.
I would recommend you get your hands on a real XP disc and format the machine using the proper license code.
Points Points : 245101
Post by spitblueblood on 19th November 2009, 2:29 am
Thanks anyways........................................................................................
spitblueblood
Joined Joined : 2009-11-19
Points Points : 25788
Post by Belahzur on 19th November 2009, 7:53 pm
If your still here, we might be able to help.
