antivirus system pro again
Post by KevLee on Thu Nov 12, 2009 8:06 pm
malware infection I need help. I can not save the log from hijack this to anywhere
KevLee
Posts Posts : 48
Joined Joined : 2009-08-06
Protection Protection : avast
Points Points : 27169
Re: antivirus system pro again
Post by Belahzur on Thu Nov 12, 2009 8:27 pm
Does Hijack This work though? when saving the log, it should save to wherever Hijack This is located.
Points Points : 245059
Post by KevLee on Fri Nov 13, 2009 12:17 am
hijackthis runs but will not save... says notepad is in fected. I have the info on the page to correct things
KevLee
Posts Posts : 48
Post by Belahzur on Fri Nov 13, 2009 12:31 am
Post by KevLee on Fri Nov 13, 2009 1:06 am
link 1 no go. link 2 worked and saved, but con not open says notepad is infected. will copy & paste here; exeHelper by Raktor
Build 20091021
exeHelper by Raktor
Build 20091021
exeHelper by Raktor
Build 20091021
Run at 20:02:37 on 11/12/09
Now searching...
Checking for bad processes...
Checking for bad files...
Resetting policies...
--Finished--
KevLee
Posts Posts : 48
Post by Belahzur on Fri Nov 13, 2009 1:35 am
Does Hijack This work now?
Post by KevLee on Fri Nov 13, 2009 2:22 am
still will not save to notebook, stays on the analyze this, (upload), screen.
KevLee
Posts Posts : 48
Post by KevLee on Fri Nov 13, 2009 2:24 am
will try again tomorrow, to late for now... up at 4:00 AM. Thanks
KevLee
Posts Posts : 48
Post by KevLee on Fri Nov 13, 2009 2:37 am
I may have it Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 9:15:59 PM, on 11/12/2009
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\CTsvcCDA.EXE
C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe
C:\Documents and Settings\Owner\Local Settings\Application Data\olulmv\qvupsysguard.exe
C:\Program Files\Creative\Shared Files\Media Sniffer\MtdAcq.exe
C:\Program Files\Windows Live\Mail\wlmail.exe
C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkCalRem.exe
C:\Program Files\Windows Live\Contacts\wlcomm.exe
C:\WINDOWS\system32\notepad.exe
C:\Documents and Settings\Owner\My Documents\winlogon2.scr
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.227 antiviraprof-2009.microsoft.com
O1 - Hosts: 91.212.127.227 antiviraprof2009.com
O1 - Hosts: 91.212.127.227 [You must be registered and logged in to see this link.]
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
O2 - BHO: Canon Easy Web Print Helper - {68F9551E-0411-48E4-9AAF-4BC42A6A46BE} - C:\Program Files\Canon\Easy-WebPrint\EWPBrowseLoader.dll
O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll
O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
O3 - Toolbar: Easy-WebPrint - {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - C:\Program Files\Canon\Easy-WebPrint\Toolband.dll
O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [BlackBerryAutoUpdate] C:\Program Files\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe /background
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [RoxWatchTray] "C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe"
O4 - HKLM\..\Run: [wtwkjtac] C:\Documents and Settings\Owner\Local Settings\Application Data\itcxue\qbnysysguard.exe
O4 - HKLM\..\Run: [rugdukxa] C:\Documents and Settings\Owner\Local Settings\Application Data\olulmv\qvupsysguard.exe
O4 - HKCU\..\Run: [updateMgr] C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe AcRdB7_0_9
O4 - HKCU\..\Run: [MtdAcq] C:\Program Files\Creative\Shared Files\Media Sniffer\MtdAcq.exe /s
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [wtwkjtac] C:\Documents and Settings\Owner\Local Settings\Application Data\itcxue\qbnysysguard.exe
O4 - HKCU\..\Run: [rugdukxa] C:\Documents and Settings\Owner\Local Settings\Application Data\olulmv\qvupsysguard.exe
O4 - Startup: wkcalrem.LNK = C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkCalRem.exe
O4 - Global Startup: Desktop Manager.lnk = C:\Program Files\Research In Motion\BlackBerry\DesktopMgr.exe
O4 - Global Startup: Install Pending Files.LNK = C:\Program Files\SIFXINST\SIFXINST.EXE
O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: (no name) - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra 'Tools' menuitem: Skype add-on for Internet Explorer - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: (no name) - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - (no file)
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - [You must be registered and logged in to see this link.]
