Problem with McAfee. Error starting on demand scanner.
Post by Aussie_Ash_131 on Thu Nov 12, 2009 6:48 am
Hi.
The other day i decided to run a scan while i was doing something else. I opened up McAfee security center, and went to the scan window and selected all possible drives.
After it began initialising the scan an error message came up, saying "Error: Starting on Demand Scanner".
So i went onto the McAfee tech support, and was given some instructions that didnt solve the problem. They told me to do a disk check and repair bad sectors, which after doing successfully didnt fix anything.
After uninstalling McAfee and using the mcpr.exe file, and reinstalling, no luck. And now McAfee is working intermintantly. Sometimes it says im not protected and cannot fix itself. Sometimes i am protected.
I think this is a virus but of course with the obvious problem, i cant find and get rid of it.
Any help, would be much appreciated. Also step by step instructions would be much appreciated.
Thanks in advance for your help, Ash.
Oh and also if any more information is needed, im happy to provide it.
Last edited by Aussie_Ash_131 on Thu Nov 12, 2009 6:53 am; edited 1 time in total (Reason for editing : forgot the last bit haha.)
Aussie_Ash_131
OS : 8
Re: Problem with McAfee. Error starting on demand scanner.
Post by Nazzgull on Thu Nov 12, 2009 10:29 am
please read [You must be registered and logged in to see this link.] post, and post your HijackThis log file in this topic.
Wait for instructions given only by [You must be registered and logged in to see this link.], [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
OS : Windows 7 Professional
Post by Aussie_Ash_131 on Sat Nov 14, 2009 12:04 pm
After updating everything on that list and downloading hijack this.
I run hijack this and click on scan and log file and it brings up the scan page (in the background of picture 2 in the forum) and it doesnt open a log file and there is also no log file in the path of where i saved hijack this (winlogon).
I am also unable to operate hijack this a second time, and unable to delete or edit it in any way because it says i do not have the appropriate permissions.
Whats the next step?
Aussie_Ash_131
OS : 8
Post by Belahzur on Sat Nov 14, 2009 8:54 pm
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
    cngaudit.dll
Post by Aussie_Ash_131 on Sat Nov 14, 2009 10:46 pm
ok, well i have done all that and it worked fine.
here are the results of the system look:
Searching for "scecli.dll"
C:\i386\scecli.dll --a--- 180224 bytes [10:57 16/08/2008] [21:00 03/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\$NtServicePackUninstall$\scecli.dll -----c 180224 bytes [09:29 23/08/2008] [21:00 03/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\ServicePackFiles\i386\scecli.dll ------ 181248 bytes [08:43 22/08/2008] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\scecli.dll --a--- 181248 bytes [04:51 10/08/2004] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
Searching for "netlogon.dll"
C:\i386\netlogon.dll --a--- 407040 bytes [10:54 16/08/2008] [21:00 03/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\$NtServicePackUninstall$\netlogon.dll -----c 407040 bytes [09:29 23/08/2008] [21:00 03/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\ServicePackFiles\i386\netlogon.dll ------ 407040 bytes [08:42 22/08/2008] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\netlogon.dll --a--- 407040 bytes [04:51 10/08/2004] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
Searching for "eventlog.dll"
C:\i386\eventlog.dll --a--- 55808 bytes [10:53 16/08/2008] [21:00 03/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\$NtServicePackUninstall$\eventlog.dll -----c 55808 bytes [09:30 23/08/2008] [21:00 03/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\ServicePackFiles\i386\eventlog.dll ------ 56320 bytes [08:42 22/08/2008] [00:11 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\system32\eventlog.dll --a--- 61952 bytes [04:51 10/08/2004] [00:11 14/04/2008] (Unable to calculate MD5)
Searching for "cngaudit.dll"
No files found.
-=End Of File=-
Aussie_Ash_131
OS : 8
Post by Belahzur on Sun Nov 15, 2009 2:08 am
Files to delete:
Post by Aussie_Ash_131 on Sun Nov 15, 2009 11:50 pm
Here are the results of the avenger:
Platform: Windows XP
Rootkit scan active.
No rootkits found!
File "C:\WINDOWS\system32\eventlog.dll" deleted successfully.
Completed script processing.
Finished! Terminate.
When my computer was starting up though, it came up with a notice that said "Windows cannot find cleanup.exe. To find files go to start and search". I am also now unable to connect to the internet on my computer!
I use a wireless adaptor on a desktop computer to connect and the wireless usb adaptor works fine, but i cant connect. When i go to the internet preferences, i set up the wireless network preferences and click ok, and then it doesnt connect, so i go have another look at the preferences and they aren't there anymore.
what do i do now?
