antivirus system pro bluescreen
Post by Jarker on 11th November 2009, 1:05 am
hello,
my girlfriend got the antivirus system pro junk installed while using stumble. It installed a bunch of porn junk and stopped her from opening programs to get rid of it. She had hijack this installed from the last time I i fȋxed this for her.
Anyways...she tried to restart the computer, but now it won't boot into windows. Even in safe mode. It just flashes a blue screen of death for a second and restarts. the computer is running win xp.
Please help
Jarker
Posts Posts : 21
Joined Joined : 2008-11-30
OS OS : winxp
Points Points : 29329
Re: antivirus system pro bluescreen
Post by Belahzur on 11th November 2009, 1:24 am
Points Points : 245111
Post by Jarker on 11th November 2009, 1:32 am
I can't even get into windows to do this
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 11th November 2009, 1:34 am
Do you have the XP disc? we can try a repair install in case Windows files are damaged.
Post by Jarker on 11th November 2009, 1:37 am
yes I do. doing the repair now
Jarker
Posts Posts : 21
OS OS : winxp
Post by Jarker on 11th November 2009, 3:56 am
did the repair and was able to get into windows. It automatically started the antivirus pro scan. I couldnt stop it. the rest of the screen was grey and i could not see anything but the avp scanning window.
I was able to get it to run in safe mode
Jarker
Posts Posts : 21
OS OS : winxp
Post by Jarker on 11th November 2009, 2:02 pm
I ran hijack this in safe mode. here is the log
Scan saved at 8:01:33 AM, on 11/11/2009
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\proquota.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
C:\DOCUME~1\C\LOCALS~1\Temp\lsass.exe
C:\DOCUME~1\C\LOCALS~1\Temp\winamp.exe
C:\DOCUME~1\C\LOCALS~1\Temp\user.exe
C:\Program Files\Adobe\Acrobat 9.0\Acrobat\AcrobatInfo.exe
O2 - BHO: C:\WINDOWS\system32\fzz1exv0.dll - {A45A4B15-23F2-42AD-F4E4-00AAC39C0004} - C:\WINDOWS\system32\fzz1exv0.dll
O3 - Toolbar: SnagIt - {8FF5E183-ABDE-46EB-B09E-D2AAB95CABE3} - C:\Program Files\TechSmith\SnagIt 9\SnagItIEAddin.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O3 - Toolbar: (no name) - {4F11ACBB-393F-4C86-A214-FF3D0D155CC3} - (no file)
O4 - HKLM\..\Run: [vptray] C:\PROGRA~1\SYMANT~1\SYMANT~1\vptray.exe
O4 - HKLM\..\Run: [Broadcom Wireless Manager UI] C:\WINDOWS\system32\WLTRAY.exe
O4 - HKLM\..\Run: [ATICCC] "C:\Program Files\ATI Technologies\ATI.ACE\cli.exe" runtime -Delay
O4 - HKLM\..\Run: [IntelZeroConfig] "C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe"
O4 - HKLM\..\Run: [IntelWireless] "C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe" /tf Intel PROSet/Wireless
O4 - HKLM\..\Run: [LMPDPSRV] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\LMPDPSRV.EXE
O4 - HKLM\..\Run: [Adobe Acrobat Speed Launcher] "C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 8.0] "C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe"
O4 - HKLM\..\Run: [calc] rundll32.exe C:\WINDOWS\system32\calc.dll,_IWMPEvents@0
O4 - HKLM\..\Run: [SigmatelSysTrayApp] stsystra.exe
O4 - HKLM\..\Run: [tuzorumog] Rundll32.exe "c:\windows\system32\yiyagefi.dll",a
O4 - HKCU\..\Run: [Aim6] "C:\Program Files\AIM6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.]
