Problem with Antivirus System Pro
Post by skooter68 on Tue 17 Nov - 0:02
My laptop has been infected with this Antivirus System Pro software that everyone has been talking about. I followed one of the posts on this site to download and run the Malwarebytes' Anti-Malware software. It identifies items for removal, which I do. I then issue a shutdown/restart but when the machine comes up, the Antivirus System Pro automatically restarts again and all of the annoying virus alerts start popping up again. I even tried to do a system restore but I get an error message about contacting the domain administrator. HELP!!!!
skooter68
Posts Posts : 3
Joined Joined : 2009-11-16
OS OS : Vista
Points Points : 25765
Re: Problem with Antivirus System Pro
Post by Belahzur on Tue 17 Nov - 5:26
Joined Joined : 2008-08-04
Points Points : 245059
Post by skooter68 on Tue 17 Nov - 13:48
Belahzur,
Thanks for the info but when I click on the link to run the HijackThis installer a popup appears which says "Application cannot be executed. The file werfault.exe is infected. Do you want to activate your antivirus software now?".
I am assuming that this message is caused by the Antivirus System Pro malware. If I click on 'No', the screen disappears and my web page closes. Help!!!
skooter68
Posts Posts : 3
OS OS : Vista
Post by skooter68 on Wed 18 Nov - 0:23
I also tried doing a Malware Full Scan but still cannot download the HijackThis executeable. This anitvirus System Pro shuts down my internet explorer during the download process. Very frustrating
skooter68
Posts Posts : 3
OS OS : Vista
Post by Belahzur on Wed 18 Nov - 2:20
Try this.
Post by Julie0104 on Wed 25 Nov - 8:14
I AM HAVING THE SAME PROBLEM CAN YOU PLEASE HELP ME!!!
Julie0104
Joined Joined : 2009-11-25
OS OS : windows XP
Points Points : 25698