Aussie_Ash_131
OS : 8
Post by Belahzur on Mon Nov 16, 2009 1:12 am
Post by Aussie_Ash_131 on Mon Nov 16, 2009 1:49 am
Here is the log file of the quick scan with mbam:
Database version: 2775
16/11/2009 12:40:43 PM
mbam-log-2009-11-16 (12-40-43).txt
Objects scanned: 110589
Time elapsed: 12 minute(s), 52 second(s)
Registry Keys Infected: 3
Registry Values Infected: 1
Files Infected: 5
HKEY_CURRENT_USER\SOFTWARE\NordBull (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\XML (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\poprock (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\poprock (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{7B02EF0B-A410-4938-8480-9BA26420A627}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{BB65B0FB-5712-401b-B616-E69AC55E2757}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\win32k.sys (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Ashbee\Desktop\winlogon.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
C:\Temp\winlogon.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
I am stillunable to connect to the internet, is this an issue? or will this be resolved when the process is resolved?
Aussie_Ash_131
OS : 8
Post by Belahzur on Mon Nov 16, 2009 6:45 pm
We'll try and resolve that now, I need 1 more log before hand though, it will show me more info and a few more things as to what's going on.
Post by Aussie_Ash_131 on Tue Nov 17, 2009 9:24 am
Thanks for all your help so far!
here is the logfile of hijack this:
Scan saved at 8:20:37 PM, on 17/11/2009
C:\Program Files\Belkin\Belkin Wireless Network Utility\WLService.exe
C:\Program Files\Belkin\Belkin Wireless Network Utility\WLanCfgG.exe
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\Program Files\McAfee\MSK\MskSrver.exe
C:\Program Files\Dell Support Center\bin\sprtsvc.exe
C:\WINDOWS\system32\igfxtray.exe
C:\WINDOWS\system32\hkcmd.exe
C:\WINDOWS\system32\ICO.EXE
C:\WINDOWS\RTHDCPL.EXE
C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
C:\Program Files\CyberLink\PowerDVD DX\PDVDDXSrv.exe
C:\Program Files\Dell Support Center\bin\sprtcmd.exe
C:\WINDOWS\system32\igfxsrvc.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\WINDOWS\system32\Pmxmiced.exe
C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe
c:\PROGRA~1\mcafee\mpf\mc\mpfalert.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Search,Default_Page_URL = [You must be registered and logged in to see this link.]
O2 - BHO: McAntiPhishingBHO - {377C180E-6F0E-4D4C-980F-F45BD3D40CF4} - c:\PROGRA~1\mcafee\msk\mcapbho.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - c:\PROGRA~1\mcafee\VIRUSS~1\scriptsn.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: Browser Address Error Redirector - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\Dell\BAE\BAE.dll
O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [IMJPMIG8.1] "C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
O4 - HKLM\..\Run: [MSPY2002] C:\WINDOWS\system32\IME\PINTLGNT\ImScInst.exe /SYNC
O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
O4 - HKLM\..\Run: [PMX Daemon] ICO.EXE
O4 - HKLM\..\Run: [ISUSPM Startup] C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe -startup
O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
O4 - HKLM\..\Run: [RoxWatchTray] "C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe"
O4 - HKLM\..\Run: [RoxioDragToDisc] "C:\Program Files\Roxio\Drag-to-Disc\DrgToDsc.exe"
O4 - HKLM\..\Run: [PDVDDXSrv] "C:\Program Files\CyberLink\PowerDVD DX\PDVDDXSrv.exe"
O4 - HKLM\..\Run: [ECenter] C:\Dell\E-Center\EULALauncher.exe
O4 - HKLM\..\Run: [dscactivate] "C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe"
O4 - HKLM\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKCU\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} (Checkers Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {48DD0448-9209-4F81-9F6D-D83562940134} (MySpace Uploader Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {5D6F45B3-9043-443D-A792-115447494D24} (UnoCtrl Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (MSN Games - Installer) - [You must be registered and logged in to see this link.]
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {D0C0F75C-683A-4390-A791-1ACFD5599AB8} (Oberon Flash Game Host) - [You must be registered and logged in to see this link.]
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - [You must be registered and logged in to see this link.]