O4 - HKCU\..\Run: [DellSupport] "C:\Program Files\DellSupport\DSAgnt.exe" /startup
O4 - HKCU\..\Run: [TurboNet] C:\DOCUME~1\C\LOCALS~1\Temp\c.exe
O4 - HKCU\..\Run: [A00F1AF60FAC.exe] C:\DOCUME~1\C\LOCALS~1\Temp\_A00F1AF60FAC.exe
O4 - HKCU\..\Run: [calc] rundll32.exe C:\DOCUME~1\C\ntuser.dll,_IWMPEvents@0
O4 - HKCU\..\Run: [BackUp Windows 2009] C:\DOCUME~1\C\LOCALS~1\Temp\zk1yxu0jvk.exe
O4 - HKCU\..\Run: [Yjafosi8kdf98winmdkmnkmfnwe] C:\DOCUME~1\C\LOCALS~1\Temp\winamp.exe
O4 - HKCU\..\Run: [sjbvudwu] C:\Documents and Settings\C\Local Settings\Application Data\voyhyp\ykavsysguard.exe
O4 - HKCU\..\Run: [wow64main.exe] C:\DOCUME~1\C\LOCALS~1\Temp\wow64main.exe
O4 - HKCU\..\Run: [winhbt.exe] C:\DOCUME~1\C\LOCALS~1\Temp\winhbt.exe
O4 - HKUS\S-1-5-18\..\RunOnce: [tscuninstall] %systemroot%\system32\tscupgrd.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [tscuninstall] %systemroot%\system32\tscupgrd.exe (User 'Default user')
O4 - Startup: AntiVirus Plus.lnk = C:\WINDOWS\system32\rundll32.exe
O4 - Startup: scandisk.dll
O4 - Startup: scandisk.lnk = ?
O4 - Global Startup: AntiVirus Plus.lnk = C:\WINDOWS\system32\rundll32.exe
O4 - Global Startup: Lexmark X125 Settings Utility.lnk = C:\Program Files\Lexmark X125\LEX125SU.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: SnagIt 9.lnk = C:\Program Files\TechSmith\SnagIt 9\SnagIt32.exe
O8 - Extra context menu item: Append Link Target to Existing PDF - [You must be registered and logged in to see this link.] Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Append to Existing PDF - [You must be registered and logged in to see this link.] Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert Link Target to Adobe PDF - [You must be registered and logged in to see this link.] Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert to Adobe PDF - [You must be registered and logged in to see this link.] Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECapture.html
O9 - Extra button: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe
O9 - Extra 'Tools' menuitem: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O16 - DPF: {82774781-8F4E-11D1-AB1C-0000F8773BF0} (DLC Class) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{0CC2DFE5-A8D4-4217-80FB-CD3E5DBF0130}: NameServer = 77.74.48.113
O17 - HKLM\System\CCS\Services\Tcpip\..\{8A9A9987-759C-4F15-B1E1-5F8FE97BA7BE}: NameServer = 77.74.48.113
O17 - HKLM\System\CS1\Services\Tcpip\..\{0CC2DFE5-A8D4-4217-80FB-CD3E5DBF0130}: NameServer = 77.74.48.113
O17 - HKLM\System\CS2\Services\Tcpip\..\{0CC2DFE5-A8D4-4217-80FB-CD3E5DBF0130}: NameServer = 77.74.48.113
O20 - AppInit_DLLs: C:\WINDOWS\system32\kbdnet.dll c:\windows\system32\yiyagefi.dll,jivazona.dll
O20 - Winlogon Notify: __c008B109 - C:\WINDOWS\system32\__c008B109.dat
O21 - SSODL: nasuwatar - {6d41d1d4-4a7f-4ac5-8db3-7f259e588dd8} - c:\windows\system32\himefuwe.dll (file missing)
O21 - SSODL: lilimivar - {9a8fd447-b6fa-4ad1-8621-dcb1058df4a1} - c:\windows\system32\yiyagefi.dll
O22 - SharedTaskScheduler: kjaf83hfriunf3sf9sfinoi\sufh\87sefhuhdd - {A45A4B15-23F2-42AD-F4E4-00AAC39C0004} - C:\WINDOWS\system32\fzz1exv0.dll
O22 - SharedTaskScheduler: tokatiluy - {6d41d1d4-4a7f-4ac5-8db3-7f259e588dd8} - c:\windows\system32\himefuwe.dll (file missing)
O22 - SharedTaskScheduler: gahurihor - {9a8fd447-b6fa-4ad1-8621-dcb1058df4a1} - c:\windows\system32\yiyagefi.dll
O23 - Service: Ares Chatroom server (AresChatServer) - Ares Development Group - C:\Program Files\Ares\chatServer.exe
O23 - Service: DefWatch - Symantec Corporation - C:\Program Files\Symantec_Client_Security\Symantec AntiVirus\DefWatch.exe
O23 - Service: DSBrokerService - Unknown owner - C:\Program Files\DellSupport\brkrsvc.exe
O23 - Service: Intel(R) PROSet/Wireless Event Log (EvtEng) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
O23 - Service: fastnetsrv Service (fastnetsrv) - Netopsystems A - C:\WINDOWS\system32\FastNetSrv.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Net Login (NetLogin) - Unknown owner - C:\WINDOWS\svchost.exe (file missing)
O23 - Service: Net_Login - Unknown owner - C:\WINDOWS\svchust.exe
O23 - Service: Symantec AntiVirus Client (Norton AntiVirus Server) - Symantec Corporation - C:\Program Files\Symantec_Client_Security\Symantec AntiVirus\Rtvscan.exe
O23 - Service: Intel(R) PROSet/Wireless Registry Service (RegSrvc) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
O23 - Service: Intel(R) PROSet/Wireless Service (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
O23 - Service: Intel(R) PROSet/Wireless SSO Service (WLANKEEPER) - Intel(R) Corporation - C:\Program Files\Intel\Wireless\Bin\WLKeeper.exe
O23 - Service: Dell Wireless WLAN Tray Service (wltrysvc) - Unknown owner - C:\WINDOWS\System32\WLTRYSVC.EXE
End of file - 10578 bytes
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 11th November 2009, 8:17 pm
Post by Jarker on 11th November 2009, 9:01 pm
Ok i'm having trouble deleting things with hijack this. I scan and find the things you told me, but they won't delete. they seem to come back if i do another scan. Also, I tried to install Malwarebytes and it won't run. it can't find the exe.