O16 - DPF: {6F750203-1362-4815-A476-88533DE61D0C} (Kodak Gallery Easy Upload Manager Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} (Facebook Photo Uploader 5 Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {E5F5D008-DD2C-4D32-977D-1A0ADF03058B} (JuniperSetupSP1 Control) - [You must be registered and logged in to see this link.]
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\system32\CTsvcCDA.EXE
O23 - Service: Google Update Service (gupdate1c98949c8fa2c4a) (gupdate1c98949c8fa2c4a) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: PrismXL - New Boundary Technologies, Inc. - C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
O23 - Service: Roxio UPnP Renderer 9 - Sonic Solutions - C:\Program Files\Roxio\Digital Home 9\RoxioUPnPRenderer9.exe
O23 - Service: Roxio Upnp Server 9 - Sonic Solutions - C:\Program Files\Roxio\Digital Home 9\RoxioUpnpService9.exe
O23 - Service: LiveShare P2P Server 9 (RoxLiveShare9) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxLiveShare9.exe
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: Roxio Hard Drive Watcher 9 (RoxWatch9) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe
O23 - Service: SupportSoft RemoteAssist - SupportSoft, Inc. - C:\Program Files\Common Files\supportsoft\bin\ssrc.exe
O24 - Desktop Component 0: (no name) - [You must be registered and logged in to see this link.]
End of file - 12024 bytes
KevLee
Posts Posts : 48
Post by Belahzur on Fri Nov 13, 2009 5:25 pm
Post by KevLee on Fri Nov 13, 2009 7:27 pm
All done. Here is the MBAM log;
Database version: 3162
11/13/2009 2:18:44 PM
mbam-log-2009-11-13 (14-18-44).txt
Objects scanned: 101370
Time elapsed: 6 minute(s), 27 second(s)
Registry Keys Infected: 2
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\msqpdxserv.sys (Trojan.Agent) -> Quarantined and deleted successfully.
KevLee
Posts Posts : 48
Post by Belahzur on Fri Nov 13, 2009 10:48 pm
Post by KevLee on Sat Nov 14, 2009 12:18 am
Run by Owner at 19:13:16.21 on Fri 11/13/2009
Internet Explorer: 8.0.6001.18702
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.502.180 [GMT -5:00]
AV: avast! antivirus 4.8.1351 [VPS 091113-1] *On-access scanning enabled* (Updated) {7591DB91-41F0-48A3-B128-1A293FD8233D}
svchost.exe
C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
svchost.exe
svchost.exe
svchost.exe
C:\Documents and Settings\Owner\Local Settings\Temporary Internet Files\Content.IE5\82XPOD5J\dds[1].scr
BHO: Skype add-on (mastermind): {22bf413b-c6d2-4d91-82a9-a0f997ba588c} - c:\program files\skype\toolbars\internet explorer\SkypeIEPlugin.dll
BHO: RealPlayer Download and Record Plugin for Internet Explorer: {3049c3e9-b461-4bc5-8870-4c09146192ca} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
BHO: EWPBrowseObject Class: {68f9551e-0411-48e4-9aaf-4bc42a6a46be} - c:\program files\canon\easy-webprint\EWPBrowseLoader.dll
BHO: Search Helper: {6ebf7485-159f-4bff-a14f-b9e3aac4465b} - c:\program files\microsoft\search enhancement pack\search helper\SEPsearchhelperie.dll
BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.4.4525.1752\swg.dll
BHO: Google Dictionary Compression sdch: {c84d72fe-e17d-4195-bb24-76c02e2e7c4e} - c:\program files\google\google toolbar\component\fastsearch_B7C5AC242193BB3E.dll
BHO: Windows Live Toolbar Helper: {e15a8dc0-8516-42a1-81ea-dc94ec1acf10} - c:\program files\windows live\toolbar\wltcore.dll
TB: Easy-WebPrint: {327c2873-e90d-4c37-aa9d-10ac9baba46c} - c:\program files\canon\easy-webprint\Toolband.dll
