Antivirus System Pro / bankerfox.a / nuqel.e
Post by tommehr on Tue Nov 17, 2009 9:22 pm
Hi there,
Having trouble with some malware that seems to be imitating an antivirus program and trying to get me to buy some software. I keep getting 'Infiltration Alerts' saying that Antivirus System Pro has detected either Nuqel.E or Bankerfox.A and asking if I want to block this attack, plus popups stating that I have lots of vulnerabilities and a mocked-up version of a antivirus that tries to look like it is scanning my files. Everytime I try and open a program it says that the file/program is infected and it won't open it (although if I leave that warning popup up then it will let me open the program). It also keeps opening up IE and trying to go to unsavoury websites (I have Firefox set as my default browser).
I'll post a HijackThis log in my next post.
Thanks,
Tom
tommehr
OS : XP
Re: Antivirus System Pro / bankerfox.a / nuqel.e
Post by tommehr on Tue Nov 17, 2009 9:37 pm
Scan saved at 21:37:09, on 17/11/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16915)
C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\Program Files\EeePC\ACPI\AsTray.exe
C:\Program Files\EeePC\ACPI\AsAcpiSvr.exe
C:\Program Files\EeePC\ACPI\AsEPCMon.exe
C:\Program Files\Elantech\ETDCtrl.exe
C:\WINDOWS\system32\igfxext.exe
C:\WINDOWS\system32\igfxtray.exe
C:\WINDOWS\system32\igfxsrvc.exe
C:\WINDOWS\system32\hkcmd.exe
C:\WINDOWS\RTHDCPL.EXE
C:\WINDOWS\SOUNDMAN.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe
C:\Documents and Settings\Tom Rowberry\Local Settings\Application Data\xopcpj\jngrsysguard.exe
C:\Program Files\TouchFreeze\TouchFreeze.exe
C:\Program Files\Nokia\Nokia PC Suite 7\PCSuite.exe
C:\Program Files\Asus\EeePC\Super Hybrid Engine\SuperHybridEngine.exe
C:\Documents and Settings\Tom Rowberry\Start Menu\Programs\Startup\AutoHotkey.exe
C:\Program Files\Alwil Software\Avast4\setup\avast.setup
C:\Program Files\Cisco Systems\VPN Client\cvpnd.exe
C:\Program Files\Common Files\InterVideo\RegMgr\iviRegMgr.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
C:\Program Files\PC Connectivity Solution\Transports\NclUSBSrv.exe
C:\Program Files\PC Connectivity Solution\Transports\NclRSSrv.exe
C:\Documents and Settings\Tom Rowberry\My Documents\Firefox Downloads\winlogon(2).scr
C:\Program Files\Windows Live\Contacts\wlcomm.exe
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.227 winsecurepro2009.microsoft.com
O1 - Hosts: 91.212.127.227 winsecurepro2009.com
O1 - Hosts: 91.212.127.227 [You must be registered and logged in to see this link.]
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O4 - HKLM\..\Run: [AsusTray] C:\Program Files\EeePC\ACPI\AsTray.exe
O4 - HKLM\..\Run: [AsusACPIServer] C:\Program Files\EeePC\ACPI\AsAcpiSvr.exe
O4 - HKLM\..\Run: [AsusEPCMonitor] C:\Program Files\EeePC\ACPI\AsEPCMon.exe
O4 - HKLM\..\Run: [ETDWare] C:\Program Files\Elantech\ETDCtrl.exe
O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [ubaqqsmd] C:\Documents and Settings\Tom Rowberry\Local Settings\Application Data\xopcpj\jngrsysguard.exe
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKCU\..\Run: [TouchFreeze] C:\Program Files\TouchFreeze\TouchFreeze.exe
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [PC Suite Tray] "C:\Program Files\Nokia\Nokia PC Suite 7\PCSuite.exe" -onlytray
O4 - HKCU\..\Run: [ubaqqsmd] C:\Documents and Settings\Tom Rowberry\Local Settings\Application Data\xopcpj\jngrsysguard.exe
O4 - Startup: AutoHotkey.exe
O4 - Global Startup: SuperHybridEngine.lnk = ?
O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O8 - Extra context menu item: Send To Bluetooth - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O16 - DPF: {A90A5822-F108-45AD-8482-9BC8B12DD539} (Crucial cpcScan) - [You must be registered and logged in to see this link.]