O23 - Service: Belkin Wireless USB Network Adapter (Belkin Wireless USB Network Adapter Service) - Unknown owner - C:\Program Files\Belkin\Belkin Wireless Network Utility\WLService.exe
O23 - Service: McAfee Scanner (McODS) - Unknown owner - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
O23 - Service: McAfee Anti-Spam Service (MSK80Service) - McAfee, Inc. - C:\Program Files\McAfee\MSK\MskSrver.exe
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: Roxio Hard Drive Watcher 9 (RoxWatch9) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe
O23 - Service: SupportSoft Sprocket Service (dellsupportcenter) (sprtsvc_dellsupportcenter) - SupportSoft, Inc. - C:\Program Files\Dell Support Center\bin\sprtsvc.exe
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
End of file - 10523 bytes
Aussie_Ash_131
OS : 8
Post by Belahzur on Tue Nov 17, 2009 3:18 pm
Okay, good. The Hijack This log looks okay, but not done yet, this infection can be messy and sometimes like to leave its mark, so we need to shift that too.
Post by Aussie_Ash_131 on Wed Nov 18, 2009 1:04 am
Here is one of the logs:
Run by Ashbee at 11:55:03.84 on Wed 18/11/2009
Internet Explorer: 8.0.6001.18702
Microsoft Windows XP Home Edition 5.1.2600.3.1252.61.1033.18.1013.535 [GMT 11:00]
AV: McAfee VirusScan *On-access scanning enabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
FW: McAfee Personal Firewall *enabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
svchost.exe
svchost.exe
svchost.exe
svchost.exe
C:\Program Files\Dell Support Center\gs_agent\dsc.exe
C:\Documents and Settings\Ashbee\Desktop\dds.scr
BHO: McAfee Phishing Filter: {377c180e-6f0e-4d4c-980f-f45bd3d40cf4} - c:\progra~1\mcafee\msk\mcapbho.dll
BHO: scriptproxy: {7db2d5a0-7241-4e79-b68d-6309f01c5231} - c:\progra~1\mcafee\viruss~1\scriptsn.dll
BHO: {7E853D72-626A-48EC-A868-BA8D5E23E045} - No File
BHO: CBrowserHelperObject Object: {ca6319c0-31b7-401e-a518-a07c3db8f777} - c:\program files\dell\bae\BAE.dll
TB: {4064EA35-578D-4073-A834-C96D82CBCF40} - No File
uRun: [DellSupportCenter] "c:\program files\dell support center\bin\sprtcmd.exe" /P DellSupportCenter
mRun: [IgfxTray] c:\windows\system32\igfxtray.exe
mRun: [HotKeysCmds] c:\windows\system32\hkcmd.exe
mRun: [Persistence] c:\windows\system32\igfxpers.exe
mRun: [IMJPMIG8.1] "c:\windows\ime\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
mRun: [MSPY2002] c:\windows\system32\ime\pintlgnt\ImScInst.exe /SYNC
mRun: [PHIME2002ASync] c:\windows\system32\ime\tintlgnt\TINTSETP.EXE /SYNC
mRun: [PHIME2002A] c:\windows\system32\ime\tintlgnt\TINTSETP.EXE /IMEName
mRun: [PMX Daemon] ICO.EXE
mRun: [RTHDCPL] RTHDCPL.EXE
mRun: [Alcmtr] ALCMTR.EXE
mRun: [ISUSPM Startup] c:\progra~1\common~1\instal~1\update~1\ISUSPM.exe -startup
mRun: [ISUSScheduler] "c:\program files\common files\installshield\updateservice\issch.exe" -start
mRun: []
mRun: [RoxWatchTray] "c:\program files\common files\roxio shared\9.0\sharedcom\RoxWatchTray9.exe"
mRun: [RoxioDragToDisc] "c:\program files\roxio\drag-to-disc\DrgToDsc.exe"
mRun: [PDVDDXSrv] "c:\program files\cyberlink\powerdvd dx\PDVDDXSrv.exe"
mRun: [ECenter] c:\dell\e-center\EULALauncher.exe
mRun: [dscactivate] "c:\program files\dell support center\gs_agent\custom\dsca.exe"
mRun: [DellSupportCenter] "c:\program files\dell support center\bin\sprtcmd.exe" /P DellSupportCenter
mRun: [mcagent_exe] "c:\program files\mcafee.com\agent\mcagent.exe" /runkey
mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 9.0\reader\Reader_sl.exe"
mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe"
IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office12\EXCEL.EXE/3000
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~2\office12\REFIEBAR.DLL
Trusted Zone: carsales.com.au\www
Trusted Zone: internet
Trusted Zone: mcafee.com
DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} - [You must be registered and logged in to see this link.]
DPF: {48DD0448-9209-4F81-9F6D-D83562940134} - [You must be registered and logged in to see this link.]
DPF: {5D6F45B3-9043-443D-A792-115447494D24} - [You must be registered and logged in to see this link.]
DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} - [You must be registered and logged in to see this link.]
DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} - [You must be registered and logged in to see this link.]
DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {D0C0F75C-683A-4390-A791-1ACFD5599AB8} - [You must be registered and logged in to see this link.]
Notify: igfxcui - igfxdev.dll
R3 pmxmouse;PMXMOUSE;c:\windows\system32\drivers\pmxmouse.sys [2008-8-14 18432]
R3 pmxusblf;PMXUSBLF;c:\windows\system32\drivers\pmxusblf.sys [2008-8-14 14336]
S3 PVUSB;CESG502 USB Driver;c:\windows\system32\drivers\CESG502.SYS [2008-11-16 40672]
2009-11-17 09:20:10 0 d-----w- c:\program files\Trend Micro
2009-11-16 01:25:48 0 d-----w- c:\docume~1\ashbee\applic~1\Malwarebytes
2009-11-16 01:25:43 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-11-16 01:25:42 0 d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-11-16 01:25:41 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-11-16 01:25:40 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-16 01:23:01 4045544 ----a-w- c:\temp\mbam-setup.exe
2009-11-15 23:16:22 574 ----a-w- C:\cleanup.bat
2009-11-15 23:16:22 135168 ----a-w- C:\zip.exe
2009-11-14 06:16:15 0 d-----w- c:\temp\JavaRa
2009-11-14 06:15:49 71798 ----a-w- c:\temp\JavaRa.zip
2009-11-01 03:55:16 9345 ----a-w- c:\windows\system32\Config.MPF
2009-11-01 03:52:32 33832 ----a-w- c:\windows\system32\drivers\mferkdk.sys
2009-11-01 03:52:30 40488 ----a-w- c:\windows\system32\drivers\mfesmfk.sys
2009-11-01 03:52:29 79304 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2009-11-01 03:52:29 35240 ----a-w- c:\windows\system32\drivers\mfebopk.sys
2009-11-01 03:52:29 201320 ----a-w- c:\windows\system32\drivers\mfehidk.sys
2009-11-01 03:52:25 113952 ----a-w- c:\windows\system32\drivers\Mpfp.sys
2009-11-01 03:51:49 0 d-----w- c:\program files\McAfee.com
2009-11-01 03:51:45 0 d-----w- c:\program files\common files\McAfee
2009-11-01 03:51:32 0 d-----w- c:\program files\McAfee
2009-10-31 08:12:20 0 dc-h--w- c:\windows\ie8
2009-10-30 04:41:01 608344 ----a-w- c:\temp\MCPR.exe
2009-10-30 04:37:06 1097717 ----a-w- c:\windows\setupapi.log.3.old
2009-10-29 03:51:01 20747 ----a-w- c:\windows\system32\drivers\AegisP.sys
2009-10-29 03:50:36 40960 ----a-w- c:\windows\system32\B11gUSB.dll
2009-10-29 03:50:35 31930 ----a-w- c:\windows\system32\GTNDIS3.VXD
2009-10-29 03:50:34 94208 ----a-w- c:\windows\system32\GTW32N50.dll
2009-10-29 03:50:34 15872 ----a-w- c:\windows\system32\GTNDIS5.sys
2009-10-29 00:10:26 0 d-----w- c:\docume~1\alluse~1\applic~1\Citrix
2009-10-29 00:02:44 61224 ----a-w- c:\documents and settings\ashbee\GoToAssistDownloadHelper.exe
2009-10-23 00:39:07 0 d-----w- c:\program files\iPod
2009-10-23 00:39:01 0 d-----w- c:\program files\iTunes
2009-10-23 00:39:01 0 d-----w- c:\docume~1\alluse~1\applic~1\{755AC846-7372-4AC8-8550-C52491DAA8BD}
2009-11-15 23:23:18 40672 ----a-w- c:\windows\system32\drivers\CESG502.SYS
2009-10-22 09:19:04 5939712 ----a-w- c:\windows\system32\dllcache\mshtml.dll
2009-10-10 17:17:27 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-09-11 14:18:39 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-11 14:18:39 136192 ------w- c:\windows\system32\dllcache\msv1_0.dll
2009-09-04 21:03:36 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-09-04 21:03:36 58880 ------w- c:\windows\system32\dllcache\msasn1.dll
2009-08-28 10:35:52 173056 ------w- c:\windows\system32\dllcache\ie4uinit.exe
2009-08-28 08:42:52 2065696 ----a-w- c:\windows\system32\usbaaplrc.dll
2009-08-26 08:00:21 247326 ----a-w- c:\windows\system32\strmdll.dll
2009-08-26 08:00:21 247326 ------w- c:\windows\system32\dllcache\strmdll.dll
============= FINISH: 11:55:35.59 ===============
Aussie_Ash_131
OS : 8
Post by Aussie_Ash_131 on Wed Nov 18, 2009 1:10 am
And here is the other one.. (i couldnt figure out how to attatch it, hope thats ok.