TB: &Windows Live Toolbar: {21fa44ef-376d-4d53-9b0f-8a89d3229068} - c:\program files\windows live\toolbar\wltcore.dll
TB: Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
uRun: [updateMgr] c:\program files\adobe\acrobat 7.0\reader\AdobeUpdateManager.exe AcRdB7_0_9
uRun: [MtdAcq] c:\program files\creative\shared files\media sniffer\MtdAcq.exe /s
uRun: [msnmsgr] "c:\program files\windows live\messenger\msnmsgr.exe" /background
uRun: [swg] "c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe"
mRun: [avast!] c:\progra~1\alwils~1\avast4\ashDisp.exe
mRun: [BlackBerryAutoUpdate] c:\program files\common files\research in motion\auto update\RIMAutoUpdate.exe /background
mRun: []
mRun: [RoxWatchTray] "c:\program files\common files\roxio shared\9.0\sharedcom\RoxWatchTray9.exe"
StartupFolder: c:\docume~1\owner\startm~1\programs\startup\wkcalrem.lnk - c:\program files\common files\microsoft shared\works shared\WkCalRem.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\deskto~1.lnk - c:\program files\research in motion\blackberry\DesktopMgr.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\instal~1.lnk - c:\program files\sifxinst\SIFXINST.EXE
IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office11\EXCEL.EXE/3000
IE: {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - {5F7B1267-94A9-47F5-98DB-E99415F33AEC} - c:\program files\windows live\writer\WriterBrowserExtension.dll
IE: {5067A26B-1337-4436-8AFE-EE169C2DA79F} - {77BF5300-1474-4EC7-9980-D32B190E9B07} - c:\program files\skype\toolbars\internet explorer\SkypeIEPlugin.dll
IE: {77BF5300-1474-4EC7-9980-D32B190E9B07} - {77BF5300-1474-4EC7-9980-D32B190E9B07} - c:\program files\skype\toolbars\internet explorer\SkypeIEPlugin.dll
Trusted Zone: aol.com\free
DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} - [You must be registered and logged in to see this link.]
DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} - [You must be registered and logged in to see this link.]
DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - [You must be registered and logged in to see this link.]
DPF: {6F750203-1362-4815-A476-88533DE61D0C} - [You must be registered and logged in to see this link.]
DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} - [You must be registered and logged in to see this link.]
DPF: {E5F5D008-DD2C-4D32-977D-1A0ADF03058B} - [You must be registered and logged in to see this link.]
Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\progra~1\common~1\skype\SKYPE4~1.DLL
Notify: igfxcui - igfxdev.dll
R0 pavboot;pavboot;c:\windows\system32\drivers\pavboot.sys [2008-12-26 28544]
R1 aswSP;avast! Self Protection;c:\windows\system32\drivers\aswSP.sys [2009-2-9 114768]
R2 aswFsBlk;aswFsBlk;c:\windows\system32\drivers\aswFsBlk.sys [2009-2-9 20560]
R2 SeaPort;SeaPort;c:\program files\microsoft\search enhancement pack\seaport\SeaPort.exe [2009-5-19 240512]
R3 DCamUSBLTN;M318B Digital Video Camera;c:\windows\system32\drivers\vq318vid.sys [2002-4-22 113632]
S2 gupdate1c98949c8fa2c4a;Google Update Service (gupdate1c98949c8fa2c4a);c:\program files\google\update\GoogleUpdate.exe [2009-2-7 133104]
S3 el575nd5;3Com Megahertz 10/100 LAN CardBus PC Card Driver;c:\windows\system32\drivers\el575ND5.sys [2006-6-30 69692]
S3 getPlus(R) Helper;getPlus(R) Helper;c:\program files\nos\bin\getPlus_HelperSvc.exe [2009-5-24 33176]
S3 RkPavproc1;RkPavproc1;\??\c:\windows\system32\drivers\rkpavproc1.sys --> c:\windows\system32\drivers\RkPavproc1.sys [?]
