Antivirus System PRO
Post by westbrkr007 on 12th November 2009, 1:46 am
I followed your instructions from Docter Inferno on "How to Remove Antivirus System PRO" from May 9, 2009. I downloaded the Malwarebytes' Anti-Malware program, ran the scan, and the program identified > 10 infected objects. I followed the instructions to remove the infected files and restarted the computer. After restarting, I still appear to have an issue with Antivirus System PRO. The Antivirus System PRO icon remains in the bottom right hand corner of my screen, and I am still experiencing disruptive pop-ups.
I am currently running the Malwarebytes' Anti-Malware program again and have identified 9 infected objects to date. I intend to follow the instructions again to remove the files, and restart the computer if instructed.
Do you have any recommendations to fully remove Antivirus System PRO?
Thanks,
westbrkr007
westbrkr007
Joined Joined : 2009-11-12
Points Points : 25833
Re: Antivirus System PRO
Post by Belahzur on 12th November 2009, 1:53 am
Points Points : 245091