Install Date: 14/08/2008 10:38:59 PM
System Uptime: 18/11/2009 11:52:44 AM (0 hours ago)
Motherboard: Dell Inc. | | 0CU409
Processor: Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz | Socket 775 | 1795/200mhz
C: is fȋxed (NTFS) - 146 GiB total, 101.062 GiB free.
D: is CDROM ()
E: is Removable
RP317: 14/11/2009 6:06:13 PM - Software Distribution Service 3.0
RP318: 14/11/2009 6:07:33 PM - Installed Java(TM) 6 Update 17
RP319: 14/11/2009 6:09:28 PM - Software Distribution Service 3.0
RP320: 14/11/2009 10:35:02 PM - Software Distribution Service 3.0
RP321: 14/11/2009 10:36:35 PM - Software Distribution Service 3.0
RP322: 14/11/2009 10:41:33 PM - Software Distribution Service 3.0
RP323: 14/11/2009 10:57:48 PM - Software Distribution Service 3.0
RP324: 15/11/2009 9:48:40 AM - Software Distribution Service 3.0
RP325: 16/11/2009 10:23:25 AM - Removed Program-Link FA-CP1
RP326: 16/11/2009 10:42:14 AM - Software Distribution Service 3.0
RP327: 16/11/2009 12:52:19 PM - Software Distribution Service 3.0
RP328: 17/11/2009 8:22:25 PM - Software Distribution Service 3.0
RP329: 17/11/2009 8:24:17 PM - Software Distribution Service 3.0
Acrobat.com
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Reader 9.2
Adobe Shockwave Player
Apple Application Support
Apple Mobile Device Support
Apple Software Update
Belkin 54g USB Network Adapter
Bonjour
Dell Support Center (Support Software)
Dell System Restore
HijackThis 2.0.2
Intel(R) PRO Network Connections 12.1.8.0
iTunes
Magic DVD Ripper V5.4.2
McAfee SecurityCenter
McAfee Virtual Technician
Messenger Plus! Live
Microsoft .NET Framework 1.1
Microsoft Age of Empires
Microsoft Office 2007 Service Pack 2 (SP2)
Microsoft Office Basic 2007
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
Microsoft Software Update for Web Folders (English) 12
Microsoft Visual C++ Run Time Lib Setup
MobileMe Control Panel
Morrowind
Mouse Suite for Desktop Computers
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 6.0 Parser (KB933579)
OGA Notifier 1.7.0105.35.0
PowerDVD
Project64 1.6
QuickTime
Roxio Creator Audio
Roxio Creator BDAV Plugin
Roxio Creator Copy
Roxio Creator Data
Roxio Creator DE
Roxio Creator Tools
Roxio Drag-to-Disc
Roxio Express Labeler
Roxio MyDVD DE
Roxio Update Manager
SearchAssist
Security Update for 2007 Microsoft Office System (KB969559)
Security Update for 2007 Microsoft Office System (KB973704)
Security Update for Microsoft Office Excel 2007 (KB973593)
Security Update for Microsoft Office Outlook 2007 (KB972363)
Security Update for Microsoft Office system 2007 (972581)
Security Update for Microsoft Office system 2007 (KB974234)
Security Update for Microsoft Office Visio Viewer 2007 (KB973709)
Security Update for Microsoft Office Word 2007 (KB969604)
Security Update for Windows Internet Explorer 8 (KB971961)
Security Update for Windows Internet Explorer 8 (KB972260)
Security Update for Windows Internet Explorer 8 (KB974455)
Security Update for Windows Media Player 9 (KB936782)
Security Update for Windows XP (KB956390)
Security Update for Windows XP (KB958215)
Security Update for Windows XP (KB960714)
Security Update for Windows XP (KB963027)
Security Update for Windows XP (KB969897)
Sonic Activation Module
Stkilda Saints Screen Saver
TES Construction Set
Update for Outlook 2007 Junk Email Filter (kb975960)
Update for Windows Internet Explorer 8 (KB976749)
WebFldrs XP
Where in the World is Carmen Sandiego?
Windows Live installer
Windows Live Messenger
Windows Live OneCare safety scanner
Windows XP Service Pack 3
WinRAR archiver
YouTube Downloader 2.5.3
Aussie_Ash_131
OS : 8
Post by Belahzur on Wed Nov 18, 2009 1:50 am
Log looks okay, still getting the on-demand scanner error?