2009-11-13 19:10:23 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-11-13 19:10:20 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-11-13 19:10:20 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-08 00:08:47 0 d-----w- c:\program files\common files\Sonic Shared
2009-11-07 23:48:20 0 d-----w- c:\docume~1\alluse~1\applic~1\Research In Motion
2009-10-30 00:29:08 2146304 ----a-w- c:\windows\system32\GPhotos.scr
2009-10-28 23:35:48 9856 ------w- c:\windows\system32\drivers\pfc.sys
2009-10-28 23:35:12 212480 ----a-w- c:\windows\pcdlib32.dll
2009-10-28 23:23:58 91136 -c--a-w- c:\windows\system32\dllcache\kswdmcap.ax
2009-10-28 23:23:58 91136 ----a-w- c:\windows\system32\kswdmcap.ax
2009-10-28 23:23:58 61952 -c--a-w- c:\windows\system32\dllcache\kstvtune.ax
2009-10-28 23:23:58 61952 ----a-w- c:\windows\system32\kstvtune.ax
2009-10-28 23:23:58 43008 -c--a-w- c:\windows\system32\dllcache\ksxbar.ax
2009-10-28 23:23:58 43008 ----a-w- c:\windows\system32\ksxbar.ax
2009-10-25 21:06:18 63 ----a-w- c:\documents and settings\owner\jagex_runescape_preferences2.dat
2009-11-03 22:07:59 5036 ----a-w- c:\docume~1\owner\applic~1\wklnhst.dat
2009-10-26 20:50:04 38 ----a-w- c:\documents and settings\owner\jagex_runescape_preferences.dat
2009-10-11 09:17:27 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-09-11 14:18:39 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-04 21:03:36 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-08-29 08:08:21 916480 ----a-w- c:\windows\system32\wininet.dll
2009-08-28 23:42:52 2065696 ----a-w- c:\windows\system32\usbaaplrc.dll
2009-08-26 08:00:21 247326 ----a-w- c:\windows\system32\strmdll.dll
2009-08-23 21:00:38 922112 ------w- c:\windows\system32\imapi2fs.dll
2009-08-23 21:00:38 426496 ------w- c:\windows\system32\imapi2.dll
2008-08-23 00:26:38 32768 --sha-w- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012008082220080823\index.dat
============= FINISH: 19:14:19.92 ===============
KevLee
Posts Posts : 48
Post by KevLee on Sat Nov 14, 2009 12:19 am
Install Date: 3/25/2007 7:37:02 PM
System Uptime: 11/13/2009 2:20:54 PM (5 hours ago)
Motherboard: Intel Corporation | | D915GUX
Processor: Intel(R) Celeron(R) CPU 3.33GHz | | 3333/133mhz
C: is fȋxed (NTFS) - 89 GiB total, 59.433 GiB free.
D: is fȋxed (FAT32) - 4 GiB total, 2.574 GiB free.
E: is CDROM ()
RP847: 8/15/2009 11:20:45 PM - Software Distribution Service 3.0
RP848: 8/16/2009 6:50:57 AM - Software Distribution Service 3.0
RP849: 8/17/2009 3:00:20 AM - Software Distribution Service 3.0
RP850: 8/18/2009 3:00:18 AM - Software Distribution Service 3.0
RP851: 8/19/2009 3:00:20 AM - Software Distribution Service 3.0
RP852: 8/20/2009 3:00:23 AM - Software Distribution Service 3.0
RP853: 8/21/2009 3:00:22 AM - Software Distribution Service 3.0
RP854: 8/22/2009 3:00:21 AM - Software Distribution Service 3.0
RP855: 8/22/2009 7:25:15 PM - Installed Windows XP KB954708.
RP856: 8/22/2009 7:25:59 PM - Installed DirectX
RP857: 8/23/2009 3:00:20 AM - Software Distribution Service 3.0
RP858: 8/24/2009 3:00:22 AM - Software Distribution Service 3.0
RP859: 8/25/2009 3:00:25 AM - Software Distribution Service 3.0
RP860: 8/26/2009 3:00:21 AM - Software Distribution Service 3.0
RP861: 8/27/2009 3:00:21 AM - Software Distribution Service 3.0
RP862: 8/28/2009 3:00:22 AM - Software Distribution Service 3.0
RP863: 8/29/2009 3:00:23 AM - Software Distribution Service 3.0
RP864: 8/30/2009 3:00:22 AM - Software Distribution Service 3.0
RP865: 8/31/2009 3:00:24 AM - Software Distribution Service 3.0
RP866: 9/1/2009 3:00:21 AM - Software Distribution Service 3.0
RP867: 9/2/2009 3:00:21 AM - Software Distribution Service 3.0
RP868: 9/2/2009 8:32:51 AM - Software Distribution Service 3.0
RP869: 9/3/2009 3:00:24 AM - Software Distribution Service 3.0
RP870: 9/4/2009 3:00:23 AM - Software Distribution Service 3.0
RP871: 9/5/2009 3:00:24 AM - Software Distribution Service 3.0
RP872: 9/6/2009 3:00:22 AM - Software Distribution Service 3.0