here is another Hijack this log
Scan saved at 2:58:52 PM, on 11/11/2009
C:\WINDOWS\System32\bcmwltry.exe
C:\WINDOWS\TEMP\spoolsv.exe
C:\WINDOWS\TEMP\lsass.exe
C:\WINDOWS\stsystra.exe
C:\Program Files\Intel\Wireless\Bin\Dot1XCfg.exe
C:\DOCUME~1\C\LOCALS~1\Temp\9689037.exe
C:\Program Files\TechSmith\SnagIt 9\TSCHelp.exe
C:\Program Files\TechSmith\SnagIt 9\SnagPriv.exe
C:\Program Files\AIM6\aolsoftware.exe
C:\Program Files\TechSmith\SnagIt 9\snagiteditor.exe
O4 - HKLM\..\Run: [msnmager] C:\WINDOWS\system32\rundll32.exe C:\WINDOWS\TEMP\gdaiec.dll,Set1
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKUS\S-1-5-18\..\Run: [asg984jgkfmgasi8ug98jgkfgfb] C:\WINDOWS\TEMP\spoolsv.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [asg984jgkfmgasi8ug98jgkfgfb] C:\WINDOWS\TEMP\spoolsv.exe (User 'Default user')
O20 - AppInit_DLLs: C:\WINDOWS\system32\rdolib.dll,jivazona.dll c:\windows\system32\yiyagefi.dll,C:\DOCUME~1\C\LOCALS~1\Temp\4931xxx.dll,C:\DOCUME~1\C\LOCALS~1\Temp\374911333.dll,C:\DOCUME~1\C\LOCALS~1\Temp\384911usc.dll
O23 - Service: Nationalkjj Instruments Domain Service (Nationalbbs) - Unknown owner - C:\WINDOWS\system32\nernea.exe
End of file - 10505 bytes
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 11th November 2009, 10:52 pm
  • Download combofix from here
Post by Jarker on 11th November 2009, 11:03 pm
It's not working. When I run the combo fix it says it is not safe to continue. the computer may be infected with a file patching virus Virut
I can't connect to the internet on the laptop or everything goes crazy. so i'm downloading it on this computer and transferring it to the laptop with a usb drive
Jarker
Posts Posts : 21
OS OS : winxp
Post by Belahzur on 11th November 2009, 11:13 pm
I'm afraid I have bad news.
Your system is infected with a polymorphic file infector called Virut. Virut is capable of infecting all the machine's executable files (.exe) and screensaver files (.scr). However, the problem is that the virus has a number of bugs in its code, and as a result, it may misinfect a proportion of executable files and therefore, the files are corrupted beyond repair. As of now, security experts suggest that a format and clean install, or destructive recovery if you have an OEM recovery partition, is the best way to clean the infection and it is the best and safest way to return the machine to its normal working state.
Backup all your documents and important items (personal data, work documents, etc) only. DO NOT backup any executable files (softwares) and screensavers (*.scr). It attempts to infect any accessed .exe or .scr files by appending itself to the executable.
Also, avoid backing up compressed files (zip/cab/rar) files that have .exe or .scr files inside them. Virut can penetrate and infect .exe files inside compressed files too.
Recent variants also modify htm, html, asp and php files.
Do not back up to another machine, as it may become compromised. Burn to DVD/CD, or to an external drive which has nothing else on it, and which you can format should it happen to become infected from the backups.
For more information, please see [You must be registered and logged in to see this link.]
Instructions how to format and reinstall Windows can be found [You must be registered and logged in to see this link.]