Post by Aussie_Ash_131 on Wed Nov 18, 2009 10:17 pm
thanks for all your help so far! i really appreciate it!
well im actually unable to open mcafee, whatever i click on it just has the loading mouse thing and then doesnt open.
im also still unable to connect to the internet.
and sometimes i get an error report from micrsoft and it encounters an error with explorer.exe (usually when im trying to fix the internet settings) and then it pops up with another one for "Dr Watsons Postmortem Debugger".
Im getting worried about my computer haha.
Aussie_Ash_131
OS : 8
Post by Belahzur on Thu Nov 19, 2009 2:00 am
Please download [You must be registered and logged in to see this link.] file.
  • Please download Junction.zip and save it.
  • Unzip it and put junction.exe in the Windows directory (C:\Windows).
  • Go to Start => Run... => Copy and paste the following command in the run box and click OK:
    cmd /c junction -s c:\ >log.txt&log.txt& del log.txt
  • A command window opens starting to scan the system. Wait until a log file opens. Copy and paste or attach the content of it.
Post by Aussie_Ash_131 on Sat Nov 21, 2009 10:10 am
Here is the log of the code and junction.exe:
Junction v1.05 - Windows junction creator and reparse point viewer
Copyright (C) 2000-2007 Mark Russinovich
Systems Internals - [You must be registered and logged in to see this link.]
Failed to open \\?\c:\\hiberfil.sys: The process cannot access the file because it is being used by another process.
Failed to open \\?\c:\\pagefile.sys: The process cannot access the file because it is being used by another process.
Failed to open \\?\c:\\System Volume Information: Access is denied.
Failed to open \\?\c:\\Program Files\McAfee\VirusScan\mcods.exe: Access is denied.
.\\?\c:\\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a: JUNCTION
Print Name : C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790
Substitute Name: C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790
\\?\c:\\WINDOWS\assembly\GAC_MSIL\IEExecRemote\2.0.0.0__b03f5f7f11d50a3a: JUNCTION
Print Name : C:\WINDOWS\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e
Substitute Name: C:\WINDOWS\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e
.\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP258.tmp\ZAP258.tmp: MOUNT POINT
Substitute Name: \Device\__max++>\^
\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP35A.tmp\ZAP35A.tmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\temp\temp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\tmp\tmp: MOUNT POINT
\\?\c:\\WINDOWS\Config\Config: MOUNT POINT
\\?\c:\\WINDOWS\Connection Wizard\Connection Wizard: MOUNT POINT
.\\?\c:\\WINDOWS\Debug\UserMode\UserMode: MOUNT POINT
\\?\c:\\WINDOWS\Help\SBSI\Training\WXPPer\Cbz\Cbz: MOUNT POINT
.\\?\c:\\WINDOWS\Help\SBSI\Training\WXPPer\Lib\Lib: MOUNT POINT
\\?\c:\\WINDOWS\Help\SBSI\Training\WXPPer\Wave\Wave: MOUNT POINT
..\\?\c:\\WINDOWS\ie8updates\ie8updates: MOUNT POINT
\\?\c:\\WINDOWS\ime\imejp\applets\applets: MOUNT POINT
\\?\c:\\WINDOWS\ime\imejp98\imejp98: MOUNT POINT
..\\?\c:\\WINDOWS\inf\IEM\0409\0409: MOUNT POINT
.\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109511090400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109F100A0C00000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109F100C0400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\0DC1503A46F231838AD88BCDDC8E8F7C\3.2.30729\3.2.30729: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\DC3BF90CC0D3D2F398A9A6D1762F70F3\2.2.30729\2.2.30729: MOUNT POINT
\\?\c:\\WINDOWS\java\classes\classes: MOUNT POINT
\\?\c:\\WINDOWS\java\trustlib\trustlib: MOUNT POINT
.\\?\c:\\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\Bind Logs\Bind Logs: MOUNT POINT
.\\?\c:\\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\Temporary ASP.NET Files: MOUNT POINT
\\?\c:\\WINDOWS\msapps\msinfo\msinfo: MOUNT POINT
\\?\c:\\WINDOWS\mui\mui: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\ERRORREP\QHEADLES\QHEADLES: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\ERRORREP\QSIGNOFF\QSIGNOFF: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\BATCH\BATCH: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\pchealth\helpctr\binaries\helpsvc.exe: Access is denied.