RP873: 9/7/2009 3:00:22 AM - Software Distribution Service 3.0
RP874: 9/8/2009 3:00:24 AM - Software Distribution Service 3.0
RP875: 9/9/2009 3:00:22 AM - Software Distribution Service 3.0
RP876: 9/10/2009 3:00:26 AM - Software Distribution Service 3.0
RP877: 9/11/2009 3:00:22 AM - Software Distribution Service 3.0
RP878: 9/12/2009 3:00:22 AM - Software Distribution Service 3.0
RP879: 9/13/2009 3:00:21 AM - Software Distribution Service 3.0
RP880: 9/14/2009 3:00:23 AM - Software Distribution Service 3.0
RP881: 9/15/2009 3:00:22 AM - Software Distribution Service 3.0
RP882: 9/16/2009 3:00:22 AM - Software Distribution Service 3.0
RP883: 9/17/2009 3:00:22 AM - Software Distribution Service 3.0
RP884: 9/18/2009 3:00:23 AM - Software Distribution Service 3.0
RP885: 9/19/2009 3:00:23 AM - Software Distribution Service 3.0
RP886: 9/19/2009 9:51:54 AM - Software Distribution Service 3.0
RP887: 9/20/2009 3:00:22 AM - Software Distribution Service 3.0
RP888: 9/21/2009 3:00:22 AM - Software Distribution Service 3.0
RP889: 9/22/2009 3:00:22 AM - Software Distribution Service 3.0
RP890: 9/23/2009 3:00:22 AM - Software Distribution Service 3.0
RP891: 9/24/2009 3:00:23 AM - Software Distribution Service 3.0
RP892: 9/25/2009 3:00:23 AM - Software Distribution Service 3.0
RP893: 9/26/2009 3:00:23 AM - Software Distribution Service 3.0
RP894: 9/27/2009 3:00:22 AM - Software Distribution Service 3.0
RP895: 9/28/2009 3:00:23 AM - Software Distribution Service 3.0
RP896: 9/29/2009 3:00:24 AM - Software Distribution Service 3.0
RP897: 9/30/2009 3:00:24 AM - Software Distribution Service 3.0
RP898: 10/1/2009 3:00:24 AM - Software Distribution Service 3.0
RP899: 10/2/2009 3:00:22 AM - Software Distribution Service 3.0
RP900: 10/3/2009 3:00:24 AM - Software Distribution Service 3.0
RP901: 10/4/2009 3:00:24 AM - Software Distribution Service 3.0
RP902: 10/5/2009 3:00:21 AM - Software Distribution Service 3.0
RP903: 10/6/2009 3:00:20 AM - Software Distribution Service 3.0
RP904: 10/7/2009 3:00:21 AM - Software Distribution Service 3.0
RP905: 10/8/2009 3:00:23 AM - Software Distribution Service 3.0
RP906: 10/9/2009 3:00:20 AM - Software Distribution Service 3.0
RP907: 10/10/2009 3:00:22 AM - Software Distribution Service 3.0
RP908: 10/11/2009 3:00:20 AM - Software Distribution Service 3.0
RP909: 10/12/2009 3:00:22 AM - Software Distribution Service 3.0
RP910: 10/12/2009 4:28:08 PM - Software Distribution Service 3.0
RP911: 10/12/2009 4:48:01 PM - Software Distribution Service 3.0
RP912: 10/12/2009 4:52:41 PM - Software Distribution Service 3.0
RP913: 10/12/2009 4:55:27 PM - Software Distribution Service 3.0
RP914: 10/12/2009 5:02:55 PM - Software Distribution Service 3.0
RP915: 10/13/2009 3:00:20 AM - Software Distribution Service 3.0
RP916: 10/13/2009 1:45:44 PM - Software Distribution Service 3.0
RP917: 10/14/2009 3:38:37 PM - System Checkpoint
RP918: 10/15/2009 3:00:21 AM - Software Distribution Service 3.0
RP919: 10/16/2009 3:00:25 AM - Software Distribution Service 3.0
RP920: 10/16/2009 9:04:33 PM - Software Distribution Service 3.0
RP921: 10/17/2009 3:00:19 AM - Software Distribution Service 3.0
RP922: 10/18/2009 3:00:25 AM - Software Distribution Service 3.0
RP923: 10/19/2009 3:00:25 AM - Software Distribution Service 3.0
RP924: 10/19/2009 1:13:10 PM - Software Distribution Service 3.0
RP925: 10/20/2009 3:00:22 AM - Software Distribution Service 3.0
RP926: 10/21/2009 3:00:26 AM - Software Distribution Service 3.0
RP927: 10/22/2009 3:00:39 AM - Software Distribution Service 3.0
RP928: 10/23/2009 3:00:25 AM - Software Distribution Service 3.0
RP929: 10/23/2009 9:58:41 AM - Software Distribution Service 3.0
RP930: 10/23/2009 3:30:40 PM - Software Distribution Service 3.0
RP931: 10/24/2009 3:00:25 AM - Software Distribution Service 3.0
RP932: 10/25/2009 3:00:29 AM - Software Distribution Service 3.0
RP933: 10/25/2009 2:45:27 PM - Installed Windows XP -- Software Updates KB952011.