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: Cisco Systems, Inc. VPN Service (CVPND) - Cisco Systems, Inc. - C:\Program Files\Cisco Systems\VPN Client\cvpnd.exe
O23 - Service: IviRegMgr - InterVideo - C:\Program Files\Common Files\InterVideo\RegMgr\iviRegMgr.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
End of file - 8014 bytes
tommehr
OS : XP
Post by Belahzur on Tue Nov 17, 2009 9:51 pm
I notice that you have Spybot's TeaTimer running. While this is normally a wonderful tool to protect against hijackers, it can also interfere with HijackThis fixes. So please disable TeaTimer by doing the following:
1) Run Spybot-S&D
2) Go to the Mode menu, and make sure "Advanced Mode" is selected
3) On the left hand side, choose Tools -> Resident
4) Uncheck "Resident TeaTimer" and OK any prompts
You can reenable TeaTimer once your system is clean.
Please make sure Teatimer is disable before we do this, otherwise this fix will fail.
Post by tommehr on Tue Nov 17, 2009 10:12 pm
Database version: 2775
17/11/2009 22:12:20
mbam-log-2009-11-17 (22-12-20).txt
Objects scanned: 87437
Time elapsed: 7 minute(s), 49 second(s)
Registry Keys Infected: 1
tommehr
OS : XP
Post by Belahzur on Tue Nov 17, 2009 11:02 pm
Please re-open Malwarebytes, click the Update tab, and click Check for Updates. Then, click the Scanner tab, select Perform Quick Scan, and press Scan.
Post by tommehr on Wed Nov 18, 2009 10:11 am
Okay, will do. It refused to Update when I downloaded the program (came up with some kind of error message) so I assumed that it was already updated. Running an updated scan now.
The laptop seems to running fine now apart from one thing. When I startup the computer it seems to default to the Advanced Windows Options screen (i.e. with Safe Mode, Start Windows Normally, etc.). That in itself wouldn't be that much of a problem, but most of the time I am unable to use arrow or enter keys to select an option leaving me unable to do anything other than hold the power button and switch the laptop off. I have to keep starting and switching off until it either bypasses that AWO screen or gives me control of the arrow and enter keys and lets me select Windows.
Would this be related to the Malware? It only started when I tried to go into Safe Mode to try and deal with the malware before I came here. Any idea what's wrong with it or how I rectify the problem?
Thanks.
tommehr
OS : XP
Post by tommehr on Wed Nov 18, 2009 10:15 am
Objects scanned: 96701
Time elapsed: 9 minute(s), 26 second(s)
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{b6d223f6-c185-49a2-ba7e-a03e84744702} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
tommehr
OS : XP
Post by Belahzur on Wed Nov 18, 2009 6:20 pm
Post by tommehr on Wed Nov 18, 2009 8:09 pm
Run by Tom Rowberry at 20:07:17.32 on 18/11/2009
Internet Explorer: 7.0.5730.13 BrowserJavaVersion: 1.6.0_07
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.1015.377 [GMT 0:00]
AV: Avira AntiVir PersonalEdition *On-access scanning enabled* (Updated) {AD166499-45F9-482A-A743-FDD3350758C7}
AV: avast! antivirus 4.8.1356 [VPS 091118-0] *On-access scanning enabled* (Updated) {7591DB91-41F0-48A3-B128-1A293FD8233D}
FW: Outpost Firewall *enabled* {8A20CA2A-9E02-4A64-923B-0A38208EB7FD}
svchost.exe
svchost.exe
svchost.exe
svchost.exe
C:\Documents and Settings\Tom Rowberry\Desktop\dds.scr
uInternet Connection Wizard,ShellNext = [You must be registered and logged in to see this link.]