\\?\c:\\WINDOWS\pchealth\helpctr\Config\CheckPoint\CheckPoint: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\Config\News\News: MOUNT POINT
.\\?\c:\\WINDOWS\pchealth\helpctr\HelpFiles\HelpFiles: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\InstalledSKUs\InstalledSKUs: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\System\DFS\DFS: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\Temp\Temp: MOUNT POINT
.\\?\c:\\WINDOWS\Registration\CRMLog\CRMLog: MOUNT POINT
...\\?\c:\\WINDOWS\SoftwareDistribution\AuthCabs\Downloaded\Downloaded: MOUNT POINT
\\?\c:\\WINDOWS\SoftwareDistribution\Download\b7b0631e184025ba37e5a4ec1d8637e7\backup\backup: MOUNT POINT
\\?\c:\\WINDOWS\Sun\Java\Deployment\Deployment: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\system32\MRT.exe: Access is denied.
..\\?\c:\\WINDOWS\Temp\Google Toolbar\Google Toolbar: MOUNT POINT
\\?\c:\\WINDOWS\Temp\History\Results\Results: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00000\MCE00000: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00001\MCE00001: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00002\MCE00002: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00003\MCE00003: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00004\MCE00004: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00005\MCE00005: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00006\MCE00006: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00007\MCE00007: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00008\MCE00008: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00009\MCE00009: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0000a\MCE0000a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0000b\MCE0000b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0000c\MCE0000c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0000d\MCE0000d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0000e\MCE0000e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0000f\MCE0000f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00010\MCE00010: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00011\MCE00011: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00012\MCE00012: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00013\MCE00013: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00014\MCE00014: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00015\MCE00015: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00016\MCE00016: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00017\MCE00017: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00018\MCE00018: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00019\MCE00019: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0001a\MCE0001a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0001b\MCE0001b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0001c\MCE0001c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0001d\MCE0001d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0001e\MCE0001e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0001f\MCE0001f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00020\MCE00020: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00021\MCE00021: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00022\MCE00022: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00023\MCE00023: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00024\MCE00024: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00025\MCE00025: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00026\MCE00026: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00027\MCE00027: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00028\MCE00028: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00029\MCE00029: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0002a\MCE0002a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0002b\MCE0002b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0002c\MCE0002c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0002d\MCE0002d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0002e\MCE0002e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0002f\MCE0002f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00030\MCE00030: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00031\MCE00031: MOUNT POINT
.\\?\c:\\WINDOWS\Temp\MCE00032\MCE00032: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00033\MCE00033: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00034\MCE00034: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00035\MCE00035: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00036\MCE00036: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00037\MCE00037: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00038\MCE00038: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00039\MCE00039: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0003a\MCE0003a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0003b\MCE0003b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0003c\MCE0003c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0003d\MCE0003d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0003e\MCE0003e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0003f\MCE0003f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00040\MCE00040: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00041\MCE00041: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00042\MCE00042: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00043\MCE00043: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00044\MCE00044: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00045\MCE00045: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00046\MCE00046: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00047\MCE00047: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00048\MCE00048: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00049\MCE00049: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0004a\MCE0004a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0004b\MCE0004b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0004c\MCE0004c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0004d\MCE0004d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0004e\MCE0004e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0004f\MCE0004f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00050\MCE00050: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00051\MCE00051: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00052\MCE00052: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00053\MCE00053: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00054\MCE00054: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00055\MCE00055: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00056\MCE00056: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00057\MCE00057: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00058\MCE00058: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00059\MCE00059: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0005a\MCE0005a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0005b\MCE0005b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0005c\MCE0005c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0005d\MCE0005d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0005e\MCE0005e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0005f\MCE0005f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00060\MCE00060: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00061\MCE00061: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00062\MCE00062: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00063\MCE00063: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00064\MCE00064: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00065\MCE00065: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00066\MCE00066: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00067\MCE00067: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00068\MCE00068: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00069\MCE00069: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0006a\MCE0006a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0006b\MCE0006b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0006c\MCE0006c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0006d\MCE0006d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0006e\MCE0006e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0006f\MCE0006f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00070\MCE00070: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00071\MCE00071: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00072\MCE00072: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00073\MCE00073: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00074\MCE00074: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00075\MCE00075: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00076\MCE00076: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00077\MCE00077: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00078\MCE00078: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00079\MCE00079: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0007a\MCE0007a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0007b\MCE0007b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0007c\MCE0007c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0007d\MCE0007d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0007e\MCE0007e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0007f\MCE0007f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00080\MCE00080: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00081\MCE00081: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00082\MCE00082: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00083\MCE00083: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00084\MCE00084: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00085\MCE00085: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00086\MCE00086: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00087\MCE00087: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00088\MCE00088: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00089\MCE00089: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0008a\MCE0008a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0008b\MCE0008b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0008c\MCE0008c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0008d\MCE0008d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0008e\MCE0008e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0008f\MCE0008f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00090\MCE00090: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00091\MCE00091: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00092\MCE00092: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00093\MCE00093: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00094\MCE00094: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00095\MCE00095: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00096\MCE00096: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00097\MCE00097: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00098\MCE00098: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE00099\MCE00099: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0009a\MCE0009a: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0009b\MCE0009b: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0009c\MCE0009c: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0009d\MCE0009d: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0009e\MCE0009e: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE0009f\MCE0009f: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a0\MCE000a0: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a1\MCE000a1: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a2\MCE000a2: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a3\MCE000a3: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a4\MCE000a4: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a5\MCE000a5: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a6\MCE000a6: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a7\MCE000a7: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a8\MCE000a8: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000a9\MCE000a9: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000aa\MCE000aa: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000ab\MCE000ab: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000ac\MCE000ac: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000ad\MCE000ad: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000ae\MCE000ae: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000af\MCE000af: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b0\MCE000b0: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b1\MCE000b1: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b2\MCE000b2: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b3\MCE000b3: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b4\MCE000b4: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b5\MCE000b5: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b6\MCE000b6: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b7\MCE000b7: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b8\MCE000b8: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000b9\MCE000b9: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000ba\MCE000ba: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000bb\MCE000bb: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000bc\MCE000bc: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000bd\MCE000bd: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000be\MCE000be: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000bf\MCE000bf: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c0\MCE000c0: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c1\MCE000c1: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c2\MCE000c2: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c3\MCE000c3: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c4\MCE000c4: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c5\MCE000c5: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c6\MCE000c6: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c7\MCE000c7: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c8\MCE000c8: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000c9\MCE000c9: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000ca\MCE000ca: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000cb\MCE000cb: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000cc\MCE000cc: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000cd\MCE000cd: MOUNT POINT
\\?\c:\\WINDOWS\Temp\MCE000ce\MCE000ce: MOUNT POINT
\\?\c:\\WINDOWS\Temp\RtSigs\Data\Data: MOUNT POINT
\\?\c:\\WINDOWS\WBEM\WBEM: MOUNT POINT
\\?\c:\\WINDOWS\WinSxS\InstallTemp\InstallTemp: MOUNT POINT
Aussie_Ash_131
OS : 8
Post by Belahzur on Sat Nov 21, 2009 9:36 pm
Like you did with juntion.exe, place inherit.exe into the Windows folder.
Now open a new notepad file.
@echo off
"inherit.exe" "c:\Program Files\McAfee\VirusScan\mcods.exe"
"inherit.exe" "c:\WINDOWS\system32\MRT.exe"
exit
Save this as fix.bat, save it to your desktop.
Let it run until it says OK on each one.
Post by Aussie_Ash_131 on Sat Nov 21, 2009 11:49 pm
Ok i've done that. what now?
or should everything be working now?
Aussie_Ash_131
OS : 8
Post by Belahzur on Sun Nov 22, 2009 2:05 am
Yeah, does Mcafee open/work now?
Post by Aussie_Ash_131 on Mon Nov 23, 2009 12:50 am
well i was unable to open mcafee still, so i reinstalled it, and it all works fine now. im running a scan now, just to be sure!
but i still cant connect to the internet, when i put in the internet preferences and click ok it tries to connect and then if it fails, the settings disappear again.
everything else seems to be working ok though...
so yeah i dont know whats happening or what to do.
Aussie_Ash_131
OS : 8
Post by Aussie_Ash_131 on Mon Nov 23, 2009 12:14 pm
oh and also a very intersting event happened today...
i put in the internet settings just in hope and it actually connected to the internet but the little icon in the system tray said it wasnt connected. but i was able to surf the internet and everything fine.
i found this out when putting in my registration info for mcafee, cos you need to subscribe online and it popped up saying internet connection found (half way through the scan).
i dont know if that changes anything, but just thought i should let you know.
Aussie_Ash_131
OS : 8
Post by Aussie_Ash_131 on Wed Nov 25, 2009 7:22 am
thanks for all our help with the mcafee problem! i really appreciate it!
just a quick question though:
for the problem with the internet, do i need to start a new topic?
or would you suggest ringing microsoft or something like that?
Aussie_Ash_131
OS : 8
Post by Belahzur on Wed Nov 25, 2009 7:13 pm
I would suggest opening a topic in the internet/networking section of this forum.