RP934: 10/26/2009 3:00:28 AM - Software Distribution Service 3.0
RP935: 10/27/2009 3:00:27 AM - Software Distribution Service 3.0
RP936: 10/27/2009 10:29:03 PM - Software Distribution Service 3.0
RP937: 10/28/2009 9:03:18 AM - Software Distribution Service 3.0
RP938: 10/28/2009 7:35:10 PM - Installed Camera Suite
RP939: 10/28/2009 7:47:18 PM - Software Distribution Service 3.0
RP940: 10/29/2009 3:00:21 AM - Software Distribution Service 3.0
RP941: 10/30/2009 3:00:23 AM - Software Distribution Service 3.0
RP942: 10/31/2009 3:00:24 AM - Software Distribution Service 3.0
RP943: 11/1/2009 3:00:26 AM - Software Distribution Service 3.0
RP944: 11/1/2009 4:00:18 AM - Software Distribution Service 3.0
RP945: 11/2/2009 4:00:25 AM - Software Distribution Service 3.0
RP946: 11/3/2009 4:00:28 AM - Software Distribution Service 3.0
RP947: 11/4/2009 4:00:28 AM - Software Distribution Service 3.0
RP948: 11/5/2009 4:00:25 AM - Software Distribution Service 3.0
RP949: 11/6/2009 4:00:26 AM - Software Distribution Service 3.0
RP950: 11/7/2009 4:00:23 AM - Software Distribution Service 3.0
RP951: 11/7/2009 7:59:42 PM - Software Distribution Service 3.0
RP952: 11/7/2009 8:08:23 PM - Installed Roxio Media Manager
RP953: 11/8/2009 3:00:20 AM - Software Distribution Service 3.0
RP954: 11/8/2009 4:30:55 PM - Installed Java(TM) 6 Update 17
RP955: 11/8/2009 4:34:17 PM - Software Distribution Service 3.0
RP956: 11/9/2009 3:00:21 AM - Software Distribution Service 3.0
RP957: 11/10/2009 3:00:24 AM - Software Distribution Service 3.0
RP958: 11/11/2009 3:00:23 AM - Software Distribution Service 3.0
RP959: 11/12/2009 3:00:25 AM - Software Distribution Service 3.0
RP960: 11/12/2009 3:14:53 PM - Software Distribution Service 3.0
RP961: 11/12/2009 6:35:01 PM - Software Distribution Service 3.0
RP962: 11/12/2009 9:43:57 PM - Software Distribution Service 3.0
RP963: 11/13/2009 1:50:00 PM - Software Distribution Service 3.0
Acrobat.com
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Reader 9.2
Adobe Shockwave Player 11
Apple Mobile Device Support
Apple Software Update
ArcSoft Camera Suite 2.1
avast! Antivirus
BlackBerry Desktop Software 5.0.1
Bonjour
Camera Support Core Library
Camera Window
Canon Camera Support Core Library
Canon Camera Window for ZoomBrowser EX
Canon iP1700
Canon iP1700 User Registration
Canon MovieEdit Task for ZoomBrowser EX
Canon My Printer
Canon PhotoRecord
Canon RAW Image Task for ZoomBrowser EX
Canon RemoteCapture Task for ZoomBrowser EX
Canon Utilities Easy-PhotoPrint
Canon Utilities PhotoStitch 3.1
Canon Utilities ZoomBrowser EX
Coupon Printer for Windows
Creative MediaSource
Creative Memories Memory Manager 2
Creative MuVo NX-TX
Creative System Information
Drivein Screen Saver
DVD Solution
Easy-WebPrint
getPlus(R) for Adobe
Google Earth
Google Earth Plug-in
Google Update Helper
Google Updater
GoToMeeting 4.0.0.320
High Definition Audio Driver Package - KB888111
HijackThis 2.0.2
Hotfix for Windows XP (KB954708)
iTunes
Juniper Networks Cache Cleaner 6.0.0
Junk Mail filter update
KODAK EASYSHARE Gallery Upload ActiveX Control
Loki ActiveX Control
Marvell Miniport Driver
Memory Manager Shared Components Update
Messenger Plus! Live
Microsoft .NET Framework 1.1
Microsoft Choice Guard
Microsoft Digital Image Library 9 - Blocker
Microsoft Digital Image Starter Edition 2006