BHO: Skype add-on (mastermind): {22bf413b-c6d2-4d91-82a9-a0f997ba588c} - c:\program files\skype\toolbars\internet explorer\SkypeIEPlugin.dll
BHO: SSVHelper Class: {761497bb-d6f0-462c-b6eb-d4daf1d92d43} - c:\program files\java\jre1.6.0_07\bin\ssv.dll
uRun: [TouchFreeze] c:\program files\touchfreeze\TouchFreeze.exe
uRun: [msnmsgr] "c:\program files\windows live\messenger\msnmsgr.exe" /background
uRun: [PC Suite Tray] "c:\program files\nokia\nokia pc suite 7\PCSuite.exe" -onlytray
uRun: [SpybotSD TeaTimer] c:\program files\spybot - search & destroy\TeaTimer.exe
mRun: [AsusTray] c:\program files\eeepc\acpi\AsTray.exe
mRun: [AsusACPIServer] c:\program files\eeepc\acpi\AsAcpiSvr.exe
mRun: [AsusEPCMonitor] c:\program files\eeepc\acpi\AsEPCMon.exe
mRun: [ETDWare] c:\program files\elantech\ETDCtrl.exe
mRun: [IgfxTray] c:\windows\system32\igfxtray.exe
mRun: [HotKeysCmds] c:\windows\system32\hkcmd.exe
mRun: [Persistence] c:\windows\system32\igfxpers.exe
mRun: [RTHDCPL] RTHDCPL.EXE
mRun: [SoundMan] SOUNDMAN.EXE
mRun: [AlcWzrd] ALCWZRD.EXE
mRun: [Alcmtr] ALCMTR.EXE
mRun: [avast!] c:\progra~1\alwils~1\avast4\ashDisp.exe
mRun: [OutpostFeedBack] "c:\program files\agnitum\outpost firewall\feedback.exe" /dump:os_startup
StartupFolder: c:\documents and settings\tom rowberry\start menu\programs\startup\AutoHotkey.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\superh~1.lnk - c:\program files\asus\eeepc\super hybrid engine\SuperHybridEngine.exe
IE: Send to &Bluetooth Device... - c:\program files\widcomm\bluetooth software\btsendto_ie_ctx.htm
IE: Send To Bluetooth - c:\program files\widcomm\bluetooth software\btsendto_ie.htm
IE: {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\program files\widcomm\bluetooth software\btsendto_ie.htm
IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {CAFEEFAC-0016-0000-0004-ABCDEFFEDCBC} - c:\program files\java\jre1.6.0_07\bin\ssv.dll
IE: {77BF5300-1474-4EC7-9980-D32B190E9B07} - {77BF5300-1474-4EC7-9980-D32B190E9B07} - c:\program files\skype\toolbars\internet explorer\SkypeIEPlugin.dll
DPF: {A90A5822-F108-45AD-8482-9BC8B12DD539} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0004-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\progra~1\common~1\skype\SKYPE4~1.DLL
Notify: igfxcui - igfxdev.dll
AppInit_DLLs: c:\progra~1\agnitum\outpos~1\wl_hook.dll
FF - ProfilePath - c:\docume~1\tomrow~1\applic~1\mozilla\firefox\profiles\9rr0tpq7.default\
FF - prefs.js: browser.search.selectedEngine - Wikipedia (en)
FF - plugin: c:\program files\mozilla firefox\plugins\npicaN.dll
FF - hȋdden: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\microsoft.net\framework\v3.5\windows presentation foundation\dotnetassistantextension\
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
---- FIREFOX POLICIES ----
c:\program files\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl3.rsa_seed_sha", true);
R1 aswSP;avast! Self Protection;c:\windows\system32\drivers\aswSP.sys [2009-11-17 114768]
R1 SandBox;SandBox;c:\windows\system32\drivers\SandBox.sys [2009-11-17 704384]
R2 acssrv;Agnitum Client Security Service;c:\progra~1\agnitum\outpos~1\acs.exe [2009-11-17 1195008]
R2 aswFsBlk;aswFsBlk;c:\windows\system32\drivers\aswFsBlk.sys [2009-11-17 20560]
R3 afw;Agnitum firewall driver;c:\windows\system32\drivers\afw.sys [2009-11-17 31128]
