Linksys wireless will not connect
Post by carolinagirl2001 on 15th November 2009, 10:38 pm
Previously I had the Alpha Antivirus (spyware) on my machine. I had to run system recovery to get rid of it and now everything is in working order except my wireless connection. I have a linksys wireless router (model WRT54GV) I cannot wirelessly connect. I have tried the troubleshooting on their website but this is not fixing the problem. Help! Thank you!
carolinagirl2001
Posts Posts : 5
Joined Joined : 2009-11-14
OS OS : Vista
Points Points : 25829
Re: Linksys wireless will not connect
Post by Doctor Inferno on 16th November 2009, 4:42 am
Open CMD, Reset WINSOCK entries to installation defaults by typing: netsh winsock reset catalog
Restart your PC.
If it doesn't work, download Winsock XP Fix from here, save it to your Desktop.
See if you can connect now.
Points Points : 104630