Microsoft Digital Image Starter Edition 2006 Editor
Microsoft Digital Image Starter Edition 2006 Library
Microsoft Money 2006
Microsoft Search Enhancement Pack
Microsoft Silverlight
Microsoft SQL Server 2005 Compact Edition [ENU]
Microsoft Sync Framework Runtime Native v1.0 (x86)
Microsoft Sync Framework Services Native v1.0 (x86)
Microsoft Works
MovieEdit Task
MS Access 97 SP2
MSVCRT
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MuVo Driver
PhotoStitch
Picasa 3
Power2Go 4.0
PowerDVD
Private Islands Inc
QuickTime
RAW Image Task 1.1
RealPlayer
Recovery Software Suite eMachines
RemoteCapture Task 1.0.3
Rhapsody Player Engine
Roxio Media Manager
Security Update for Windows Internet Explorer 8 (KB971961)
Security Update for Windows Internet Explorer 8 (KB972260)
Security Update for Windows Internet Explorer 8 (KB974455)
Security Update for Windows XP (KB913433)
Segoe UI
SimCity 3000 Unlimited
SimCity 4 Deluxe
Skype web features
Skype 4.1
Soft Data Fax Modem with SmartCP
Spelling Dictionaries Support For Adobe Reader 9
The Sims
TWC Customer Controls
Update for Windows Internet Explorer 8 (KB972636)
Update for Windows Internet Explorer 8 (KB976749)
Update for Windows XP (KB961503)
V CAST Music with Rhapsody
WebFldrs XP
Windows Backup Utility
Windows Feature Pack for Storage (32-bit) - IMAPI update for Blu-Ray
Windows Imaging Component
Windows Live Call
Windows Live Essentials
Windows Live Mail
Windows Live Messenger
Windows Live Photo Gallery
Windows Live Sync
Windows Live Upload Tool
Windows Live Writer
Windows XP Service Pack 3
WinRAR archiver
11/8/2009 6:51:51 PM, error: System Error [1003] - Error code 1000000a, parameter1 00000004, parameter2 00000002, parameter3 00000001, parameter4 804fff0a.
11/8/2009 6:32:42 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the Roxio Hard Drive Watcher 9 service to connect.
11/8/2009 6:32:42 PM, error: Service Control Manager [7000] - The MCSTRM service failed to start due to the following error: The system cannot find the file specified.
11/8/2009 3:01:27 AM, error: SideBySide [36] - The assembly x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a has missing or invalid files; recovery of this assembly failed.
11/7/2009 7:59:55 PM, error: Windows Update Agent [20] - Installation Failure: Windows failed to install the following update with error 0x80070643: Security Update for Microsoft XML Core Services 4.0 Service Pack 2 (KB954430).
11/12/2009 9:26:09 PM, error: Print [6161] - The document hijackthis - Notepad owned by Owner failed to print on printer Canon iP1700. Data type: NT EMF 1.008. Size of the spool file in bytes: 0. Number of bytes printed: 0. Total number of pages in the document: 1. Number of pages printed: 0. Client machine: \\HOME-CF443346E3. Win32 error code returned by the print processor: 259 (0x103).
KevLee
Posts Posts : 48
Post by KevLee on Sun Nov 15, 2009 7:18 pm
should I uninstall hijack this and the malware program, as well as the logs now? Or doesn't it matter ?
Thanks for all your help,
Kevin
KevLee
Posts Posts : 48
Post by Belahzur on Sun Nov 15, 2009 11:19 pm
Log looks good, how's the machine running?
You can delete everything we used. Smile
Post by KevLee on Mon Nov 16, 2009 12:30 am
everything is running great! thank you again.
Kevin
KevLee
Posts Posts : 48