R3 afwcore;afwcore;c:\windows\system32\drivers\afwcore.sys [2009-11-17 257432]
R3 AsusACPI;ASUS ACPI Driver;c:\windows\system32\drivers\ASUSACPI.SYS [2008-6-27 11264]
R3 Ktp;Elantech Smart-Pad;c:\windows\system32\drivers\ETD.sys [2008-5-21 25088]
R3 L1e;Miniport Driver for Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller;c:\windows\system32\drivers\l1e51x86.sys [2008-6-27 36864]
R3 RT80x86;Ralink 802.11n Wireless Driver;c:\windows\system32\drivers\rt2860.sys [2008-6-27 625024]
2009-11-17 22:32:56 118784 ----a-w- c:\windows\system32\MSSTDFMT.DLL
2009-11-17 22:32:56 1071088 ----a-w- c:\windows\system32\MSCOMCTL.OCX
2009-11-17 22:32:54 0 d-----w- c:\program files\SpywareBlaster
2009-11-17 22:22:26 704384 ----a-w- c:\windows\system32\drivers\SandBox.sys
2009-11-17 22:22:09 257432 ----a-w- c:\windows\system32\drivers\afwcore.sys
2009-11-17 22:20:42 49 ----a-w- c:\windows\transp.gif
2009-11-17 22:20:41 31128 ----a-w- c:\windows\system32\drivers\afw.sys
2009-11-17 22:20:32 0 d-----w- c:\program files\Agnitum
2009-11-17 22:20:13 0 d-----w- c:\docume~1\alluse~1\applic~1\Agnitum
2009-11-17 22:02:47 0 d-----w- c:\docume~1\tomrow~1\applic~1\Malwarebytes
2009-11-17 22:02:41 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-11-17 22:02:39 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-11-17 22:02:39 0 d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-11-17 22:02:38 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-17 19:49:33 0 d-----w- C:\_OTM
2009-11-17 19:43:09 0 d-----w- c:\program files\Spybot - Search & Destroy
2009-11-17 19:43:09 0 d-----w- c:\docume~1\alluse~1\applic~1\Spybot - Search & Destroy
2009-11-16 23:15:07 0 d-----w- c:\windows\system32\XPSViewer
2009-11-16 23:14:22 89088 -c----w- c:\windows\system32\dllcache\filterpipelineprintproc.dll
2009-11-16 23:14:22 117760 ------w- c:\windows\system32\prntvpt.dll
2009-11-16 23:14:21 597504 -c----w- c:\windows\system32\dllcache\printfilterpipelinesvc.exe
2009-11-16 23:14:21 575488 -c----w- c:\windows\system32\dllcache\xpsshhdr.dll
2009-11-16 23:14:21 575488 ------w- c:\windows\system32\xpsshhdr.dll
2009-11-16 23:14:21 1676288 -c----w- c:\windows\system32\dllcache\xpssvcs.dll
2009-11-16 23:14:21 1676288 ------w- c:\windows\system32\xpssvcs.dll
2009-11-15 10:08:57 0 d-----w- c:\windows\Performance
2009-11-15 10:08:25 0 d-----w- c:\program files\Microsoft Windows 7 Upgrade Advisor
2009-09-11 14:18:39 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-04 21:03:36 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-08-29 07:36:27 832512 ----a-w- c:\windows\system32\wininet.dll
2009-08-29 07:36:24 78336 ----a-w- c:\windows\system32\ieencode.dll
2009-08-29 07:36:24 17408 ----a-w- c:\windows\system32\corpol.dll
2009-08-26 08:00:21 247326 ----a-w- c:\windows\system32\strmdll.dll
2008-05-07 23:34:00 15523560 ----a-w- c:\program files\U1 Setup.exe
============= FINISH: 20:09:00.20 ===============
tommehr
OS : XP
Post by tommehr on Wed Nov 18, 2009 8:10 pm
Install Date: 04/10/2008 06:57:16
System Uptime: 18/11/2009 17:11:36 (3 hours ago)
Motherboard: ASUSTeK Computer INC. | | 1000H
Processor: Intel(R) Atom(TM) CPU N270 @ 1.60GHz | PBGA 437 | 1710/133mhz
C: is fȋxed (NTFS) - 40 GiB total, 27.475 GiB free.
D: is fȋxed (NTFS) - 34 GiB total, 33.262 GiB free.
Class GUID: {4D36E972-E325-11CE-BFC1-08002BE10318}
Description: Cisco Systems VPN Adapter
Device ID: ROOT\NET\0000
Manufacturer: Cisco Systems
Name: Cisco Systems VPN Adapter
PNP Device ID: ROOT\NET\0000
Service: CVirtA
RP48: 26/08/2009 11:35:55 - Software Distribution Service 3.0
RP49: 29/08/2009 09:41:50 - System Checkpoint
RP50: 03/09/2009 19:29:25 - Software Distribution Service 3.0
RP51: 10/09/2009 09:18:47 - Software Distribution Service 3.0
RP52: 17/09/2009 19:45:08 - System Checkpoint
RP53: 20/09/2009 19:36:03 - System Checkpoint
RP54: 21/09/2009 20:21:21 - System Checkpoint
RP55: 29/09/2009 17:12:16 - System Checkpoint
RP56: 03/10/2009 20:16:49 - System Checkpoint
RP57: 05/10/2009 08:43:38 - Software Distribution Service 3.0
RP58: 08/10/2009 18:25:41 - System Checkpoint
RP59: 10/10/2009 16:52:52 - System Checkpoint
RP60: 14/10/2009 09:31:54 - Software Distribution Service 3.0
RP61: 21/10/2009 12:52:37 - System Checkpoint
RP62: 24/10/2009 19:21:36 - System Checkpoint
RP63: 26/10/2009 10:09:52 - System Checkpoint
RP64: 29/10/2009 12:55:26 - System Checkpoint
RP65: 02/11/2009 00:16:43 - System Checkpoint
RP66: 03/11/2009 17:12:08 - System Checkpoint
RP67: 04/11/2009 10:17:55 - Software Distribution Service 3.0
RP68: 05/11/2009 22:08:18 - System Checkpoint
RP69: 06/11/2009 22:42:02 - System Checkpoint
RP70: 09/11/2009 13:27:18 - System Checkpoint
RP71: 11/11/2009 13:02:16 - System Checkpoint
RP72: 11/11/2009 14:17:50 - Software Distribution Service 3.0
RP73: 12/11/2009 15:15:25 - System Checkpoint
RP74: 14/11/2009 11:13:19 - System Checkpoint
RP75: 15/11/2009 10:08:25 - Installed Windows 7 Upgrade Advisor
RP76: 16/11/2009 17:05:00 - System Checkpoint
RP77: 16/11/2009 23:10:02 - Software Distribution Service 3.0
RP78: 17/11/2009 18:47:16 - Avira AntiVir Personal - 17/11/2009 18:47
RP79: 17/11/2009 18:59:04 - Software Distribution Service 3.0
RP80: 17/11/2009 22:20:38 - Agnitum Outpost Firewall Restore Point: install
µTorrent
Adabas D 13.01.00
Adobe Acrobat and Reader 8.1.2 Security Update 1 (KB403742)
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Reader 8.1.2
Adobe Reader 8.1.2 Security Update 1 (KB403742)
Adobe Shockwave Player 11.5
Asus ACPI Driver
ASUSUpdate for Eee PC
Atheros Communications Inc.(R) AR8121/AR8113/AR8114 Gigabit/Fast Ethernet Driver
AutoHotkey 1.0.47.06
avast! Antivirus
Azurewave Wireless LAN
Cisco Systems VPN Client 5.0.00.0340
Citrix Presentation Server Client
Eee Instant Key
ETDWare PS/2-x86 7.0.2.5 WHQL
HijackThis 2.0.2
InterVideo Register Manager
InterVideo WinDVD
IrfanView (remove only)
Java(TM) 6 Update 3
Java(TM) 6 Update 4
Java(TM) 6 Update 7
Microsoft .NET Framework 1.1
Microsoft Choice Guard
Microsoft Office PowerPoint Viewer 2007 (English)
Microsoft SQL Server 2005 Compact Edition [ENU]
Microsoft Visual C++ 2008 ATL Update kb973924 - x86 9.0.30729.4148
Mozilla Firefox (3.5.5)
Mozilla Thunderbird (2.0.0.22)
MSVC80_x86
MSVCRT
Nokia Connectivity Cable Driver
Nokia PC Suite
OpenOffice.org 2.4
Outpost Firewall 2009
Security Update for Windows XP (KB923789)
Segoe UI
Skype™ 3.6
Spotify
SpywareBlaster 4.2
Stream Torrent 1.0
Super Hybrid Engine
TouchFreeze
Transcribe! 7.51
Update for Windows Internet Explorer 7 (KB976749)
Update for Windows XP (KB961503)
WebFldrs XP
WIDCOMM Bluetooth Software
Windows Driver Package - Nokia Modem (10/27/2008 3.9)
Windows Driver Package - Nokia Modem (10/27/2008 7.01.0.1)
Windows Driver Package - Nokia pccsmcfd (08/22/2008 7.0.0.0)
Windows Live Call
Windows Live Essentials
Windows Live Mail
Windows Live Messenger
Windows Live Upload Tool
WinRAR archiver
WinZip 12.0
12/11/2009 20:17:20, error: Service Control Manager [7023] - The Uninterruptible Power Supply service terminated with the following error: %%2481
12/11/2009 20:17:19, error: UPS [2481] - The UPS service is not configured correctly.
tommehr
OS : XP
Post by Belahzur on Thu Nov 19, 2009 1:58 am
    µTorrent
    Java(TM) 6 Update 3
    Java(TM) 6 Update 4
    Java(TM) 6 Update 7
How is the machine now?
Post by tommehr on Thu Nov 19, 2009 10:47 am
It's running much better now. Thanks so much!
tommehr
OS : XP
